VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Jan 30, 2021 at 4:28 PM
    #1381
    ry18Tac
    ry18Tac Well-Known Member
    North Texas
    2018 Quicksand Tacoma TRD 4x4
    Ovtuned
    I made a similar tune without the VVT adjustments, injection split and Atkinson cycle adjustments. Doesn’t seem to do it anymore. Not sure if it’s one of those adjustments that needs some tweaking in that specific area or the combination of all 3.
  2. Jan 30, 2021 at 4:54 PM
    #1382
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    I mean if I’m being honest a V8 sounds awesome lol. But this is good info thanks I need to tweak mine to accommodate mountain driving here in CO
  3. Jan 30, 2021 at 5:50 PM
    #1383
    CAG Gonzo
    CAG Gonzo Ascendant Spaghetti
    2018 OR DCLB BarRed
    Can you elaborate on this? Wasn't the 10th map of that category being talked about on here? Seemed to produce favorable results.
  4. Jan 30, 2021 at 6:16 PM
    #1384
    TFly
    TFly Well-Known Member
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    Tried this out tonight, but the tip-in is way too sensitive for me. My wife drives my truck on occasion, and touchy tip-in makes her sick, literally. We've got ice and snow coming tomorrow, and it's a definite no-no for that.
    What steps do I need to take to reduce it? I'm really a fan of the stock THX tip in that Mat provided for VFT. I've been perusing the forums, but I can't keep up with all of the changes he's is making to the software. Seems that the table structure has changed since the last post I can find about anything related to it.
  5. Jan 30, 2021 at 6:26 PM
    #1385
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Go to throttle limits S tables and reduce numbers in 1st 3 columns for 1st and 2 gear
    BortisYeltzen likes this.
  6. Jan 30, 2021 at 6:28 PM
    #1386
    TFly
    Travis
    Richmond, VA
    2018 Cement DCSB OR
    S tables? Even if I'm not using S mode?
    Forgive me. This is the first time I've taken a dive into shifting and throttle tables.
  7. Jan 30, 2021 at 6:42 PM
    #1387
    Vlady
    Issy, WA
    Welcome to the club.
  8. Jan 30, 2021 at 6:44 PM
    #1388
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    Not sure if it's in here, but is there a download or link for the stock tunes on all ECU's? Incase you know I F up and want to go back to stock to start fresh.
  9. Jan 30, 2021 at 6:45 PM
    #1389
    Chadr7858
    Chadr7858 Well-Known Member
    Chad
    Colorado
    19 TRD SHIT BOX, 02 BEST GEN
    All the mods; all the problems
    Lmao
  10. Jan 30, 2021 at 6:48 PM
    #1390
    N5J_Taco
    N5J_Taco Well-Known Member
    Plug your nose and Jump in!! This may help....
    vFtuner walkthrough basics.mp4 - Google Drive
  11. Jan 30, 2021 at 7:02 PM
    #1391
    DownhillDragon
    DownhillDragon Well-Known Member
    Brody
    Austin, TX
    2017 Tacoma TRD Pro AT Cement - POWERTHIRST v2.4 Tuned
    POWERTHIRST Tuned - My Custom OVTune SSO Slimline Bumper with Stage 2 Kit + BajaDesigns 20" Light bar with Amber Backlight + Smittybilt Winch x2o 10,000lb Synthetic CaliRaisedLED Step Edition Rock Sliders SUSPENSION FRONT A.D.S. - 2.5 Adjustable Dampening Remote Resi Fronts Dirt King Upper Control Arms SUSPENSION REAR A.D.S - 2.5 Smoothie Piggy Back "Rear" Shock With Compression Adjuster Deaver Leaf Pack Cab Mount Relocate by Triple-C Chop Shop, Lago Vista, TX Nitro Gear 5.29 BFG KM3 35x12.5x17 Fuel Rebel6 17" Wheels + Full-size Spare + Rhino-Rack Spare Wheel Strap 4x Rigid Cube Ditch Lights + Cali Raised Ditch Light Hood Mount Brackets + Cali Raised Ditch Light Extension Brackets + 3x Cali Raised Switches + Light Switch Mount Bracket Snugtop Camper Shell with Carpeted Ceiling and Mounting Tracks Prinsu Top Rack and Cab Rack Hi-lift Jack + Hi-lift Jack Mount on roof DEFEND INDUST Recovery Traction Tracks (knockoff Maxtrax) Trimax ST30 Trimaflex Spare Tire Cable Lock (Round Key) 36" x 12mm K&N Intake Canvas 270 RV Awning Rooftop Sun Shelter + Prinsu Awning Brackets Fire Extinguisher w/mount Campbell Hausfeld FP209499AV - 3 Gallon Air Compressor
    Check your vF Tuner Install Folder. All the Stock .vft files are in there, for more Toyota models than you'll ever want to F with.
  12. Jan 30, 2021 at 7:03 PM
    #1392
    trdquoc
    "Q"
    Well dear god I'm an idiot. Thank you!
  13. Jan 30, 2021 at 7:15 PM
    #1393
    DownhillDragon
    Brody
    Austin, TX
    We're all idiots, don't you worry.
    TacoManOne, MGMSangTaco and N5J_Taco like this.
  14. Jan 30, 2021 at 11:12 PM
    #1394
    Tharris242
    Tharris242 Technically
    Houston, TX
    2017 TRDOR DCSB 4X4 A/T FP TO BL
    Solid Fold 2.0, Air Dam
    There are the 17 maps; then, there is one "...for sport mode".
    Don't copy the sport mode map to the other 17.
    I tried this because OV said "build yourself a base 3D torque map and set all of them the same" (and because I was trying to fix/diagnose another issue).
    CAG Gonzo[QUOTED] likes this.
  15. Jan 30, 2021 at 11:44 PM
    #1395
    CAG Gonzo
    2018 OR DCLB BarRed
    Did things go boom?
  16. Jan 31, 2021 at 1:49 AM
    #1396
    Tharris242
    Houston, TX
    No, it just shifted about 10 times as much as necessary.
    Had to select S mode to get where I was going... ironic.
    (Don't know if that would have worked without gear lock set up.)
  17. Jan 31, 2021 at 7:08 AM
    #1397
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Has anyone tried setting them all to match #9? That's what we changed 10 to to try and address some issues... Maybe that's what he was hinting at???
    @ForceOfG
    @PapaRee
  18. Jan 31, 2021 at 7:57 AM
    #1398
    dunlap837
    dunlap837 Well-Known Member
    2018QSDCLBSR5
    Enhanced Skinny Pedal
    I was about to do this, thanks for the warning. What happened?
    Edit: saw you already answered, excessive shifting.
  19. Jan 31, 2021 at 8:13 AM
    #1399
    OVTune
    OVTune Well-Known Member
    OVTune
    Look at each table and separate by how similar they are to eachother
    Combine these by like-ness
    This should leave you with 4 variants.
    You can then compare areas of each 4, combining and smoothing into 1
    (except Sport mode)
    it should result in something *similar* to this.
    But you'll have to retune your 2D up/down tables too.
  20. Jan 31, 2021 at 8:16 AM
    #1400
    OVTune
    OVTune
    example file
    (this is NOT a PDF file it just wont let me attach a VFT) You have to change the extension
    Any future tuning assistance *must* be posted on our forum. I won't be responding here anymore.
    G8R_Taco and Mooseditty17 like this.
