VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Jan 28, 2021 at 9:36 PM
    #1301
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    @OVTune, you're doing some damn fine work for us. It's easy for us to want to lament about what's missing and overlooking all that we have, myself included. I don't know much about engines but I'm able to pickup on forum help (here and yours) and combine that with your program and get results. I ain't trying to kiss ass but you don't get enough appreciation. I'm assuming you've had to reverse engineer at a very, very basic level of programming (I remember you mentioning Assembly) and a little bit of my brain died inside when I heard that. I do not envy you but wish you continued success as you continue to map this frontier for us.
    Your gun analogy is a good point and you made me realize that I need to do even more learning. Already had, and now I know that a torque converter is a thing, but I need to keep learning. That said, the UI/UX of the program could use some work. Undo/Redo, more thorough info for table/field names, floating point comparison issues, consistent and accurate table naming conventions, and a more consistent adoption of Windows features (mostly I mean Ctrl+W to be able to close the active window. This would be money for when you're doing comparisons and want to close all the compared table windows). I know you've got some of this on your radar already. I've seen a few of those mentioned in forums but wanted to throw the rest out there.
    wahoobie likes this.
  2. Jan 29, 2021 at 4:42 AM
    #1302
    OVTune
    OVTune Well-Known Member
    OVTune
    89 percent is the physical limit of the throttle.
    Think of it like degrees. At 90 degrees the throttle is perfectly horizontal.
    It's limited to 89 so there isn't any chance the spring that snaps it closed doesn't bind.
    Thank you, we are taking all feedback and implementing things based offof it for sure.
    CTRL+W I can ask my dev about for sure.
  3. Jan 29, 2021 at 4:46 AM
    #1303
    OVTune
    OVTune
    When we release 1.3.0
    We have taken all feedback, info, etc over the last several weeks and it's all going to be in 1.3.0
  4. Jan 29, 2021 at 5:02 AM
    #1304
    wahoobie
    wahoobie TidewaterCustoms.com
    chris
    Suffolk, VA
    2016 DCLB 4x4 SR5ish
    VA/Remote Elite Performance Tuning Services
    Thank you, as a keyboard jockey this would be a significant ease of use improvement! Great suggestion @CAG Gonzo !!
  5. Jan 29, 2021 at 5:31 AM
    #1305
    McGio
    McGio Well-Known Member
    Gio
    2018 Blazing Blue Tacoma Lg Bd
    None so far
    No the same.
  6. Jan 29, 2021 at 5:39 AM
    #1306
    McGio
    Gio
    None so far
    WTF is going on in this forum?!?! I’m over here trying to get OVTuned and all I’m hearing about is a guy named Matt. I see frustrated replies from what appears to be a rep for OVTune and quite frankly the company sounds like it’s days from being nonexistent. Should I even purchase this product anymore. WHO THE F%^k IS MATT?
  7. Jan 29, 2021 at 5:45 AM
    #1307
    OVTune
    OVTune
    Mat, me, is the owner of OVTUNE and VF Tuner.
    we are not days from being non existent. We are just fighting a bit of piracy. It will get cleared up and taken care of. There are just some things being delayed because of it (software training materials, some patches, etc).
  8. Jan 29, 2021 at 5:46 AM
    #1308
    uploadadventure
    uploadadventure [OP] It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    Good response.
    ihatemytruck likes this.
  9. Jan 29, 2021 at 6:17 AM
    #1309
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    The throttle position sensor is only 32 @accelerator 51.
    Any ideas how to close the gap between these 2 and the plate?
    And I did look at Help button on all airload tables.....
  10. Jan 29, 2021 at 6:46 AM
    #1310
    TacoSupremo19
    TacoSupremo19 Well-Known Member
    NJ
    2019 Black Tacoma TRD SPort DCSB
    Brushed Copper Blaze 10 Rims | 265 70 17 Toyo Open Country A/T III tires | Bilstein 5100 w/ Eibach Coils 2.5" lift | Blackhawk UCAs | ICON Rear 3 AAL |TRD Skid Plate | TRD CAI | OEM Rear Bed Lighting | OEM rear Tailgate lock | RC Bed Molle Racks | Custom Blacked out OEM LED Headlights | MESO V4 Mirror Turnsignals | MESO Interior trim blackout | TG DMM dash mount | TRD Shift Knob | OEM SR5 interior door handles | Upgraded Stereo including Alpine 700W Amp Alpine Type R Components & Hertz speakers 12" Sub | Custom Clazzio Seat covers | Mobtown Sliders | Front Camera
    :facepalm::deadhorse:
  11. Jan 29, 2021 at 7:09 AM
    #1311
    OVTune
    OVTune
    Check that the 2D throttle to accelerator angle tables aren't limiting you. That's first place to check.
    Second is the 3D 32d torque split throttle table.
    Also remember that part of throttle control is *code* not tables. Toyota's intelligent throttle control.
    Having exact 1:1 is not a good idea in my opinion.
  12. Jan 29, 2021 at 7:32 AM
    #1312
    AtomicRyan
    AtomicRyan Well-Known Member
    Interesting update on my Mild + Wild @Mooseditty17 tune installed by @DownhillDragon
    Truck is a 2021 TRD Off Road with AT. It's all stock other than a set of 16x7.5" wheels and 265/75/16 Duratracs. No weight has been aded. Before the tune, I averaged 19.1mpg on three or four tanks.
    After the tune, I got all of the great benefits with two growingly annoying side effects:
    1. The truck is lazy to upshift once cruise speed is met.
    2. Gas mileage over five or six tanks has degraded to 15.0 mpg if I take it easy on the throttle and can be as bad as around 13.8 or so if I have fun.
    Anyway, I stopped for gas a couple of days ago and all that was available was 93-octane. I filled up curious how it would do on higher octane fuel. I've now gone through that tank and while the lazy upshifting is still there, my gas mileage improved to 17.6 mpg over the tank.... same kind of driving and no other changes...
    I'm considering going back to stock. Even with the tune, it's not like the thing is fast... And I never expected my Tacoma to be a hot rod... So the fuel economy is hard to justify... The only thing is, I hate the way the stock tuned transmission handles itself on the highway...
  13. Jan 29, 2021 at 7:42 AM
    #1313
    Vlady
    Issy, WA
    I'm not expecting 1:1. I just want to see if i can a get a bit more opening. It seems I have a % of load to work with in my specific conditions
    Are you referring to airload Control and Expected?
  14. Jan 29, 2021 at 7:43 AM
    #1314
    wahoobie
    chris
    Suffolk, VA
    Wow, that's a big hit. I cannot imagine how I would have to drive to see <16mpg but every truck is different. I know my mpg took a hit with cold and perhaps winter blend(?) but I am still 18+. Is that wheel/tire setup a Fred Flintstones replica? After running my own tune with influences certainly from M+W I would not expect it so low after running a few tanks full. Anyone else have that MPG shocker?
  15. Jan 29, 2021 at 8:03 AM
    #1315
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    You can always make adjustments to the tip in, Airload tables for economy, and shift points so it's not holding too long before an upshift.
  16. Jan 29, 2021 at 8:07 AM
    #1316
    Mooseditty17
    AJ
    WI
    I get as low as 13 on some trips, but I'm driving like an ass. My commute to work is 70% hwy, and I go through a couple of towns. 18+ every time. 33s, 3" lift and a steel front bumper. 87 octane.
    TWTaco likes this.
  17. Jan 29, 2021 at 8:19 AM
    #1317
    OVTune
    OVTune
    Don't forget winter time MPG always goesdown
    johntoyota, Mooseditty17 and wahoobie like this.
  18. Jan 29, 2021 at 9:10 AM
    #1318
    AtomicRyan
    @DownhillDragon - is this something we could pull off? Or is there another tune possibly that might work better for me?
    @Mooseditty17 Would love to get you involved.
    Mooseditty17[QUOTED] likes this.
  19. Jan 29, 2021 at 9:27 AM
    #1319
    BortisYeltzen
    BortisYeltzen Well-Known Member
    Barrett
    Salt Lake City, UT
    2017 MGM TRD Off-road DCLB
    OTT Tuned, Bilstein TRD Pro lift, ECGS bushing, Heated Clazzio's, RCI SKID TRILOGY, BAMF sliders, ARE V-Series shell, RokBlokz flaps, more to come
    wahoobie and MGMSangTaco like this.
  20. Jan 29, 2021 at 9:41 AM
    #1320
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    I posted this earlier and no one responded ... He makes it looks like A) he works for OvTune/VfTune and B) like you’re purchasing the software... Pretty fishy and seems deceitful. I also heard people tried to ask questions about stuff and he basically had no clue how to answer which is scary. Plus how is he selling 4runner tunes? I thought they were in dev?
    The motto all along with vf has been we can share members edited tunes which makes it way more fun IMO which was part of the reason I got it in the first place, plus the ability to make some $ back on the investment through buying credits and unlocking different ECU’s to tweak. But taking the logo and selling it as your own seems like the definition of piracy.
    There’s also a dude on FB with the name of “Chan Chan” who has been using the logo, I think he may have stopped using it though.
