VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Feb 28, 2021 at 12:19 PM
    #2061
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    I have access to a mainline hubpro for relatively fair rates, since I have a couple good friends that work at this particular shop. I might could be enticed to see about getting an hour or two of time booked to try out some different tunes :anonymous:
    It’s usually reserved for relatively high horsepower cars, as such, so I might be laughed at.
    https://www.instagram.com/p/CCV7kQBHGwV/?igshid=1cwunr99c1m8b
    :ohsnap:
  2. Feb 28, 2021 at 3:12 PM
    #2062
    Crimson Flam3s
    Crimson Flam3s Well-Known Member
    Tried the 87 cruiser file and it has great performance and mpg!
    If I switch to the 91/93, it should be making a bit more hp correct? wondering how noticeable it is..
    shotgunbilly420 and Scott4032 like this.
  3. Feb 28, 2021 at 3:24 PM
    #2063
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    You are welcome to continue using the shared version in the 1st post.
    That is a very early version that was shared publicly. There is a newer (improved) version that is available only by PM.
    The Premium versions do produce slightly more HP, but in my opinion, not noticeable enough to justify some people's gas prices.
  4. Feb 28, 2021 at 4:36 PM
    #2064
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Can you still shift with s mode like this?
  5. Feb 28, 2021 at 5:32 PM
    #2065
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Youse guys that have been messing with that transmission throttle reduction tables... how's it going?
  6. Feb 28, 2021 at 5:46 PM
    #2066
    Mooseditty17
    AJ
    WI
    Trans torque tables?
    I averaged all 17 tables including the axis values and made them all the same. Left "sport" out of the equation. Works beautifully
  7. Feb 28, 2021 at 7:00 PM
    #2067
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    I've done similar to a degree I've been tweaking it since to produce better drivability. It's surprising how much different the truck will drive by modifying those tables.
  8. Feb 28, 2021 at 8:31 PM
    #2068
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    K 4.0 is killer. That low end torque is niiiice. When u need to accelerate in a higher gear, she's not afraid to do it. About 300 miles in, so far I'm impressed!
  9. Feb 28, 2021 at 8:46 PM
    #2069
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    I have one queued up but haven’t flashed it yet. I used the OV example tune maps on top of a modified version of @PapaRee 4.0. I didn’t modify all of them to the same map, I did something similar to what OV posted in the combined sample tune.
    Any tricks/lessons learned you’d like to share with the class before I flash my version?
  10. Feb 28, 2021 at 8:57 PM
    #2070
    PapaRee
    PapaRee Pro Tuner
    Kreg
    If you look at them all and their 3D shape, you can see which ones need to be done. I did not change them all, but did change about half of them on a new tune.
  11. Mar 1, 2021 at 5:21 AM
    #2071
    dunlap837
    2018QSDCLBSR5
    Yes, those are the tables I'm asking about. So the results were positive? I think I will make the same change this week.
  12. Mar 1, 2021 at 5:22 AM
    #2072
    dunlap837
    2018QSDCLBSR5
    How are you determining where on the table to tweak? The axes are throttle position vs vehicle speed. Throttle position is easy (I think), but do you have any idea what the units are for vehicle speed?
  13. Mar 1, 2021 at 5:45 AM
    #2073
    N5J_Taco
    N5J_Taco Well-Known Member
    Tune and hang on!! This by far the best tune for me that holds cruise and keeps low trans temps while pulling up steep hills and mountains in my area. It's finally a pleasure to drive with cruise on to being able to crest small hills and never down shift to 5 or 4th gear! I did lower the tip in on the skinny pedal for winter driving BUT will go back to the original when it stays dry.
    PapaRee likes this.
  14. Mar 1, 2021 at 5:49 AM
    #2074
    My Name Is Nobody
    My Name Is Nobody Active Member
    Rex
    Colorado
    2020 OR, Barcelona Red (unfortunately)
    You might be alright and able to get away with the current file's tip in - so long as it stays dry and no further significant snow storms come through. What @PapaRee modified for me was perfect just sensitive enough but not too much taken out that it made it boring or anything.
    PapaRee likes this.
  15. Mar 1, 2021 at 5:51 AM
    #2075
    BortisYeltzen
    Barrett
    Salt Lake City, UT
    I’ve been running a modified Kruiser 4.0 for a while now, it is a great tune. I altered the 3-4, 4-5 and 5-6 downshift points for around here and slightly reduced the normal throttle values in lower gears as well. It’s mainly the 17 transmission throttle reduction tables I haven’t implemented. Kruiser 4.0 had table 10 modified, and possibly a few more, but not all 17. I have a tune ready to flash where I’ve changed the majority of them based on the example tune OV posted. Maybe mid week I’ll flash it.
    PapaRee and N5J_Taco[QUOTED] like this.
  16. Mar 1, 2021 at 6:55 AM
    #2076
    Mooseditty17
    AJ
    WI
    I feel it is more consistent and "smoother" shifting.
  17. Mar 1, 2021 at 7:47 AM
    #2077
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Kph
  18. Mar 1, 2021 at 7:56 AM
    #2078
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Well, @OVTune or anyone else that may know the answer.
    What happened to the previously bought credits before we went to this new system?
  19. Mar 1, 2021 at 7:59 AM
    #2079
    dunlap837
    2018QSDCLBSR5
    Are they actually kph, or are they kph like the shift schedule maps are (not) kph?
  20. Mar 1, 2021 at 8:25 AM
    #2080
    Vlady
    Issy, WA
    There is only one kph...
    A while ago I set my monitoring apps to kph and helped alot to dial in shift points.
