VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Oct 13, 2021 at 2:57 PM
    #3301
    Bastek
    Bastek Average Member
    Seb
    SI NY
    '17 OR dcsb
    KDMaxP10, plastidip
    I'm using Surface Pro without any issues. Works just fine for me.
  2. Dec 19, 2021 at 4:35 PM
    #3302
    LongDistanceTaco
    LongDistanceTaco Well-Known Member
    Geoff
    California
    Is there a trick to converting a tune from one ECU ID to another? I started to copy and paste values and realized that maybe I should ask before I subjected myself to voluntary torture.
  3. Dec 19, 2021 at 4:40 PM
    #3303
    mZiggy
    mZiggy Honey badger
    Marc
    2020 MGM Tundra SR5; 2020 4R TRD Pro; 2008 4R SR5 v8
    Yes, careful attention to detail for starters.
  4. Dec 19, 2021 at 4:56 PM
    #3304
    LongDistanceTaco
    Geoff
    California
    I figured as much. Time to get to work...
  5. Dec 19, 2021 at 5:45 PM
    #3305
    DAS Taco
    DAS Taco Well-Known Member
    DAS
    2017 TRD Offroad
    That's why I stay with OEM Tune!, I mean factory!
  6. Dec 19, 2021 at 7:41 PM
    #3306
    Team Scream
    Team Scream Well-Known Member
    Los Angeles Kali
    2018 TRD DCOR Quicksand 4x4
    Old Man $538.00 Sound System Upgrade w/Kicker DS in the doors, and a Cerwin Vega VPAS10 powered (10") sub under the drivers seat.
    Id like to know the answer for this as well.
  7. Dec 19, 2021 at 8:26 PM
    #3307
    LongDistanceTaco
    Geoff
    California
    So what I did (and somebody correct me if this is wrong) take a stock file of the same ECU ID and the modified file, compared bins. The made a long word doc of all the bolded categories. The comparison function pulls a lot of false negatives that say there are differences but when you look there aren't. I'm now thinning out what changes actually do exist on the word doc, so I can much more quickly copy values over to a different ECU ID file.
    Team Scream[QUOTED] likes this.
  8. Dec 19, 2021 at 10:49 PM
    #3308
    LongDistanceTaco
    Geoff
    California
    No idea how the axis got messed up like this, but anyone have an idea on how to fix it and delete axis values?
  9. Dec 20, 2021 at 2:00 AM
    #3309
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Some maps do look like that, I've stumbled upon them before. If it's truly screwed up, you can always open a known good file and copy the values back. I think 1.5.0 added a feature to undo, but have yet to test it.
  10. Dec 21, 2021 at 6:13 AM
    #3310
    Stoked4
    Stoked4 Well-Known Member
    2017 trd sport DCLB (OVtuned)
    I’d have to sell the truck if i stayed on the factory tune
    It was total garbage
  11. Dec 26, 2021 at 5:23 AM
    #3311
    Stoked4
    Anyone have the VF tuner app stop responding after trying to reset the third learning value?
    I can reset the first two but by the time I get to the third the app stopped responding I have to close it open it and reset the third one
  12. Dec 26, 2021 at 7:26 AM
    #3312
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Can you show a screenshot of what you're selecting? I only know of 2 resets, ECU and TCU. The 3rd "reset" is DTC's, and that shouldn't cause any hangups within VF.
  13. Dec 26, 2021 at 7:45 AM
    #3313
    Stoked4
    Yea that’s the third. It doesn’t matter what order I go in, it seems when I reset the third from that list I’ll get the “not responding” next to vf tuner
  14. Dec 26, 2021 at 7:47 AM
    #3314
    mZiggy
    mZiggy Honey badger
    Marc
    like, infinitely?
    vf1.5 is quite bloated now. Even with 1.4.4 I'd get the spinning wheel. I usually just click on the screen somewhere to prompt the partial graying out while it does that and let it figure out its life. And I use a barely capable laptop that was originally only intended to run the OG OVT flash tool. It even happens on my gaming PC from time to time when saving files.
  15. Dec 26, 2021 at 8:26 AM
    #3315
    Stoked4
    Ok
    Wanted to see if anyone else has had a similar experience
  16. Jan 4, 2022 at 10:21 PM
    #3316
    Heywaiter
    Heywaiter Member
    San Diego
    2016 SSM TRD OR
    Toyo MT 295/70/17 on Method 701 17x8.5, Total Chaos UCA's Fox 2.5 CO's Front, ICON RXT Leaf Pack w/ Fox Adjustable 2.0's rear, VF Tune, MBRP XP CBE.
    Just upgraded to vf1.5 from 1.4.4 and now I can only open the program when the laptop is plugged into the OBDII port with the truck on. Every time I try it tells me to plug in the cable and then shuts down :(.
    Pretty sure this isn't a new feature, anyone else running into this?
  17. Jan 4, 2022 at 10:35 PM
    #3317
    TWTaco
    TWTaco Well-Known Member
    Dave
    Yes that is a new feature.
    wahoobie likes this.
  18. Jan 4, 2022 at 10:49 PM
    #3318
    Heywaiter
    Heywaiter Member
    San Diego
    2016 SSM TRD OR
    Odd, so I either need a 45ft OBD cable or I have to sit in the truck to work on a tune mod. I guess it's a security thing but it's already tied to my VIN so not sure why the extra layer?
  19. Jan 5, 2022 at 2:18 AM
    #3319
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    You only need to plug the Tactrix into the computer, you do not need it plugged into your vehicle.
  20. Jan 5, 2022 at 3:07 AM
    #3320
    LongDistanceTaco
    Geoff
    California
    Like Ktbell said, just plug it in to your computer
