Viair 300P question
Discussion in 'Recovery' started by OffroadToy, Sep 30, 2023.
  1. Sep 30, 2023 at 1:28 PM
    OffroadToy
    OffroadToy [OP] old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    After cutting the clamps off the power cord to install larger clamps i'm now at a loss trying to figure out what side of the power cord was pos and what side is neg. :facepalm: Need help confirming if the inline fuse on the cord is on the pos or neg. Thanks
  2. Sep 30, 2023 at 2:45 PM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    Fuse is typically on the (+) side. IIRC, the positive and negative wires have a slightly different shape. I can check on mine later (I cut the wires to permanently mount it).
  3. Sep 30, 2023 at 2:46 PM
    Bishop84
    Bishop84 Well-Known Member
    Inline positive.
    OffroadToy[OP] likes this.
  4. Sep 30, 2023 at 4:22 PM
    OffroadToy
    Thanks, that's what i thought too. What's got me confused is the fuse is on the side that's got ridges... isn't that usually neg? :crazy:
  5. Oct 1, 2023 at 4:26 PM
    OffroadToy
    update: went with your recommendations (in-line fuse and pos jumper cable clamp were both ribbed... negative was smooth) and worked like a champ... the garage is still standing!! I have a good excuse now to updated from the 10 year old brittle yellow air line to the braided black version after it snapped trying to get to the passenger rear... at least it happened at home. :thumbsup: Thanks again!
