Viair 450c vs ARB ckma12 ... help me decide
Discussion in '2nd Gen. Tacomas (2005-2015)' started by sgtpepper, Jan 27, 2013.
  1. Jan 27, 2013 at 7:58 PM
    sgtpepper
    sgtpepper [OP] Active Member
    Trying to decide on the right compressor for an OBA setup.
    I realize these compressors are quite different
    - the ARB pushes more CFMs, but is 50% duty rated
    - the Viair is less flow but 100% duty @ 100psi
    What does that really mean in real life? I need some real-world experience to help make up my mind.
    Both models cost more than I originally planned to spend, but looking down the road I'm ok to spend some extra money up front.
    Some intended uses:
    - horns .. reasonable, ie: bus/ambulance, not train
    - filling tires .. stock on the Taco, 33s on the Jeep
    - lockers .. in the future
    - air tools .. maybe, see below
    - crotch-air .. for those hot summer days, global warming fellas, it's coming..
    Will either of these models push air tools (ie: spin off tire lugs) with any success? with/without tank?
  2. Jan 27, 2013 at 8:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    the Viair wont drive air tools without a tank, and even then, it would only run tool sfor a short time. The ARB will, with the use of an air tank of about 2 gallons, would drive an air wrench for a short time. With its 50% duty cycle of 30 mins run time, 30 mins off time, it would be fine for light duty jobs.
  3. Jan 28, 2013 at 8:16 AM
    barlowrs
    barlowrs Well-Known Member
    Robert
    So Cal
    06 Toyota Tacoma Sport 4x4
    Build Thread: http://www.tacomaworld.com/forum/builds/74926-barlowrs-06-taco-expo-build-thread.html OME Lift, FJ SE Wheels, 255/85 KM2, Allpro Plate Bumper, 8K Winch, Synthetic Line, Yaesu FT-8800R, Custom Sliders Sockmonkey bedside decals, BHLM, base model grille, TRD offroad (black) trim
    Do yourself a favor and get a Puma. Chearper and will run many tools (depending on air demand) strait from the compressor (though a small tank is advised, and guess what, it comes withat a tank haha).
    100% Duty Cycle
    3.4 CFM (3.0 CFM @ 90 psi)
  4. Jan 28, 2013 at 8:21 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    I'm :confused:
  5. Jan 28, 2013 at 8:24 AM
    barlowrs
    Robert
    So Cal
    HAHAHA sorry, do a google search for "12V Puma compressor", you will find LOTS of info (also check in my build for details on my install with mine...about 2 or 3 years later, and she is still going strong.
    Basically it is exactly the same as the extreme air (costs around $600), at a MUCH lower price
  6. Jan 28, 2013 at 9:54 AM
    sgtpepper
    The air tools were kind of an afterthought, not something I would be doing regularly.
    I will add the Puma to my list of contenders, though.
    So the question comes down to A) do I want 100% duty or B) more CFMs? Since I'm not planning to run this continuously, it's starting to look like ARB or Puma. to be decided.
  7. Jan 28, 2013 at 10:21 AM
    sgtpepper
    oh yeah, your build was one of my "inspiration" threads. The Puma thing didn't click for some reason, but now I see.
    Badass truck you have there, by the way! I put an OME lift on my father's Jeep few years back, big fan of their products.
  8. Jan 28, 2013 at 10:29 AM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    ARB.
    I have had the Viair Superduty kit (2 compressors with 2 gallon tank) It was pitiful. The ARB out preforms it by far. The longest I have had the ARB running was to air up my 4 33's from 14psi, 4 37's from about 10psi and 2 more 35's from about 12psi. The ARB never faltered and wanted more.
    Air tools would be a stretch on it though. But, if you ever plan on getting lockers you're already set!
  9. Jan 28, 2013 at 1:22 PM
    barlowrs
    Robert
    So Cal
    The puma is 100% duty cycle as well. So its higher CFM AND 100% ducty cycle. I do run a 3" grinders/cutoff wheel and impact off it, though a large grinder may be a stretch for it and other things that require high flow. With a tank you are good though.
