VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Mar 13, 2021 at 8:19 PM
    #2421
    PRO_Taco
    PRO_Taco Well-Known Member
    Ontario Canada
    2025 TRD PRO
    Ceramic coated Underground ARB rear bumper flush mount lights Trailhunter rock sliders
    @wahoobie couldn't agree more. 100% a leap in the right direction.
    Mooseditty17 and wahoobie like this.
  2. Mar 13, 2021 at 8:45 PM
    #2422
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    Setting those throttle limits all to 100 is where it’s at. :burnrubber:
  3. Mar 13, 2021 at 8:49 PM
    #2423
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    So 3-months ago :boink:
  4. Mar 13, 2021 at 9:24 PM
    #2424
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    What tire size you running?
  5. Mar 13, 2021 at 9:34 PM
    #2425
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    I gave it a whirl. FYI, I drove PapaRee's tune with the same tire size.
    Some elements of tune are fantastic. Tip in is just right. The engine sounded better and overall was a smooth drive.. but shifting was subpar.
    On the cold engine 1-2-3 were abrupt. 4-5 was a lazy upshift -low fluid lazy. 6th was jerky and always felt.
    After 30 minutes of driving, 4-5 and 5-6 were the same and did not improve.
    I think 1-2 was a perfect upshift, but there were alot of short upshift in the wrong time.
    Alot of 6th gear driving. Good job to make truck staying in 6th. However, for a hilly driving I prefer early downshift to 5th. PapaRee's downshift at 28 % of the accelerator , yours at 35..
    Here is a screenshot of the same place where PapaRee w/Warm engine opt. shifting maps slightly outperformed and kept 5th at 100% of the load. Yours downshifted to 4th after hitting 98%. In reality, I prefer downshift to 4th around 95%.
    Mpg was the same.
    I would try the tune with different opt. torque shifting maps and adjusted shift points. .
    BTW, Both tunes would not upshift to 5th under the load. It was a bit disappointing. Works in S . Works in D if speed below 65 and low accelerator
  6. Mar 14, 2021 at 4:49 AM
    #2426
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    Did you figure out of the speed units are kph as labelled?
  7. Mar 14, 2021 at 4:51 AM
    #2427
    wahoobie
    chris
    Suffolk, VA
    Stock 245-75R16
  8. Mar 14, 2021 at 5:10 AM
    #2428
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Anyone with solid advice on idle settings?
    WAY closer to MPH than KPH. If I set an upshift to 60, it shifts at 57-58 mph. That would be closer to 100 if in KPH.
  9. Mar 14, 2021 at 5:21 AM
    #2429
    Mooseditty17
    AJ
    WI
    I find that shifting into 5th prior to 50 mph is unnecessary. Cruising at 45 I'm at 1700 rpm, but mpg are still in the 18-20 range as the load is so light. When I have the upshift from 4-5 shift sooner, like 40 or 45, the truck seems to just lug along. Then to get up to 55 which is generally right after a 45 zone, you're downshifting again anyways. It's intentionally "lazy". What do you mean by short upshifting at wrong times? Truck was upshifting too soon? What load % both the tunes not shifting into 5th? I don't find either of them really have an issue... What is your level of expectations there? Are you continuing to run the tune longer or calling it at 30 minutes?
    Greatly appreciate the constructive criticism!
  10. Mar 14, 2021 at 6:02 AM
    #2430
    dunlap837
    2018QSDCLBSR5
    I meant the speed units in the transmission torque maps. They way you worded your answer it sounds like you may have been talking about the shift schedule maps, so I am just clarifying. Thanks
    shotgunbilly420 likes this.
  11. Mar 14, 2021 at 6:15 AM
    #2431
    Mooseditty17
    AJ
    WI
    Same
    dunlap837[QUOTED] likes this.
  12. Mar 14, 2021 at 7:06 AM
    #2432
    PRO_Taco
    Ontario Canada
    2025 TRD PRO
  13. Mar 14, 2021 at 7:08 AM
    #2433
    uploadadventure
    uploadadventure [OP] It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Oh
    And if anyone is curious.
    Camry acceleration and airload maps feel great in the truck. But shifting with the Camry maps is not an option. I’ve never had the truck shift so hard at WOT. I thought it was coming apart haha.
    Low speed it drives really nice and knock stays under -4
    dunlap837, Mooseditty17 and Chadr7858 like this.
  14. Mar 14, 2021 at 7:10 AM
    #2434
    shotgunbilly420
    ok yeah hopefully these great guys on here can make some magic happen for running 33 inch tires I know they can it just takes time
  15. Mar 14, 2021 at 7:16 AM
    #2435
    shotgunbilly420
    all i gotta say is im bringing all these tunes from washington state to pikes peak colorado now that will be the real test im leaving april 9th and hopefully i can pick the ultimate to for the trip
    uploadadventure[OP] likes this.
  16. Mar 14, 2021 at 7:19 AM
    #2436
    PRO_Taco
    Ontario Canada
    2025 TRD PRO
    You should give the tune a try as @Mooseditty17 has it set up for 33" tires
    KOTOC79 and Mooseditty17 like this.
  17. Mar 14, 2021 at 7:21 AM
    #2437
    shotgunbilly420
    i will today with spring forward still dark here in washington i told him i was gonna give it a rip I already put a full tank of the best shit in the taco just trying to figure out where im gonna cruise to
    PRO_Taco likes this.
  18. Mar 14, 2021 at 7:27 AM
    #2438
    Vlady
    Issy, WA
    I saw early 5-6 upshifting while merging and relaxing the accelerator to make a room. Then it has to downshift back to 5th to get the acceleratoration going.
    1-2 upshifting was perfect, 2-3 could be a tad longer.
    4-5 upshift issue -loads >70% and speed above 65. We have these long inclines which I can make in 5th with 2400 rpms if I start at the base.
    But If I merge in the middle of the incline, I'm in 4th spinning 3000+ to the end of the incline and a bit moreafter that until it shifts on its own. Changing speed in 2D did not help. Messing with torque tables so far produced 0 effect.
    I'll consider this tune, but shifting needs some refining. I'm sure some can be adjusted by moving speeds, but torque tables may need some review.
    Thanks.
    Mooseditty17[QUOTED] likes this.
  19. Mar 14, 2021 at 7:29 AM
    #2439
    shotgunbilly420
    see reviews like this make me wanna wait till further refining .
  20. Mar 14, 2021 at 7:30 AM
    #2440
    Mooseditty17
    AJ
    WI
    Run my Ultimate_Daily. I think you're gonna like it. Setup for 33s. Last tune on my signature. Please provide feedback.
    FCL30 likes this.
