Vibe after Lift - ECGS Bushing Didn’t Fix It
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ataconamedsylvia, Oct 1, 2020.
  1. Oct 15, 2020 at 10:40 AM
    #61
    Ataconamedsylvia
    Ataconamedsylvia [OP] Active Member
    2019 SR 4x4 V6
    3/2 RC lift. ECGS bushing swap. 1” diff drop. OME carrier drop. Still trying to get rid of the damn 2WD-only pulse vibe.
    Road force balancing tomorrow AM. It’s a shot in the dark, but I’ve wasted more money than that, so far.
  2. Oct 15, 2020 at 11:21 AM
    #62
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    I need to find a shop near me that does RF balancing... it truely does get a more accurate balance on a tire.. used to work at a shop that had one of these Hunter 2000 machines.. it could easily detect out of round rims, bad tires, and correct some wobbles that were hard to find or correct on a regular machine.
    hopefully it solves, or reduces your problem.. hoping I can get this done on my rig soon.. lots of jeep off road guys swear by bead shot.... 6-8oz of beads to correct a 33-35" tire imbalance.. but I am not a fan...
  3. Oct 15, 2020 at 12:22 PM
    #63
    Ataconamedsylvia
    2019 SR 4x4 V6
    If you’ve got a Discount Tire chain store near you, they do it. $20 a wheel.
  4. Oct 15, 2020 at 1:09 PM
    #64
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    I have ione in Rockland, just not sure they do RF... there is a shop in Camden that advertises that they do road force balancing...
  5. Oct 15, 2020 at 2:07 PM
    #65
    Halena Molokai
    Halena Molokai Well-Known Member
    Black 2016 TRD DCSB OR 4x4 MT6
    BFG KO2 265/70/17 Moto Metal 17x 9 -12mm ToyTec Boss 2.0 lift Kit Wet Okole, Ceramic tint 35% Bakflip F1 Flowmaster Exhaust Single in /Dual out with 3"stainless tips DashMat Covercraft Custom windshield shade Tilt Alarm Weatherbeater Mats Diode Dynamic LED upgrade to interior OEM Bed Mat OEM 5" Chrome Side Steps
    Did you install the lift or paid someone? If you did it yourself take them out and see what happens. If you paid someone I can see the resistance to keep trying to minimize expenses. I'm with you on the fact that it goes away in 4HI and that tires and most things can't be it. I've always been a proponent of keeping the stock Rake vs leveling it, I just feel that geometrically it is the way to go. Don't know much about the RC lift but the rear lift blocks should be tapered for sure. Good luck $.02
  6. Oct 15, 2020 at 4:06 PM
    #66
    NotSoQuicksand
    NotSoQuicksand Well-Known Member
    2019 TRD Sport x4
    I was going to mention this, I had brand new Hankook Dynopros I put on myself, Had a death wobble at 50-70 mph Thought it was my wheel spacers on factory rims, did a road force and at 55lbs that was the cause. Warranty out the tires and the next set was just as bad, then went with a Diff brand.... Don't leave the shop with them being more than 25lbs or you will never get rid of it.
  7. Oct 15, 2020 at 4:41 PM
    #67
    Ataconamedsylvia
    2019 SR 4x4 V6
    You may be right. Yeah, I paid for the install—thus the stubborn refusal to stop throwing more money at it, LOL.
  8. Oct 15, 2020 at 4:45 PM
    #68
    Ataconamedsylvia
    2019 SR 4x4 V6
    So, you’re saying yours were overinflated and that was the cause?
  9. Oct 16, 2020 at 6:25 AM
    #69
    Ataconamedsylvia
    2019 SR 4x4 V6
    Update: Tire shop said road force balancing wouldn’t do a damn thing, based on the description of the problem. I’m just taking the lift kit off. The only other thing I can think of to do is pull the spacers and put in longer struts in the front, but that’ll be another $350. I’m out. F this thing.
    TacoBuffet and jmneill like this.
  10. Oct 16, 2020 at 6:30 AM
    #70
    Scott17818
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    sorry bro, could be the lift, and no UCA's? I know approaching 3" lift the tacoma steering seems flat, and can cause alignment vibes/death-wobble. I went with High castor UCA's from JBAoffroad. this puts back some of the steering feel. and return to center.. but I still have these low vibes (I believe to be a combination of tire balance (wieghts got knocked off), or the rear pinion angle, but I have yet to get underneath my truck with an angle finder to check it.
  11. Nov 7, 2020 at 7:39 PM
    #71
    Ataconamedsylvia
    2019 SR 4x4 V6
    OK, boys, looks like I’m in it for the long haul. Gonna leave this damnable lift on it and f’ing figure this bitch out. Any more ideas?
    Lt. Dangle likes this.
  12. Nov 7, 2020 at 7:40 PM
    #72
    Ataconamedsylvia
    2019 SR 4x4 V6
    You really think UCA’s could cause a vibe/noise that disappears in 4WD?
  13. Nov 7, 2020 at 7:46 PM
    #73
    Phil4200
    Phil4200 Well-Known Member
    2018 Tacoma SR5 DC 4x4
    3.5 RC Vertex coil overs, SPC uppers, rear blocks\RC V2 monotubes CVC tune 3.0 mbrp exhaust
    Dude it’s gotta be the bushing trust me
    TacoBuffet likes this.
  14. Nov 8, 2020 at 10:03 AM
    #74
    Birnie
    Birnie New Member
    2020 Tacoma
    2.5 front lift. 1 in rear
    With a 2 inch lift in front end the cv needle bearings will hum. Replace with bushings. I think they around 60 bucks but labor will cost you.
  15. Nov 8, 2020 at 10:34 AM
    #75
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    I would have bought a new bushing.
  16. Nov 8, 2020 at 10:51 AM
    #76
    Traction
    Traction Well-Known Member
    WA
    2020 TRDOR
    You guys did read that he has already done the ECG needle replacement, right?
  17. Nov 8, 2020 at 10:56 AM
    #77
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    If ECGS bushing didnt help id try the next steps: Carrier bearing drop and axle shims should help
    If those mods dont help, then tire misalignment or unbalanced tires would be my guess
  18. Nov 8, 2020 at 10:56 AM
    #78
    Bishop84
    Bishop84 Well-Known Member
    Even after my ECGS replacement there was still a vibe, just less.
    It's 100% the spacer lift, its too much strain, either live with it, or install a 2" lift.
  19. Nov 9, 2020 at 5:43 PM
    #79
    Ataconamedsylvia
    2019 SR 4x4 V6
    I think we can put to rest the ‘bushing was installed wrong’ theory. According to Will at ECGS, “[t]he only way to install it incorrectly is to drive it in too far in which it would contact the spider gears inside of the carrier.” When I asked what symptoms that would cause, he replied, “Not what you're describing.”
    So, unless the shop didn’t install the bushing AT ALL (which I guess we can’t eliminate without having another shop pull the CV again), then the vibe is something else.
    I can see what Bishop84 is saying about the bushing reducing but not eliminating the vibe, but in my case it didn’t change it one iota.
    I’m thinking about just replacing the spacers with lifted struts. Worse case scenario, I’m out $350 and that doesn’t fix it. It’s cheaper than changing whole lift out for a 2” lift. Anyway, still kicking that around.
  20. Nov 9, 2020 at 9:43 PM
    #80
    Jaggerbub
    Jaggerbub Well-Known Member
    Tom
    Diamond Bar 91765
    2017 DCLB OR 4X4
    Following along for the outcome... hope u get this figured out.
