VF tuning collaboration and BS
Discussion in 'Performance and Tuning' started by uploadadventure, Nov 5, 2020.
  1. Feb 19, 2021 at 4:56 PM
    #1841
    OVTune
    OVTune Well-Known Member
    OVTune
    It's not really a problem on the tacoma, but remember vF Tuner is used by many different Toyota owners, some with ECUs that can be bricked.
  2. Feb 19, 2021 at 5:06 PM
    #1842
    Mooseditty17
    Mooseditty17 Seasoned Rookie
    AJ
    WI
    2017 TRD OR : M+W Nexus Tuned
    Tune: Nexus +P Add ons: +3" custom suspension 295/70/18 Yokohama M/T Tires KMC XD Grenade OR wheels KN intake Blackhawk MBRP Exhaust TJM Rock Crawler Bumper Lighting (+10 H.P.)
    Mat, when you mentioned the blending of optimal trans shifting torque tables, should 1:17 all be the same for best results except leave the sport table as is and out of the equation? Is there a table for low 4 specifically that you are aware of?
    Chadr7858 likes this.
  3. Feb 19, 2021 at 5:10 PM
    #1843
    Mooseditty17
    AJ
    WI
    @OVTune
    also curious, have you every dyno'd a tune, ran it for a tank or two and dyno'd it again? would there be any increases or losses due to the learning process?
  4. Feb 19, 2021 at 5:25 PM
    #1844
    Team Scream
    Team Scream Well-Known Member
    Los Angeles Kali
    2018 TRD DCOR Quicksand 4x4
    Old Man $538.00 Sound System Upgrade w/Kicker DS in the doors, and a Cerwin Vega VPAS10 powered (10") sub under the drivers seat.
    Ok I just downloaded and read the new instructions. Looks like good stuff coming as far as functionality. The big question is since this previous version (The one I am on now) already applied the credits toward "unlocking" this ECU-ID (04A61) will I still be able to unlock/credit/activate/whatever the VIN without having to buy new/more credits?
  5. Feb 19, 2021 at 5:30 PM
    #1845
    Team Scream
    Los Angeles Kali
    Going to answer that based on experience, not necessarily with Toyotas.
    The answer to the question is a moving target. It has a lot to do with LKC (learned knock correction) tables, of which I am sure there are some in the Yota..
    When tuners are on the dyno and they flash a variant, most of the learned values are reset by default with the flash, so you flash, do a pull on the dyno and then see where you are at. NONE of the flkc/fbkc tables have settled, so while you might get a dyno "queen" run with high numbers, once the ECU retards timing and adds a bunch of fuel to try and reduce/remove knock, of course it will dyno lower if you do a pull after that has all happened.... ALL of those corrections happen ALL of the time, and they are dependent on weather, fuel quality, density altitude etc... It all factors in, so you should never expect a car to dyno the same from one day/session to the next...
    Hopefully that makes some sense.?.
  6. Feb 19, 2021 at 6:08 PM
    #1846
    OVTune
    OVTune
    Everyone will get 4 extra credits applied to their account to license 1 vehicle.
    ihatemytruck and Mooseditty17 like this.
  7. Feb 20, 2021 at 6:41 AM
    #1847
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Glad you like it.
    PM me, please, if you need or want anything else.
    TWTaco and Kerbouchard![QUOTED] like this.
  8. Feb 21, 2021 at 11:11 AM
    #1848
    skidooboy
    skidooboy titanium plate tester
    central lower mich
    2019 Tacoma Sport KDMax Tuned, Cement
    dd light bars, trd cat back exhaust, KDMax tuned, trd skid plate, 2" lift, sema wheels toyo open country at3 tires.
    I see the new software version link is up on the vf tune site. anyone go for it yet? can we use a "new" (non registered) computer/laptop, or are we still governed by the original unit we used to register ov tune/vf tune? Ski
  9. Feb 21, 2021 at 11:21 AM
    #1849
    N5J_Taco
    N5J_Taco Well-Known Member
    Not yet I did get a message see I had credits added to my account. I'm waiting for some of the more experienced guys go first! :bananadance:
    trdquoc likes this.
  10. Feb 21, 2021 at 8:05 PM
    #1850
    Ak-47
    Ak-47 Member
    Chode
    Austin TX
    2016 Quicksand Tacoma TRD Off-Road
    2" lift + 1" leveling kit + 35" tires + very tiny benis
    Any good tunes for 3.90 and 34" tires?
  11. Feb 21, 2021 at 8:10 PM
    #1851
    trdquoc
    trdquoc Well-Known Member
    "Q"
    2020 Cement DCLB TRD-Offroad
    @PapaRee can take care of you
  12. Feb 22, 2021 at 9:19 AM
    #1852
    whitedlite
    whitedlite Well-Known Member
    USA!
    3RD Gen TRD 4WD
    Maybe I missed it, to return a truck to stock and remove a tune do I reflash a new stock tune?
    If so where can I locate the stock parameters?
  13. Feb 22, 2021 at 9:27 AM
    #1853
    trdquoc
    "Q"
    The stock tunes are in the program folder or vftuner
  14. Feb 22, 2021 at 9:38 AM
    #1854
    whitedlite
    USA!
    3RD Gen TRD 4WD
    well call me a big dummy because I haven't found it.
    Program Folder for OVtune
    My Computer > Windows (C) > Program Files (x86) > OVTuned > ????
    ???? marks are where I'm lost on where to look.
  15. Feb 22, 2021 at 9:44 AM
    #1855
    Shellshock
    Iowa
    C:\program files (x86)\vf tuner\tacoma
    trdquoc likes this.
  16. Feb 22, 2021 at 9:48 AM
    #1856
    whitedlite
    USA!
    3RD Gen TRD 4WD
    Well that explains it, OvTuned and VF tuner, two different folders.
    Thank you,
  17. Feb 22, 2021 at 9:51 AM
    #1857
    Shellshock
    Iowa
    Yeah the folder name has changed like 3-4 times.. its also changed locations a couple times over the years. I think at one point i had a vftuner, ovtuned and vf tuner folder
    ktbell444 and whitedlite[QUOTED] like this.
  18. Feb 22, 2021 at 3:15 PM
    #1858
    boxer38z
    boxer38z Member
    NJ
    2016 Tacoma TRD sport
    can someone explain to me what are those tune files means ? regular stock.vtf , regular stock 4.88 vtf, regular stock 5.29vtf. regular stock thx.vtf. what gear is my stock 16 TRD sport? thank you.
  19. Feb 22, 2021 at 3:18 PM
    #1859
    trdquoc
    "Q"
    Stock tires with different gear ratios.
    Your stock gear ratio is 3.9, which means your file is regular stock... the others are if you have regeared your truck which you probably have not, otherwise you would know :)
  20. Feb 22, 2021 at 3:20 PM
    #1860
    boxer38z
    boxer38z Member
    NJ
    ok thank you. whats the regular stock thx means ?
