VHT Nightshades Cracking
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BLP, Dec 20, 2011.
  1. Dec 20, 2011 at 2:19 PM
    BLP
    BLP [OP] Well-Known Member
    Bryson
    Stem, NC
    06 DCLB 4x4
    Bilstein 5100s front and rear, front set to .85 with ome 885 coil springs, 1.5" aal, nitto trail grapplers 285/75/16, level 8 guardian wheels, delta toolbox painted black, tinted tail lights, black headlights with 6k HIDs, smoked fog lights with 6k HIDs, weathertechs, usa spec pa15 ipod adapter, single in dual out flowmaster 10 series with 3.5" tips and secondary cats removed, 20% tint, coverking neosupreme seat covers, color matched grill.
    Tinted my tail lights with nightshades today and they came out great. However, the 3rd brake light had "cracks" in the paint and it looks really bad. Sprayed another coat and it didn't fill them in. What should I do to remove the tint and get the cracks out?
  2. Dec 20, 2011 at 3:15 PM
    wrxRome
    wrxRome Houston's Swamp Rat
    Brandon
    Covington, LA/Friendswood,TX
    06 SWB 4x4 trd off road
    Rubbing alcohol and scrub away
  3. Dec 20, 2011 at 5:21 PM
    Leer
    Leer Well-Known Member
    Lee
    Hilo / Oahu
    08 Tacoma 4x4
    Sounds like the nightshades is reacting to some residue on the lens, probably wax. You might need to sand the tinit off. If you can get it off with rubbing alcohol then you can try that, but be carefult it doen't ruin the lens.
    Once you get everything off, you need to clean the lens real well, prep-sol would be the best. The sell spray cans of that where you buy paint. If not, clean real well with dish washing detergant, maybe wipe it down with some acetone (quickly) to remove what ever you can, just be careful that what ever you use doesn't ruin the lens!
  4. Dec 20, 2011 at 5:24 PM
    Fiolo
    Fiolo Senior member
    98 Regular cab lifted 4wd
    Lost track many mods ago
    Sand it and redo it
  5. Dec 20, 2011 at 5:25 PM
    TACOMABOSS
    TACOMABOSS Well-Known Member
    96 SR5 4x4
    Bilstein 5100s, Toytec AAL, Deck plate mod, Hella 500ff's, Sportsman Camo seat covers, Total Chaos 1" diff drop, JVC stereo, Painted bumpers and grille, Custom grille insert, HID projectors, Black spray paint
    what did you use to clean the 3rd brake light cover before you sprayed the nightshades on it?
