VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Mar 2, 2021 at 4:46 PM
    #2121
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    It's for regular, and it's a solid tune. If you want a BETTER tune, since many improvements have been made since then, PM me!
    PapaRee likes this.
  2. Mar 3, 2021 at 3:04 AM
    #2122
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    I have been driving with 04B04 Kruiser 4.0 now for a couple weeks. Probably 4 tanks of gas in and it's definitely settled in nicely. I'm back to the exact same mileage I was before. Leveled out at 13.7 which is about right for my heavy pig of a truck. Definitely noticeable performance gains and still seeing really nice shifting and holding gears like you'd have expected it to drive off the lot. No dead pedal like someone else described a while back, and when the torque demand increases a quick and minor blip of the throttle causes it to down shift nice and smooth. I did change the throttle map a little to eliminate the jumpiness at lower speeds which made this even more of a wicked ass tune. Really really loving how my truck drives on this one! Nice work @PapaRee!
  3. Mar 3, 2021 at 9:59 AM
    #2123
    ivan5105
    ivan5105 Member
    ivan
    San Juan, PR
    2016 Off Road Tacoma 4x4
    KDMax tuning,BP51,TRD intake and exh.,5.29
    Last month I was using differents versions of 04B04 Kruiser 4.0 .My taco only has rock sliders and 31.5 tires,no much weight added.Started with the premiun version, the performance gains was really good, smooth shifting,good power for pass traffic no matter the speed, climbing hills was really nice,no more weird downshitft.The only problem was that I used my Taco as a daily driver with lots of stop and go, traffic congestion and trying to maintain a smooth throttle was difficult.I sent a message to Kreig and he sent me a "light tip in" version of Kruiser 4.0.Much better but my wife didn't liked the touchy throttle on "the light tip in"version and I changed to OV 2.0.I sent another message to Kreig and he changed the throttle tip in again.Wow what a difference,all the power of Kruiser 4.0 but with a super smooth throttle,know driving the taco is another history,super happy with the modified tip in throttle(regular gas) of Kruiser 4.0.Driving the taco is effortless I don' have to think when or how hard I have to push the pedal.Mpg are good for my driving style.I think PapaRee K 4.0 is a huge improvement over Toyota software. I love the way my truck drives and Kruiser 4.0 "light tip in" is a keeper!(wife approved)Thanks PapaRee!
    AjaxTaco, honey, TWTaco and 9 others like this.
  4. Mar 3, 2021 at 6:13 PM
    #2124
    TacoManOne
    TacoManOne YotaWerx Authorized Tuner
    Paul
    Liberty Lake, WA
    2018 Blazing Blue TRDOR DCLB Premium JBL
    YotaWerx Tuned, Meso stuff, JBL upgrades, Bilstein 6112/5160, RAS
    @PapaRee Another review of the Kruiser 4.0 tune. Great power increase and shifting is amazing. Super smooth. I really like how it holds gears longer before shifting down. Helps on the freeway. Holds speed really well on the freeway without downshifting or lugging. Mileage today (58 deg F) was running about 19.6 which is good for still being winter. Need to try it out towing now.
  5. Mar 3, 2021 at 6:13 PM
    #2125
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Yes I too love the k 4.0 but yeah tip in is lil too nasty for me .I thought that it would be great for the dunes or snow . When in doubt throttle out . Pin it to win it
    Scott4032, TWTaco and PapaRee like this.
  6. Mar 3, 2021 at 6:14 PM
    #2126
    shotgunbilly420
    I too will hopefully be trying the lighter tip in version .
    PapaRee likes this.
  7. Mar 3, 2021 at 6:24 PM
    #2127
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Glad to hear it!
    Towing is good with it. If it is a heavy load, press the ECT button.
  8. Mar 3, 2021 at 6:25 PM
    #2128
    TacoManOne
    Paul
    Liberty Lake, WA
    ECT is fun without towing! Way crazy acceleration.
  9. Mar 3, 2021 at 8:07 PM
    #2129
    DownhillDragon
    Brody
    Austin, TX
    The beauty of ECT is that what works best for towing is pretty much the same things that work best for a sport mode... more reactive throttle, holding gears longer. I never tow, but I sure use ECT often lol.
  10. Mar 3, 2021 at 8:54 PM
    #2130
    uploadadventure
    uploadadventure [OP] It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    So anyone doing things with tunes these days...
    Has anyone tried putting the Camry Airload tables in their tune...
    :boink: @Chadr7858
  11. Mar 3, 2021 at 9:05 PM
    #2131
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    It's a minivan motor after all
  12. Mar 3, 2021 at 9:11 PM
    #2132
    uploadadventure
    Dixon, Mo
    The minivan pulls better.
    Shellshock likes this.
  13. Mar 3, 2021 at 9:12 PM
    #2133
    Chadr7858
    Chad
    Colorado
    True
  14. Mar 3, 2021 at 9:43 PM
    #2134
    cdoghump
    cdoghump Well-Known Member
    Amarillo, TX
    17' TRD OR DCSB 4x4
    I had to reset my laptop and had to put in my Master Key in again, but I was putting the wrong number in a few times.:frusty: so now I've exceeded the amount of tries you can try and now I'm locked out. Any chance anyone know how long till it resets?:pccoffee:
  15. Mar 4, 2021 at 2:58 AM
    #2135
    Stormpeacock
    Stormpeacock IG: @storm.peacock
    Rich
    Atlanta, GA
    19 Cement Offroad
    MCB Elite Performance Tuned 5.29 Differential Gearing 35" Kenda M/T on Steelies SOS Bumpers, Skids, and Sliders Ranch Camper Shell
    You have to request a reset from Ovtune. Send a zendesk ticket
  16. Mar 4, 2021 at 5:57 AM
    #2136
    cdoghump
    Amarillo, TX
    17' TRD OR DCSB 4x4
    Thanks
  17. Mar 4, 2021 at 5:58 AM
    #2137
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    A Tacoma that identifies as a Camry?
    :lalala:
    TacoManOne likes this.
  18. Mar 4, 2021 at 6:17 AM
    #2138
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    @PapaRee 's 4.0 Kruiser premium netted me 24.2 mpg's, for the first 50 miles on a fresh tank of non ethanol premium, driving with my foot no cruise control. it is a definite improvement over stock. cant wait until the cruise tables, and more shift tables are opened. I am still not fully in love with the standard cruise shifting but, that is not on him or the tune, that is on my ocd, the toyota algorithm, and the available tables to work with, at this time . the truck is worlds better but, still hunts a bit too much for my liking, on slightly hilly terrain, over 55 mph with cruise engaged. driving by foot, the truck is absolutely INCREDIBLE! well worth the donations, and feedback. thanks buddy! hope your day is awesome! Ski
    shotgunbilly420, PapaRee and TWTaco like this.
  19. Mar 4, 2021 at 11:20 AM
    #2139
    Ak-47
    Ak-47 Member
    Chode
    Austin TX
    2016 Quicksand Tacoma TRD Off-Road
    2" lift + 1" leveling kit + 35" tires + very tiny benis
    Kruiser 4.0 is pretty fun, I just started using it today. I feel like there is no way that I will keep getting the 14.5mpg I was getting before (because it's more fun to drive fast with this tune)... but maybe once I get used to the throttle more. Very nice driving so far, my gibson exhaust is screaming now, good thing I did sound dampening and insulation in the cabin.
    So I was able to flash the tune by unlocking vin for 4 credits, but I cannot open the tunes without paying another 4 credits? I only had 5
    PapaRee likes this.
  20. Mar 4, 2021 at 11:58 AM
    #2140
    N5J_Taco
    N5J_Taco Well-Known Member
    Yeah Kruiser 4.0 is fun to drive! If you bought the tune pack you may need to contact OVTune help desk with your order number and the ECU ID you need the tunes for and let them know your issue.
    PapaRee likes this.
