VIAIR 400P-Automatic RV compressor: $231
Discussion in 'Deals & Coupons' started by DoorDing, May 6, 2013.
  1. May 6, 2013 at 2:07 AM
    DoorDing
    DoorDing [OP] Intentionally obtuse
    Bodie, CA
    2017 RC Off-Road 3.5WD
    yes
    VIAIR 400P-Automatic RV compressor for $231 on Amazon, with free shipping
    http://www.amazon.com/Viair-40047-A...e=UTF8&qid=1367831210&sr=1-1&keywords=400P-RV
    $20 less than the same compressor with the 400P-A package. I was shopping for a 400P-A (Automatic) and found the RV version for less. The only difference between the two is the RV package has an additional hose and tire chucks.
    If you compare VIAIR's top portables, the 440P and 450P-A may cost more, but they don't offer a clear cut advantage over the 400P-A. The 440P lacks auto shutoff (but has +0.46 cfm over 400 series), and the 450P-A has -0.88 cfm less output than a 400 series (but gains a 100% duty cycle rating). Looking at the specifications, I wonder if the 450 is just a detuned 400 that runs a little slower & cooler, leading to an increased duty cycle. I'm surprised there isn't a 440P-A.
  2. May 9, 2013 at 3:41 PM
    Infra
    Infra Well-Known Member
    Az
    2010 MGM DCSB 4x4 TRD OR 6spd
    CBI Bushmaster 2.0 rear bumper with swing out tire carrier & fold down camp table, CBI Moab 2.0 front bumper, Warn M8000-S, Icon 2.5 RR CDC Extended travel CO's with 700lb springs, Icon 2.5 RR CDC rear shocks, Icon hydro bumps, Total Chaos uniball UCA's, All Pro Expo leafs, U-bolt flip kit, Softopper, diff breather mod, extended rear brake lines, Grillecraft mesh grille, Elusive Elements behind grille light bar with B.A.M.F. LED light bar brackets, okLEDlightbars.com 20" double row LED light bar, Relentless Fabrication hood cb antenna mount, Wilson Silver Load CB antenna, Uniden 520 Pro XL CB radio, Wet okole seat covers, Weather tech floor liners, Weather tech in channel window deflectors, trasharoo spare tire trash bag carrier, Box Rocket 2nd gen bed rack with (2) 2 gallon gas rotopax mounted on drivers side, (2) 2 gallon water rotopax mounted on passenger side, (1) 3 gallon gas rotopax & (1) 2 gallon gas rotopax mounted on CBI swing out, Avid weld on sliders, Mattgecko LED bed light
    Great price for a great compressor!
