VERY intermittent steering shimmy while braking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mankx, Feb 24, 2024.
  1. Feb 24, 2024 at 2:10 PM
    Mankx
    Mankx [OP] New Member
    2013 Tacoma
    2013 Tacoma 2wd sport.
    Can't reproduce intentionally, but every now and then I get mild to violent shimmy while braking and it's repeatable for a few minutes, and then it's not.??!?!
    New front brakes, and rotors are within spec. No difference. Wheels all balanced - no difference.
    Can control arm bushings or ball joint cause rare severe shimmy? Seems it would be much more consistent. Other possibilities?
  2. Feb 24, 2024 at 3:47 PM
    Normshark
    Normshark Well-Known Member
    Great White North
    2014 Tacoma DCLB Limited
    Tie rod end? (daughter in laws Edge did that and I found a bad tie rod end)
    Sticking caliper intermittently heating up the rotor?
  3. Feb 25, 2024 at 3:54 PM
    TacoTuesday1
    SD CA
    who are the rotors made by
    And how do you know they are within spec. What spec.
  4. Feb 25, 2024 at 3:58 PM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    Definitely sounds like warped rotors to me with possible bad struts?? I know you said brakes were replaced but this is just such a common symptom of brakes
    wilcam47 likes this.
  5. Feb 25, 2024 at 5:44 PM
    BlkDakDave
    BlkDakDave Well-Known Member
    David
    CC TX
    07 AC PreRunner TRD/Off Road
    @Mankx here's my story. Had the same symptoms that I drove around on for a few years even though I knew what the problem was. Finally had enough and replaced the rotors, pads and added a second spring clip. That was four years ago and four years without steering wheel shake or brake pad slap. Morale of my story, pads and rotors should be replaced.
    Highly recommended read on StopTech Rotors.
    https://www.tacomaworld.com/threads/brake-upgrade-stoptech-rotors-trd-performance-pads.523829/
    Rotors I purchased. They were less than half this price in 2019 when I bought them. Wonder what happened?:rolleyes:
    https://www.autoaccessoriesgarage.com/Brakes/StopTech-Slotted-Brake-Rotors
    oldtimertoyota likes this.
  6. Feb 25, 2024 at 6:34 PM
    TacoTuesday1
    SD CA
    the factory rotors shake.
    mine did. No crazy driving. Turned them straight on a lathe. Shortly after they shook again. Maybe a month later.
    upgraded to Stoptech cryo slotted. No more shaking.
    wouldn’t put factory rotors on it if you paid me to.
