Very loud screeching from front right wheel
Discussion in 'Technical Chat' started by Windmill, Jul 17, 2024.
  1. Jul 17, 2024 at 4:40 PM
    Windmill
    Windmill [OP] Active Member
    2018 TRD Sport
    I first heard a slight squeal pulling into my garage today after about an hour drive. I left again to run to the store down the street and about half way there the noise was so loud I pulled over and turned around. Braking doesn’t affect the noise, other than to make it louder due to slowing down. At higher speeds it’s a high pitch squeal that correlates with wheel rotation. This is a 2018 with 43k on it. Not a mechanic at all, so I won’t even guess.
  2. Jul 17, 2024 at 4:46 PM
    661 Well-Known Member
    SoCal
    Check your brake rotors. I had a pebble once wedge its way in between the rotor and the backplate. Made an awful scraping/skreetching noise.
    Juspat2 and Windmill[OP] like this.
  3. Jul 17, 2024 at 4:50 PM
    kent50
    kent50 Well-Known Member
    Kent
    Gold River California
    2017 Tacoma Sport DCSB MGM
    3" Lift XD Wheels 33" K02s Predator Steps TRD Oil Cap Backflip Bed Cover Factory All Weather Mats WeatherTech Bed Mat TRD Pro Shift Knob Vinyl Air Bag Decal Covers Vinyl TRD and Tacoma Inserts Factory Mud Flaps Factory Remote Start Factory Door Sill Protectors Console Organizer and Tray Pro Fogs Grill Mounted LED Light Bar TRD Faux Grill DeBadged TRD Sport Door Emblems Factory Bed Lights Pop Lock Tailgate Lock Rear USB Ports DIY Power Panel
    This^
    Windmill[OP] likes this.
  4. Jul 17, 2024 at 4:59 PM
    Windmill
    2018 TRD Sport
    Thanks for the tip. Seems plausible based on the noise I’m hearing. I reached in there and flexed the plate and felt around as much as I could. Is there something in particular you did to find the pebble?
    Do I need to jack it up and remove the wheel?
  5. Jul 17, 2024 at 6:38 PM
    SoCal
    That might help give you more access to it. It could be wedged in between that flimsy metal and the rotor or it could be caught near the actual brake pad area.
    Try to watch some yt videos , I’m not a mechanic myself so it’s a little difficult to explain haha
    When it happened to me on my xterra I just took the wheel off and took the pebble out with a flat head screw driver but it took me a little bit to find it.
    Windmill[QUOTED][OP] likes this.
  6. Jul 17, 2024 at 7:10 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    If this ain't it check your wheel bearing.
  7. Jul 17, 2024 at 8:11 PM
    1 Limited Toyota
    1 Limited Toyota ISO XRunner body kit complete or pieces
    California
    08 XRunner
    slowly erasing past owner hacks
    Or small children
    661 and T4R_hereforbearings like this.
  8. Jul 18, 2024 at 8:10 AM
    Windmill
    2018 TRD Sport
    There was a small stick in there rubbing the rotor. Hard to believe it made such a loud noise, but it was jammed in there. Also pulled the guide pins and loosened the calipers to make sure they weren’t seized.
    HisDad, 661, kent50 and 3 others like this.
