vF Tuner installation guide & FAQ
Discussion in 'Performance and Tuning' started by Shellshock, Nov 24, 2020.
  1. May 23, 2022 at 5:25 AM
    #321
    Yamota1617
    Yamota1617 Well-Known Member
    sean
    17 Tacoma sr5
    Yea restarted, connect the cable to the car. Then tried it without connecting to the car. Had the car on accessory, had the car off. Still nothing.
  2. May 23, 2022 at 5:45 AM
    #322
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You don't need to be plugged into your vehicle if you are just setting up the software. Just have the adapter plugged into the computer.
    su.b.rat likes this.
  3. May 23, 2022 at 5:57 AM
    #323
    su.b.rat
    su.b.rat broken truck
    if this was me i would get Revo uninstaller and completely uninstall vF, restart your box and install the latest fresh. then restart and go again.
    tonered and skeletron like this.
  4. May 23, 2022 at 7:12 AM
    #324
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    OVT / vF only installed into a couple folders:
    C:\Program Files (x86)\VF Tuner or C:\Program Files (x86)\VF Tuner Pro, if you have the Pro upgrade.
    And:
    C:\Users\ [your user account] \AppData\Roaming\EcuEdit
    su.b.rat[QUOTED] likes this.
  5. May 23, 2022 at 8:04 AM
    #325
    Yamota1617
    sean
    17 Tacoma sr5
    yea I have it in the first folder. Im still getting the same error message
  6. May 23, 2022 at 8:06 AM
    #326
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    That was not the point of the post. Sorry. If you uninstalled to start fresh, both of those folders should be gone. If either exist, delete them, then re-install vF. From there, plug in your Tactrix (with a WL xxxx Serial Number, right?) and launch the program.
    If that does not work, then you need to ping vF Tuner.
    If your Tactrix has a TA xxxx Serial Number, you may need to contact vF Tuner regardless.
    oliver1539 likes this.
  7. May 29, 2022 at 2:06 PM
    #327
    FlickFrack
    FlickFrack Well-Known Member
    MA
    '18 Superwhite TRD Pro
    How easy is this actually... it seems... complex
  8. May 29, 2022 at 3:02 PM
    #328
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Easy if you take the time to read the instructions.
    Shellshock[OP] likes this.
  9. May 29, 2022 at 3:03 PM
    #329
    FlickFrack
    MA
    Like anything else I suppose haha.
    ChilliTaco and tonered[QUOTED] like this.
  10. May 29, 2022 at 3:04 PM
    #330
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Exactly. It is just a matter of punching a few buttons after the software is set up. The new licensing scheme is truly plug and play.
  11. May 29, 2022 at 3:05 PM
    #331
    FlickFrack
    MA
    Appreciate the responses! Gives me some thought...
    tonered[QUOTED] likes this.
  12. May 29, 2022 at 3:07 PM
    #332
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    You're welcome!
    If you need anything else, just post up.
  13. Jun 5, 2022 at 3:36 PM
    #333
    oreinaga
    oreinaga New Member
    oscar
    2018 tacoma trd sport
    hola, estoy con vftuner 1.3, es necesario desinstalar esa versión de mi computadora antes de instalar 1.6?
  14. Jun 5, 2022 at 6:38 PM
    #334
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Hola.
    Mis disculpas, pero estoy haciendo esto con Google Translate.
    Sí. Debe actualizar a la última versión, que se encuentra en la página de inicio de vFTuner.com, ya que vF Tuner bloquea las versiones anteriores.
    ChilliTaco likes this.
  15. Jun 5, 2022 at 6:54 PM
    #335
    Shellshock
    Shellshock [OP] King Shit of Turd Island
    Iowa
    I knew you had this under control lmao
  16. Jun 5, 2022 at 6:56 PM
    #336
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Cheers!
    Been using it for Chinese to English. Now, holding a phone up to a computer screen to read images. That sucks! Hahaha!
  17. Jun 10, 2022 at 8:35 AM
    #337
    ChilliTaco
    ChilliTaco Well-Known Member
    Richard
    Alberta, Canada
    2017 AC TRD OR AT MGM
    Sooo this might be a little off topic, and apologies if it is, but thought this would be as good a spot as any to ask…
    - How would I go about tuning a friends truck, or can he use my tuner?
    - Would he buy the tune?
    There is literally no one within 5 hours drive that does tuning for Toyotas and I am sure there are others who would want to get tuned. I am not looking to make tunes, just possibly help those who want premade ones…
    - What is involved with the pro tuners I see on FB?
    - Is it a legit need to get licenced?
    thanks in advance!
  18. Jun 10, 2022 at 8:38 AM
    #338
    Shellshock
    Iowa
    you need the upgrade to vf pro and then you need whatever tunes you desire to use (either for a cost or per truck royalty)
    ChilliTaco[QUOTED] likes this.
  19. Jun 10, 2022 at 8:39 AM
    #339
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    If you have four Credits remaining on your account, you can Unlock your friend's VIN and flash him up.
    If you don't have Credits, your friend can contact vF Tuner and buy a Software Only License (about $229?) that will get him four Credits. Verify that he can use your Tactrix (Serial Number) to connect and flash as the Tactrix SN is tied to accounts now was the main licensing tool.
    Pro Tuners buy the Pro Tuner Upgrade ($1,250) which basically allows us to purchase Credits. It is very much necessary to Unlock VINs.
    Once a VIN is Unlocked, anyone with vF Tuner can flash them any number of times.
  20. Jun 10, 2022 at 8:42 AM
    #340
    ChilliTaco
    Richard
    Alberta, Canada
    Can I buy more credits if I have another truck? (Wife actually dealing on a Tundra right meow)
    I think that is the software licence you are talking about…
