Very Loose Shifter On 6 speed :(
Discussion in 'Technical Chat' started by Hgkilla, May 21, 2012.
  1. May 21, 2012 at 9:10 PM
    Hgkilla
    Hgkilla [OP] Little Brown Pool Boy
    Cody
    Central Texas/Gulf Coast
    06 Access Cab Sport 4x4 6sp
    Yeah its in the making but its still a taco
    What is normal on a 6 speed shifter idk how loose the free play should be, like i could be in 5th gear and it will still move left to right tremendously and when im wheelin it will pop out of gear ?? is it just me ? or is there some grommit, spring , bushing that i dont know about thats worn out because i plan on installing the urd short throw shifter on it but i want to get rid of the loose play shifter first any ideas ???
  2. May 21, 2012 at 9:17 PM
    tinker_troy
    tinker_troy Well-Known Member
    T R O Y
    WY/SD
    #3, 2015 SR AC 4x4 V6 6 speed
    shackle brace, rear sway bar, 3 gen seats, Coupe Shifter, 3rd gen OR front springs + shocks, 17" 4runner 6 spoke wheels
    There is a rubber isolater in the shifter that gets worn that could be the problem. Member Coupe has a good write up on how he fixes em either on here or xru.
  3. May 21, 2012 at 9:34 PM
    Hgkilla
    Cody
    So there is no way to replace the internal isolater ?
  4. May 21, 2012 at 9:38 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    Everyone loves the URD short shifter. Taking it all apart to install will give you an excuse to nose around and see whats loose. I know AFTER install if you don't use loctite things can rattle loose and have a little play. As far as BEFORE with your stock shifter, I'm assuming it could be a similar issue but when I had mine all apart I didn't really pay attention to what could cause that. . .
  5. May 21, 2012 at 9:42 PM
    Hgkilla
    Cody
    like i can almost flick it its that loose
  6. May 21, 2012 at 11:15 PM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    Shifter is two pieces sandwiched together, so over time it can become worn. You won't know until you take off the console to look at the base. If the base stays still it's time to fix it, or a new shifter as it is sold as one piece. If the base moves you probably need a new plastic bushing. Marlin Crawler sells them cheap.
