Very Slight Shudder
Discussion in '3rd Gen. Tacomas (2016-2023)' started by mquibble, Jan 13, 2024.
  1. Jan 13, 2024 at 5:18 AM
    mquibble
    mquibble [OP] Well-Known Member
    Michael
    2021 TacomaTRD Pro
    I have a 2021 Pro with 35,000 miles. Over the past month I’ve noticed a very very slight shudder that stays fairly constant and wouldn’t be noticeable to those who don’t think about cars/trucks. Has anyone experienced this? Possibly it may be the tires reaching their end of life but part of me thinks it could be a loose spark plug? I don’t have any check engine lights on. I don’t believe it is inferior gas. Appreciate any ideas from this great resource. Thanks!
    Don’t know if this could be the cause by I had an Alu-Cab Canopy Camper installed a couple of months ago.
  2. Jan 13, 2024 at 5:30 AM
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Last time tires were balanced?
  3. Jan 13, 2024 at 5:36 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Never. I’m planning to replace the tires in another 5k miles so I can live with the shudder until then if this is the cause.
  4. Jan 13, 2024 at 11:21 AM
    ScottThePainter
    ScottThePainter Well-Known Member
    2023 TRD Off-Road Magnetic Grey
    If it started after the Alu-Cab install, I’m thinking it’s driveline vibration. I’m guessing it’s squatting more now.
    mquibble[OP] and Chew like this.
  5. Jan 13, 2024 at 11:27 AM
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Everything was fine until about when you installed the shell? It's probably either that new weight on the back or your tires are done. Or both. Get your new tires then report back.
  6. Jan 13, 2024 at 11:54 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Great point. I’ll check into that. Thanks!
  7. Jan 13, 2024 at 11:56 AM
    mquibble
    Michael
    2021 TacomaTRD Pro
    This is exactly why I posted here. I knew the experience and knowledge here is invaluable. Whether it actually is the camper causing the issue, and I’m guessing it is at least a contributing factor, it is certainly something to look into. Thanks you!
  8. Jan 13, 2024 at 12:03 PM
    mquibble
    Michael
    2021 TacomaTRD Pro
    Based on your inputs so far I believe the shell is, at a minimum, causing my nearing-end-of-life tires to be contributing to that very subtle shudder. I’m going to put some tires on in April and I’ll report back. I’ve got a cross-country trip coming up in May.
    I’m thinking of going with some skinny KO2’s [235-85-16]? I will get a slight bump in clearance height, push the MPG in the right direction- due to tire width not increased tire weight, and be better situated for any terrain troubles.
