VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Aug 4, 2021 at 12:29 PM
    #3281
    Kevinpd325
    Kevinpd325 Well-Known Member
    Kevin
    San Diego
    2017 Tacoma TRD Sport 4x4
    Racks/Storage • Prinsu Cabrack w/ load panels • Leitner Designs ACS • Leitner Designs cargo pods (x2) • Leitner Designs accessory mounts (x4) • Leitner Designs Hi-lift mount • Rotopax mounts (x6) • Harbor freight roof mounted rifle case • FWP Fab bed rail shovel and axe mounts (modified for Leitner ACS) • FWP Fab bed corner mounts (modified for Leitner ACS & air fittings) Wheels/Tires • BFG 285/70 R17 KM3 • Pro Comp 61 series Cognos 17x9 wheels Electrical/Power • Genesis Offroad dual battery system • Odyssey group 34 AGM batteries • Renogy 100w solar panel w/ Voyager charge controller • Renogy 3000w pure sine power inverter • sPod4x4 BantamX • Warn winch isolator solenoid • Powertray x2 (right side modified for solar charger) • DC Power Engineering 270A alternator Engine/Performance • IS350 Custom tune • Revolution gears (5.29 ratio) • Eaton E-lockers (front & rear) • OME carrier bearing drop • Custom rear differential breather • K&N drop-in air filter • Dobinson snorkle • AC drain line mod • Start-X remote start • Redline tuning hood struts Exterior • Meso Customs Gashole • TRD Pro grille w/ LED lights • Pop & lock tailgate lock actuator • Anytime Backup Camera (modified for 2nd rear camera) • AVS in-channel weather guards • Expedition Essentials bedside compressor mount • Custom CMC & pinch weld mod • OEM spare tire well modified to fit 285/70 R17 • Goat armor (arachnid black) • Leitner Designs bed stiffeners • Black raised tailgate letters • Bed stickers removed • Debadged 100% • Herculiner bed liner • Mountain Hatch tailgate insert • Modified right side bed storage compartment for water and power connections • Vinyl wrapped hood & roof • Tacoma Twins Prinsu grab handles & Prinsu accents Interior • Meso Customs lower switch panel • Meso Customs interior chrome delete • Meso Customs extended fuse panel cover • Meso Customs overhead 3 switch panel • Relocated center 12vdc outlet • Dual USB outlet mounted in overhead console • Blue Sea dual USB outlet mounted on rear of lower console • Expedition Essentials 3TPAM w/ Blue Sea rapid charger • Doc Loco Molle rear wall panel • 67 Designs ball mounts • 67 Designs carbon fiber arms • 67 Designs universal device holder • 67 Designs sPod touchscreen mount • Ram Mounts Tab-tite iPad holder • ch4x4 cubby switch mount (water pump, winch power & air compressor switches) • Interior panels painted American flag pattern • Tuff skins glovebox letters • GPCA headrest grab handles • desert.does.it seat jackers Lighting • Caliraised LED dual function 40” light bar • Caliraised LED ditch light brackets & side shooters • Caliraised LED amber chase lights • SpartanX Customs stealth scoop light w/ Nitevision function • SDHQ Dual hidden light bar mount • Extreme LED 30" dual function light bar (x2) • Auxbeam 6x2 amber LED light pods (scene lights) • Opt7 Quantum rock lights • LED interior lighting upgrade • SpartanX Customs tricolor LED headlights & fog lights • yodaTEQ underhood LED lights • Meso Customs V2 Dome light • Meso Customs total tail lights Comms • Uniden Bearcat CB radio (mounted in center console) • Anytone AT878UV UHF/VHF radio • Rago antenna mount Armor • SSO slimline bumper w/ stage 2 • RCI sliders Suspension • Icon Vehicle Dynamics Stage 4 • Icon Vehicle Dynamics tubular UCA w/ delta joint • Icon Vehicle Dynamics RXT leaf springs • Overland Custom Designs swaybar disconnects Recovery • Smittybuilt XRC 9500 w/ synthetic cable (rewired for wireless remote) • Factor55 flatlink • 40” Hi-lift jack w/ Jack Mate • Rototrax • Vault hitch shackle block • Gear America recovery kit Audio • Kicker KS series speakers • Kicker CS dome tweeters. • Kicker 10” powered subwoofer • Subaru Kicker tweeters • Kicker Key 180.4 plug and play amplifier • Mat66 sound deadening (whole interior) Accessories • ARB twin compressor • ARB 35L fridge/freezer • Expedition Essentials propane mount w/ 11 lb tank • Outer Limit Supply first aid kit w/ magnetic mount • Rotopax Gen2 2gal fuel & water cans • Fuelpax 3.5gal cans • Quick release fire extinguisher mounts x2 • Fire extinguisher x2 (5lb & 1lb) • Seaflo series 33 water washdown pump • Custom ABS 5 gallon water tank • Roam Vagabond XL Rooftop Tent • OVS Nomad 270⁰ awning
    If you haven't seen the Facebook post, they are behind on orders and tickets because of a covid related issue.
  2. Aug 4, 2021 at 12:41 PM
    #3282
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Valley runner is a daily driver tune balanced for performance and economy
    C41n likes this.
  3. Aug 4, 2021 at 2:28 PM
    #3283
    calzonical
    calzonical Without the 2nd, there is no 1st.
    2018 Taco TRD OR DCSB A/T
    Matt usually responds within 3 business days.
  4. Aug 4, 2021 at 3:12 PM
    #3284
    STRRAYNGE
    STRRAYNGE Member
    2020 TRD Offroad
    Yeah. They are just really behind right now. Ambushed with tons of new orders, more than they've ever had, as well as covid crap, but it's fine. My first tune pack took 6 days, so we will see on this one. No biggie though, I can wait.
  5. Sep 24, 2021 at 5:51 PM
    #3285
    Team Scream
    Team Scream Well-Known Member
    Los Angeles Kali
    2018 TRD DCOR Quicksand 4x4
    Old Man $538.00 Sound System Upgrade w/Kicker DS in the doors, and a Cerwin Vega VPAS10 powered (10") sub under the drivers seat.
    Class Action Lawsuit
    Chadr7858[QUOTED] and VB25 like this.
  6. Oct 13, 2021 at 12:17 AM
    #3286
    Alfamoua
    Alfamoua Well-Known Member
    17tacoOR
    Anyone using Microsoft surface pro? My MacBook got busted and the new Mac no longer supported Booy camp.
    Bastek likes this.
  7. Oct 13, 2021 at 12:44 AM
    #3287
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    I do. It is a few years old but works fine
  8. Oct 13, 2021 at 1:41 AM
    #3288
    Sierra Trail Pro
    Sierra Trail Pro The more I play with it, the Bigger it gets!
    Kelly
    Cameron Park, CA
    2020 TRD Pro, Magnetic Grey Metallic
    Upgraded REM Polished 5.29 Revolution Gears Dobinsons 2.5 MRA/MMR adjustable remote reservoir front coilovers w/732lb springs, 35x12.5 BFG KM3 MTA tires on Moto Metal 16" wheels, incl. full size spare Bushmaster bolt on wheel well flares CaliLED full cab length DOM Steel Rock Sliders w/kickouts, Total Chaos welded spindle gussets, & LCA Cam Tab Gussets, Welded "Runnin 4 Tacos" Cab Mount Relocation Bracket, C4 Fabrication front steel hybrid bumper incl. heavy duty steel bumper support add-on's, C4 Fab Rear overland high rise steel bumper w/steel rear qtr panel wrap armor and side tube upgrades, 12k Smittybilt XRC Pro Comp Winch w/Factor 55 Flatlink Expert shackle mount assembly, Dobinsons heavy duty rear leaf spring pack, Timbren Off Road Racing bump stops (F&R), Fox 2.5 TRD Pro OEM rear monotube shocks, OEM Factory TRD Pro front aluminum skid RCI Steel skid plates (tucked in to factory engine skid)@ transmission, transfer case, lower A arms, and rear diff; CBI steel gas tank skid, ARB Twin Compressor in an M.O.R.E. engine bay mount, ARB Front Air Locker w/ Stainless Steel Air Lines Diode Dynamics 30" LED light bar @front bumper, RIGID front fog lights tied into factory wiring harness, Odyssey Group 31 AGM battery in a CBI Steel battery tray, Decked Slide-Out lockable Bed Drawer System, Yaesu FTM-400XDR HAM Radio (c/s:K6TOY), FreeSpirit Recreation "Evolution" Aluminum Hard Shell RTT w/Accessory Rails X2, FreeSpirit Recreation 270 Degree Swing-Out Self Supporting Awning w/Tent Mount Brackets, Cab Rack Mounted shower/changing tent, CBI corner to corner Steel Full Bed Rack, Prinsu Cab Rack w/extra rails, UpTop Overland upTAKE Snorkel (Functional & self draining), iPOD Bantam X touch screen switch panel control module, Dometic CFX3 95DZ Dual Zone Electric Refrigerator/Freezer w/dedicated electrical circuit & outlet, Dometic Refrigerator Slider Bed Mount, (4) 4 Gal Roto Pax Gas Cans w/locking Bed Rack Mount, MaxTrax Extreme Recovery Boards w/locking bed rack mount, Valley Runner custom ECU tune, TRD Advanced Cold Air Intake, Escort Radar Detector, hard wired w/RVM mount ALL K&N cleanable filter media installed, Only use Mobile One Full Synthetic Oil, changed every 5K miles, All Major Mods Professionally Installed
    You can run Windows 11 through Parallels Desktop 17 on Apple silicon Macs... It is limited to using ARM-based apps right now, although supposedly Microsoft is working on an ARM emulator to run x86-based Windows apps in the ARM version of Windows 11
  9. Oct 13, 2021 at 5:06 AM
    #3289
    Stoked4
    Stoked4 Well-Known Member
    2017 trd sport DCLB (OVtuned)
    Posted this in the other vf tuner thread also
    does anyone know how (hack)to get the original flash tool that’s registered to one particular computer onto a new computer?
  10. Oct 13, 2021 at 5:43 AM
    #3290
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    You'd have to talk to Mat because that uses your PC's system ID rather than how it now goes off of your Master Key with VFTuner
  11. Oct 13, 2021 at 5:48 AM
    #3291
    Stoked4
    not sure he’d even give it a thought seeing that the new software is out
    But I’ll give it a go
  12. Oct 13, 2021 at 6:02 AM
    #3292
    mZiggy
    mZiggy Honey badger
    Marc
    Since you have older software, I'm assuming you are either an original dongle user or "dong-less" lol
    In the former instance, you can upgrade to VF for free in exchange for sending your dongle back to him (black or purple device). In the latter, the upgrade price is $79.
    This is pretty much if you want to be able to edit your own tunes
  13. Oct 13, 2021 at 6:05 AM
    #3293
    Kevinpd325
    Kevin
    San Diego
    I use a Surface Go 2. Works well. Have to use a USB C adapter, but it works.
  14. Oct 13, 2021 at 6:17 AM
    #3294
    Shellshock
    Iowa
    Kevinpd325[QUOTED] likes this.
  15. Oct 13, 2021 at 6:18 AM
    #3295
    Stoked4
    I already upgraded traded in my dongle but I’ve gotten into a few situations where I was using the new software and the truck wouldn’t start and the only way to get it back onto a tune was to use the old software I had loaded in my original computer. I’d like to have only one computer
  16. Oct 13, 2021 at 9:59 AM
    #3296
    Kevinpd325
    Kevin
    San Diego
  17. Oct 13, 2021 at 10:29 AM
    #3297
    Shellshock
    Iowa
    If there are issues you are encountering with the new software, you should message that to zendesk. Support@ovtune.zendesk.com
    The old software is no longer supported.
    Kevinpd325 likes this.
  18. Oct 13, 2021 at 1:25 PM
    #3298
    Stoked4
    ok
    In the past instance I would have been screwed if I didn’t have the old program and had to rely on waiting to hear back from zendesk seeing that I was at my fathers house and he’d be without a truck til the issue was fixed. Call it an in case of emergency plan
  19. Oct 13, 2021 at 1:52 PM
    #3299
    Shellshock
    Iowa
    With the new software, as long as you’ve got your master key, you *should* be fine to reinstall, update, whatever
    I’m not aware of any issues with the current flash utility.
  20. Oct 13, 2021 at 2:38 PM
    #3300
    Stoked4
    I’m not sure what happened but in the middle of the tune being installed it stopped and then the truck wouldn’t start and it did that every tune I tried to put in the truck with VF tuner. I’ve been tried the old program that I still had installed and was able to get the tune on the truck so that it would start, then redid the VF Tuner install and it worked
