VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Feb 27, 2021 at 8:44 PM
    #2041
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    I’m just thirsty for a beer
    Mooseditty17 and PapaRee[QUOTED] like this.
  2. Feb 27, 2021 at 8:45 PM
    #2042
    TWTaco
    TWTaco Well-Known Member
    Dave
    :cheers:
    PapaRee likes this.
  3. Feb 28, 2021 at 5:08 AM
    #2043
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    The OV Tune dyno runs posted on the first page of the 1.05 dev thread go down to 2,500 rpm. Hopefully we will get access to making gearlock work in the lower rpm range in the future. Your 5,000 rpm + gains are impressive, but 2k - 3k is where I'd really like to see more torque.
    inksin, hirod, Tacolife5 and 3 others like this.
  4. Feb 28, 2021 at 5:19 AM
    #2044
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Touche definitely
  5. Feb 28, 2021 at 5:41 AM
    #2045
    trdquoc
    "Q"
    We are definitely trying... if anyone has dyno’d these trucks can shed any light on how we can get one gear to stick and do consistent pulls we are all ears...
    We try a lot of different things on the dyno...
    Also.. does the dyno pull on OVTune 1.05 page... are they using a manual trans truck?
    shotgunbilly420 likes this.
  6. Feb 28, 2021 at 6:27 AM
    #2046
    dunlap837
    2018QSDCLBSR5
    Dont get me wrong I don’t mean to be negative or diminish what you guys have done at all, just really interested in what yall can do at lower rpms. I believe OVTune used his 2017 auto for his pulls.
  7. Feb 28, 2021 at 6:35 AM
    #2047
    Shellshock
    Iowa
    It was done with an AT and gear lock
  8. Feb 28, 2021 at 6:44 AM
    #2048
    shotgunbilly420
    I think Matt has done a great job with ov tune and PapaRee has done a good job fine tuning
    Rainoffire and PapaRee like this.
  9. Feb 28, 2021 at 6:48 AM
    #2049
    shotgunbilly420
    And it's our real world test results that make their tunes even better more we test the better it gets im gonna compile a 1,000 mile review on Kruiser 4.0 give the pros and cons and try to be detail as possible
    trdquoc and Mooseditty17 like this.
  10. Feb 28, 2021 at 6:49 AM
    #2050
    shotgunbilly420
    My hats off to you guys cause we are out having fun testing while you guys put in the hard work crunching numbers keep up the great work
    Mooseditty17 likes this.
  11. Feb 28, 2021 at 7:25 AM
    #2051
    trdquoc
    "Q"
    No offense taken, we wanted to know the low end numbers ourself. We used the gear lock tunes but the truck still wanted to shift.
    @TWTaco @PapaRee and myself are determined to figure this out... trust me, I want to see the low end performance gains myself and it’s bummed that something is quite not right with the gear lock.
    Mooseditty17 and shotgunbilly420 like this.
  12. Feb 28, 2021 at 7:28 AM
    #2052
    trdquoc
    "Q"
    We’ll try it again, I wasn’t manning the dyno this time, @TWTaco was at the helm and I’ll have to revisit the conversation to see if the guy running the dyno had it properly setup...
    These are all valuable data points regardless and part of the learning process which is why we come back to the dyno tune after tune to learn and make the tunes better.
    It’s also like a fun 3rd grade science experiment where you have a hypothesis and test your work to come to a conclusion and come back time and time again to get it right.
    We are all having fun and learning as we go which is why we are even doing this with funds out of our pockets.
  13. Feb 28, 2021 at 7:38 AM
    #2053
    OVTune
    OVTune Well-Known Member
    OVTune
    put truck in ECT mode.
    set ECT mode downshift tables to 0.
    you can full throttle without downshifts.
  14. Feb 28, 2021 at 7:39 AM
    #2054
    trdquoc
    "Q"
    I believe we did that, but we could have made an error. Will go back to it again!
  15. Feb 28, 2021 at 7:44 AM
    #2055
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Something was definitely wrong because I can go wot with gearlock no problem.
  16. Feb 28, 2021 at 7:45 AM
    #2056
    trdquoc
    "Q"
    Would agree 100%
    PapaRee and shotgunbilly420 like this.
  17. Feb 28, 2021 at 9:29 AM
    #2057
    uploadadventure
    uploadadventure [OP] It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    :rocket:
  18. Feb 28, 2021 at 10:44 AM
    #2058
    SpeySquatch
    2016 TRD OR DCSB
    Is this a different file from 4.0 Kruiser?
  19. Feb 28, 2021 at 10:47 AM
    #2059
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    We did NOT have them set to 0.
    We had them set at the low value in the table/map.
    That has to be the problem.
    Thanks for the info. Makes sense!!
    All the past GearLock info says to set them to lowest value.
  20. Feb 28, 2021 at 10:48 AM
    #2060
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Different name, slightly different (minor settings).
