VIAIR 10007 vs. 20001
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MDBigRed, Aug 21, 2009.
Which one???
Poll closed Aug 26, 2009.
  1. VIAIR 10007
    0 vote(s)
    0.0%
  2. VIAIR 20001
    0 vote(s)
    0.0%
  1. Aug 21, 2009 at 8:03 PM
    MDBigRed
    MDBigRed [OP] Well-Known Member
    Potomac, MD
    '08 TRD Sport 4x4
    Uniden PC78Elite CB, 4' Firestiks, KC reverse/work lights, Mudflaps removed, Gorilla wheel locks, TRD box air intake, MBRP XP series dual exhaust, Wet Okole seat covers, 20% front tints, Pacer tailgate light bar, Uniden Bear Cat PA external speaker, 4.5" RCD Lift w/ extended ICON coilovers, door sill LED running lights, LED alarm scanner light, Scangauge II, Blendmount, Diff breather mod, Whelen hideaway 90watt strobes, Piaa Xtreme white bulbs, VIAIR onboard air, Allpro T-case sheild, TC LCA Skids, Stubbswelding HD-SKO Sliders, Weathertech floor mats, TC UCA's, Allpro SS brakelines, rear ARB locker, 4.56 Yukon gears, BlueSea fuse block, bed rail light bar, Shrockworks bumper, Smittybuilt XRC8 Comp winch, IPF 900's, Piaa 510's, Tekonsha brake controller, Air horn, Pop 'n lock, Alcan Spring leaf packs, JVC KD-AHD 69 head unit, 12voltguy winch controller, Safari Snorkel
    OK so I'm in the market for a good onboard air system. I would like to have a continuous cycle system as it is much faster and more efficient to have one. I would like to get a VIAIR setup as I believe they make great onboard air setups. I am debating between the
    10007 model: $400
    http://www.viaircorp.com/OffRoad/10007.html
    OR
    20001 model: $480
    http://www.viaircorp.com/OffRoad/20001.html
    I would like to use this system for train horns, an air locker, and as a tire inflator unit. Of course I can run some air tools if necessary! I am just wondering if it's really worth the $80 for the nicer model. I'm sorta leaning towards the 10007 model as I think it's plenty of power for what I need. My tires are only 33". Any feedback would be much appreciated :)
  2. Aug 29, 2009 at 12:47 PM
    MDBigRed
    Potomac, MD
    '08 TRD Sport 4x4
    Anybody have suggestions???????
  3. Aug 29, 2009 at 12:52 PM
    j1999t
    j1999t Well-Known Member
    Justin
    Northern Colorado
    traded it in
    links arent working
  4. Aug 29, 2009 at 2:10 PM
    silver07taco
    silver07taco Well-Known Member
    COIL
    Maryland
    13 Tundra RCSB 5.7 4x4,07 Tacoma AC 4.0 4x4
    2013 Tundra RCSB 5.7 4x4, 2007 Tacoma AC 4.0 4x4
    If your planing to run an airhorn, Locker and fill tires and run air tools, Your goin to want to run the 20001 model, If you want max air you should run two tanks.
