very cool switch panel with built in relays!!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timsxr, May 29, 2011.
  1. May 29, 2011 at 10:52 PM
    timsxr
    timsxr [OP] Well-Known Member
    portland
  2. May 29, 2011 at 10:57 PM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    2nd gen?
  3. May 29, 2011 at 11:01 PM
    timsxr
    portland
    or all i just did not know where to post it there is no electrical thread just lighting and audio??
  4. May 29, 2011 at 11:02 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab CLONE
    crap bolted and welded together....
    its cool as hell, but $400 :eek:
  5. May 29, 2011 at 11:09 PM
    snowgod06
    Rob
    06 Access Cab CLONE
    im just a cheap bastard :D
  6. May 29, 2011 at 11:10 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    I like
  7. May 29, 2011 at 11:11 PM
    timsxr
    portland
    i think it still needs a relay fuse box set up the switches are programable but only output 2.5 amps still a clean setup
  8. May 29, 2011 at 11:17 PM
    snowgod06
    Rob
    06 Access Cab CLONE
    WIRED HDH patent pending Flat Switch Panel (FSP) is the easiest, most versatile switch panel on the market today! No thicker than a credit card, a footprint smaller than a dollar bill, flexible, and programmabe makes our line of switch panels the best for ANY application!
    Being programmable, the FSP series gives you options on how to control any of your accesories. No other panel on the market gives you so many features straight out of the box!
    • Features:
      Keypad: 1/32" thick and measures 5.5" x 1.75"
    • Compact control unit measuring 6.5" x 3.25" x 1.25"
    • 8 switches in an area smaller than a dollar bill.
    • Keypad and control unit are water and chemical resistant. and completely splash proof
    • Easy, intuitive, "on the fly" programming. Takes less than 30 seconds! See how it works in out video section!
    • Individual switches can be "programmed" to be momentary or sustained
    • Individual switches can be "programmed" to be active all the time, or only when the ignition key is on
    • Each individual output is electronically fused for 2.5 amps - letting you run many accessories direct, or adding relays to run anything else!
    • Automatic low voltage protection - shuts down your accessories if the battery drops below a certain level
    • Water and Chemical resistant. Completely splash proof
    • Keypad is UV resistant for long life when mounted in open cabs
    • Switch life rating is >1,000,000 activations
    • Comes with WIRED HDH 2 year warranty
    WIRED's programmable Flat Switch Panel (FSP) comes with an eight button key pad, a control box, a 5' harness, and all the mounting and wiring accessories necessary to install the system in most vehicles.
    Key Pad: Eight programmable buttons in a single membrane key pad that is the thickness of a credit card. Each button is a tactile dome rated for 1,000,000 presses. Each button is programmable to make it either (1) a sustained button (like a rocker or toggle turning on/off an accessory) or (2) a momentary button (like a horn or winch in/out button) AND each button can be programmed to make it active either (1) all the time (a.k.a. wired battery direct) or (2) only with the ignition activated (a.k.a. when you turn your key on). Programming takes less than 30 seconds per switch.
    Control Unit: A small, remote-mounted control box which is the brain that allows the programmability of the key pad. All accessories added to a vehicle are routed to the Control Unit. The outputs of the Control Unit correspond with a button on the Keypad. Each output is rated to handle 2.5 amps and is auto current limiting. This means if you are powering something that requires more than 2.5 amps, or if you develop a short, the output will automatically turn off. Once the problem is solved, the output will regain power. Add a relay, and control any number of high powered accessories!
    Harness: A 5' harness with 2 locking connectors to link the keypad to the control box. The harness allows you to mount the Control Unit in an easily accessible area in the vehicle for easy addition of multiple accessories, whether the accessories are added all at once or added over a period of time.
  9. May 30, 2011 at 4:54 AM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    Auto zone used to have one of these with 4 buttons for about 50 bucks. The problem was the flat wire ribbon going to the panel was very prone to breaking. Also this does NOT have relays built in. Each output has 2.5 amps so most your accessories will still need a relay. If you do get this make sure to not kink that ribbon and secure it and the wire plugging into it so they cant move at all.
    I do like that they are programmable for momentary or on/off. I love the labels included and might try to find a set for when I do all my lighting.
  10. May 30, 2011 at 7:14 AM
    timsxr
    portland
  11. May 30, 2011 at 7:20 AM
    OZ-T
    Peter North
    British Columbia
  12. May 30, 2011 at 7:33 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    The "Big Nig"
    Lifted, Locked, Armored. Ready To Wheel.
    spod is like a relay box. instead of having a bunch of relays hooked up and mounted where ever, this is one unit that holds 6 relays.
    I really like this switch.. might have to get this for when I get my winch, and it will give me an excuse to wire up more stuff
  13. May 30, 2011 at 7:34 AM
    timsxr
    portland
    This gives you 6 relays and fused links so you can run your acessories right to it
  14. May 30, 2011 at 7:35 AM
    OZ-T
    Peter North
    British Columbia
    Thanks guys
  15. May 30, 2011 at 7:39 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    thats awesome, but $400?!?
