Very loud popping -occasionally with wheels turned
Discussion in '2nd Gen. Tacomas (2005-2015)' started by DetroitDarin, Apr 8, 2024.
  1. Apr 8, 2024 at 6:17 PM
    DetroitDarin
    DetroitDarin [OP] Specified
    York County PA
    Scratches and Whatnot
    I'm kind of at a loss - nothing shows up on visual inspection but when I'm turning the wheels borderline sharply and giving any throttle I get a pop/bang as if it's still in 4wd maybe? It happens most of the time on uneven surfaces - could it be a broken coil/strut? Sway bar looks fine - one of the steering arms has some grease on it - but I think it's from when I tore a CV. I had the wheels up today and they didn't seem loose (like a wheel bearing problem) - there was some play - barely - top to bottom. but not side to side.
    I've seen where the skid plate can cause popping/banging - so I removed it to see what I see. Any other tips/directions where I can further diagnose?
  2. Apr 8, 2024 at 6:25 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Are the lower control arm bolts good and tight?
    If they a “loose” they can cause a pop. The6 need to be tight. Like tight..tight.
    How the ball joints looking?
    tacoman45, winkel and wilcam47 like this.
  3. Apr 8, 2024 at 6:27 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    CVs if ripped and no grease left could make the noise.
    Bad strut/shock inside the spring or loose nuts on the top mount under hood.
    But if at full steering stops then could simply be the stops metal on metal so you can grease the stop and then no noise (or don't crank the steering over fully).
  4. Apr 8, 2024 at 6:30 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    Grab the center section of your CV axle and shake it. Any play?
    wilcam47 likes this.
  5. Apr 9, 2024 at 4:28 AM
    DetroitDarin
    York County PA
    Thank you! I hadn't thought about the LCAs. Ball joints are good - one thing I noticed but thought my eyes were out of calibration - but seems like my passenger side wheel sits a little closer to the back of the fender when turned - it's like there's less ground clearance. I'll get under and check the cam bolts, then schedule an alignment if things are wonky.
    CVs are in perfect shape, visually.
    I'll double-tap those bolts thank you. Could it be a broken spring? I haven't seen anything but I can't see the back of it.
    I'll do that. Thank you.
  6. Apr 9, 2024 at 7:40 AM
    TnShooter
    Deogee
    STOCK
    :rofl:
    My truck would pop when turning the wheels sometimes. But most of the time it was when going in reverse. It started shortly after an alignment. I looked for ever and couldn’t find an issue. Finally I came across one post here on TW where a guy had just done LCA and had the same issue.
    Crawled under and cranked down on the bolts. That fixed my problem.
    I have lifetime alignment. And sure enough, the next time I had the alignment done. Same issue. I now tell the guys to double check and CRANK DOWN on those bolts.
    I don’t know if they follow torque specs or not. If so, the 100 ft/lbs isn’t enough.
    :rofl:
  7. Apr 9, 2024 at 7:44 AM
    DetroitDarin
    York County PA
    Thank you so much. I'll crawl under the truck tonite and see what I see.
    TnShooter[QUOTED] likes this.
  8. Apr 9, 2024 at 1:48 PM
    DetroitDarin
    York County PA
    Something tells me I found the problem. 11 month old CVJ with no wheeling; just about 50 miles in the snow.
    https://youtube.com/shorts/xarY8yoFegY
    Unsure if I should buy from them again.
    tacoman45, slossboss, Torspd and 4 others like this.
  9. Apr 9, 2024 at 1:51 PM
    TnShooter
    Deogee
    STOCK
    looks like you found the problem.
    Wow, that’s not good at all.
  10. Apr 9, 2024 at 2:09 PM
    DetroitDarin
    York County PA
    Oh - maybe 5000 miles on the axle. Likely less. One 1500 mile round trip, and then to and from work.
  11. Apr 9, 2024 at 2:17 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Looks like either the shaft broke or a circlip broke in the outer joint.
  12. Apr 10, 2024 at 3:38 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    That’s a new one for me to see…
    tacoman45 likes this.
  13. Apr 10, 2024 at 11:54 AM
    DetroitDarin
    York County PA
    New details - I thought I had two cvj axles in the truck - had only the one; the other one. This is likely an autozone-type axle from 2021 timeframe
  14. Aug 18, 2024 at 3:51 PM
    DetroitDarin
    York County PA
    Changing the CV didn't fix the issue. When I brake and sometimes turn, it sounds like i'm snapping an axle - that kind of bang/pop. I think next i'll replace the brake calipers, and grease the driveshaft and u-bolts.
  15. Aug 20, 2024 at 4:20 PM
    DetroitDarin
    York County PA
    BabyBilly likes this.
  16. Aug 20, 2024 at 4:54 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
  17. Aug 20, 2024 at 5:03 PM
    DetroitDarin
    York County PA
    Tightened it - but no torque wrench so erred toward too loose. Drive down to get the mail and back - truck was fine….except….right at the end. One pop/bang but 1/3 as loud as before. I am on the path. Will torque both sides. As an aside, I was dumb when checking them before (grabbed the Lca and tried to shake it) - I did it with the wheels mounted. Removing the wheel made the difference because obviously hanging there it’s easier to shake thatswhatshesaid. The popping could have been the cams spinning and then popping down over the metal stoppers.
    more to follow but am sure this is the right path to getting it fixed
    hyrule_trd likes this.
  18. Aug 20, 2024 at 5:47 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    Good luck!
  19. Aug 22, 2024 at 2:14 PM
    DetroitDarin
    York County PA
    To put a bow on this - I re-torqued the bolts on the LCA and the truck drives perfectly. However, there's damage to the little tabs that hold the cam, so I'm going to need something to get that sorted. But the popping/banging is gone.
    tacoman45 and hyrule_trd like this.
  20. Aug 22, 2024 at 2:22 PM
    hyrule_trd
    Eric
    Harford County, MD
    2020 Black TRD OR
    ForestRunnerFrank99 likes this.
