vF Tuner for the 3.5L Tacoma-AGM tuning
Discussion in '3rd Gen. Tacomas (2016-2023)' started by banjoist13, Oct 12, 2020.
  1. Oct 12, 2020 at 1:44 PM
    banjoist13
    banjoist13 [OP] Well-Known Member
    Ian
    Humboldt County, CA
    2016 Off-Road 4x4 Manual Transmission
    BAMF Alumisteel front bumper, BAMF dual swing high clearance rear bumper, RCI full skids, C4 Fab Rock Sliders, Rago Fab LCA skids & rear shock mount skids, Method Trail 701 Wheels, ARB dual onboard air system under hood, Taco Tunes speaker system, Rago fabs center consol MOLLE, Weboost Drive Sleek OTR, SDHQ Billet Battery Terminals, Gofast Camper, Morimoto XD headlights and taillights, Accutune custom tuned Fox 2.5 adjustable front w/650lb Eibach springs and rear shocks, Deavers stage 3 leaf springs, Martin off-road camper rack, Cammo & Covers Tactical Seat covers,
    Please, this thread is only intended for discussing using vF tune to tune the alternator to properly charge AGM batteries or such related discussions. Always feel free to reach out to me if you have specific questions or want ideas on shifting things.
    C41n, SC4333, Governor and 8 others like this.
  2. Oct 12, 2020 at 2:17 PM
    banjoist13
    Ian
    Humboldt County, CA
    Here are my latest numbers for tuning the ECU to charge AGM batteries with the vF tune 04B14 2.0 SFOB Premium tune.
    This gives a cold start voltage of ~14.56 in the ECU which translates to ~14.66v at the battery terminals. It will then drop the voltage to around 14.2v-14.4 v once the engine is fully hot. Still waiting on some clarification from Matt and Raphael about what the different phase duty numbers actually correlate to. Please feel free to reach out if you have any questions!
    upload_2020-10-12_14-15-13.jpg[/USER]
  3. Oct 12, 2020 at 5:40 PM
    dutchcontractor
    dutchcontractor Well-Known Member
    Good deal! Thank you!
    WHTLTNG likes this.
  4. Oct 12, 2020 at 6:05 PM
    CLVol1255
    CLVol1255 Well-Known Member
    Tennessee
    2017 TRD Sport DCSB
    Bilstein 8112/8100 ICON RXT Stage 2 JBA UCAs Archive Garage HH w Shackles Archive Garage U Bolt Flip kit Nitto Ridge Grapplers 255/80/R17 TRD Front Skid and RCI Transmission Skid Kenwood DMX 1057XR Head Unit Focal Utopia WM 3 way plus WM10 Sub Mosconi 5/30 and Genesis Dual Mono Amp
    Sub’d for future reference. Thanks for sharing
    WHTLTNG likes this.
  5. Oct 12, 2020 at 7:02 PM
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    Just loaded a tune with these settings. My truck was still warm from my 35 mile commute home, but when I started it and took it around the neighborhood it was between 14.2-14.3 V. I’ll keep an eye on it and report back. Temps will drop into the 30’s here in the next few days, so I’ll get to see how it behaves when cold.
    soggyBottom and WHTLTNG like this.
  6. Oct 12, 2020 at 7:13 PM
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Running @Shellshock AGM values for the last however many months had me at 14.3 cold start, idk about warmed up float, I honestly never checked. Flashed the values that @banjoist13 had shared here this evening since I was flashing a new map edit anyhow and my cold start voltage was identical. Will try to remember to observe the warmed up voltage tomorrow
    uploadadventure, WHTLTNG and su.b.rat like this.
  7. Oct 12, 2020 at 7:22 PM
    banjoist13
    Ian
    Humboldt County, CA
    Try upping the first three base phase duty numbers by 1%. I am seeing that every truck seems to pretty much work a bit differently which makes sense given manufacturing tolerances and such. Feel free to send me your readings as you shift things. Like all of us, I am still trying to figure out what many of them do exactly. The Base Phase Duty chart seems to be the most influential given the available info. I still haven't figured out what numbers deal with the float charge.
    WHTLTNG and mZiggy[QUOTED] like this.
  8. Oct 12, 2020 at 7:24 PM
    mZiggy
    mZiggy Honey badger
    Marc
    Will try this tomorrow :thumbsup:
    WHTLTNG likes this.
  9. Oct 12, 2020 at 7:24 PM
    banjoist13
    Ian
    Humboldt County, CA
    That is what I am hitting with a warm engine which is pretty close to optimal.
  10. Oct 12, 2020 at 7:37 PM
    Shellshock
    Iowa
    The other variable is not everyone is setting the duty cycles the same.
    base phase duty controls the voltage output but you need the additional duty cycle to get the consistent voltage.
    At this point, we still don’t know exact what the columns of base phase duty correspond to and when the various duty cycles are actually used.
    that’s why I bumped my duty cycle all up by the same amount for consistency. I guess you could do the same thing for base phase duty
    FWIW, I’ve been running with my setting since vF was released with the alternator settings. My truck hasn’t started on fire so I’m not super worried about it.
  11. Oct 12, 2020 at 9:51 PM
    WHTLTNG
    WHTLTNG White Lightning
    Does anyone have alternator values for AGM with 04A61 (2018)?
    Maybe you can copy and paste the info below and add the new values.
    Please replace the Asterisks with the new values if you choose this route.
    If there is more than one way to skin this cat, let me see the other options. TIA
    Base Phase Duty - Current Values=
    *_____*_____*_____*_____*_____*_____*_____*_____*____
    Base Phase Initial Additive - Current Value= 0 ~ New Value= *
    Disable Control - Current Value= 3.578 ~ New Value= *
    Phase Duty 1 - Current Value= 14.031 ~ New Value= *
    Phase Duty 2 - Current Value= 60.796 ~ New Value= *
    Phase Duty 2 Base Voltage 13.6v - Current Value= 67.203 ~ New Value= *
    Phase Duty 3 - Current Value= 62.062 ~ New Value= *
    Phase Duty 4 - Current Value= 64 ~ New Value= *
    Phase Duty 5 - Current Value= 64 ~ New Value= *
    Phase Duty 9 - Current Value= 64 ~ New Value= *
    Phase Duty Base Voltage 13.6v - Current Value= 97.921 ~ New Value= *
    Phase Duty For Maximum Voltage 14.7v - Current Value= 102.398 ~ New Value= *
    Phase Duty Minimum - Current Value= 67.843 ~ New Value= *
    Phase Duty Maximum For 14.7 - Current Value= 102.398 ~ New Value= *
    soggyBottom likes this.
  12. Oct 13, 2020 at 10:44 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Using your values on my 2017 6MT, I logged using the vF logger just now and my results are as follows:
    Cold start, about 80deg ambient temp
    Max: 14.492
    Current: 14.45-14.6x
    Min: 14.3x
    Halfway warmed up engine:
    Max: unchanged (as expected)
    Current: 14.37-14.39x
    Min: 13.5x
    Fully warmed up engine:
    Current: 14.23-14.27
    Min: 13.085
    Mattchew likes this.
  13. Oct 13, 2020 at 11:35 AM
    mZiggy
    mZiggy Honey badger
    Marc
    *91.843 *91.843 *91.523 *94 *94 *94 *94 *94 *94
    Base Phase Initial Additive - Current Value= 0 ~ New Value= *unchanged
    Disable Control - Current Value= 3.578 ~ New Value= *unchanged
    Phase Duty 1 - Current Value= 14.031 ~ New Value= *unchanged
    Phase Duty 2 - Current Value= 60.796 ~ New Value= *80.796 (+20 = 20%)
    Phase Duty 2 Base Voltage 13.6v - Current Value= 67.203 ~ New Value= *87.203 (this is the main value that varies from the 2016-17 MY's and so I took Shellshock's advice and just raised by 20, figured that was safer than jumping all the way to 102.xxx)
    Phase Duty 3 - Current Value= 62.062 ~ New Value= *82.062
    Phase Duty 4 - Current Value= 64 ~ New Value= *84
    Phase Duty 5 - Current Value= 64 ~ New Value= *84
    Phase Duty 9 - Current Value= 64 ~ New Value= *84
    Phase Duty Base Voltage 13.6v - Current Value= 97.921 ~ New Value= *102.296
    Phase Duty For Maximum Voltage 14.7v - Current Value= 102.398 ~ New Value= *unchanged
    Phase Duty Minimum - Current Value= 67.843 ~ New Value= *73.703 (copied from @banjoist13 values)
    Phase Duty Maximum For 14.7 - Current Value= 102.398 ~ New Value= *unchanged
    The above values are what I put into a map for my 2018 friend and when he'd flashed them on an already warmed up engine, he got 14.4v
    The previous map, I'd had him try settings that matched the settings from @banjoist13 except that PD1 was left alone and for PD2 Base Voltage, I increased by 20, and he hit 14.2 on cold start which isn't enough.
  14. Oct 13, 2020 at 5:29 PM
    WHTLTNG
    Thank you, at minimum I have a starting point now. I am not sure when I will get to this. I will follow up on this though. :thumbsup:
    mZiggy[QUOTED] likes this.
  15. Oct 13, 2020 at 7:41 PM
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    Day 1 driving ~70 miles on @banjoist13 AGM tune. My previous AGM tune was a little closer to what @Shellshock and @mZiggy have shared. Just going by what I’m seeing on my simple cig lighter USB adapter with voltage reading, which I previously verified was close enough to my multimeter at the battery if I round up to nearest whole number after decimal point. Cold start up at ~45 F today had it at 14.6 for most of my initial ~5 mile city drive. Dropped off kiddo and upon restart (warm?) was at 14.5 for most of the rest of my 30 mile drive at 75 mph. I also saw it dropping to 14.1 or less when coming to a stop on city drive. After work, started my truck at 75 F (warm?) and it was at 14.3 and 14.2 for most all my drive home, ~30 miles at 75-80 mph. Engine definitely got fully to temp.
    Previous settings it really didn’t change much regardless of drive and temps, it was always around 14.4 and 14.5. Don’t know if any of this new stuff is better, but it does appear the @banjoist13 settings have more fluctuation, which I’m assuming is good as it changes charging voltage based on temps and other conditions, but I’m no battery-ologist guy...
  16. Oct 17, 2020 at 7:38 AM
    runmc
    runmc Well-Known Member
    Ron
    DFW Texas
    2021 Army Green Tacoma TRD OR DCSB
    One Mod after another
    Have you had a chance to try mZiggys settings ? Have you adjusted them? I just got my Tune pack and I'm ready to give this a try. :D
  17. Oct 17, 2020 at 8:20 AM
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I think it's appropriate to ask, especially before everything gets buried behind 10's of pages. Will these settings (once finalized) be universal to all AGM batteries?
  18. Oct 17, 2020 at 8:24 AM
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    Not sure if it can be universal but may be good enough. If each manufacturer has different charging requirements for their AGM battery, a universal setting may not work.
  19. Oct 17, 2020 at 8:27 AM
    mZiggy
    mZiggy Honey badger
    Marc
    Most are pretty similar though
    Shellshock likes this.
  20. Oct 17, 2020 at 12:35 PM
    oldschool403
    oldschool403 ReloadOS
    2018 TRD Sport Long Bed
    SOS Front bumper with winch, Dual battery, RCI bed rack, Smitty built XL, 8112's in front, King 2.5 adj in back, Armor on the way.
    I was experiencing some issues with my optima yellow tops this summer when I raised the voltages to 14.7. It was strange as when I would be driving it was fine but as soon as I stopped the volts dropped to 13 and I got a warning "check charging system". Then it would go away after I started moving again. So I turned down the Volts to 14.4 and it hasn't happened since. It hadn't happened until the summer and I have had the AGM adjustment in for many months leading up to it with no issue. I was reading the those optima agm's don't like heat and the Odyssey ones have high heat AGM's. Up to 80C.
    I was going to suggest that if people post their tweaks that we include the battery that it is being used on?
    ktbell444[QUOTED] and mZiggy like this.
