Vibe after Lift - ECGS Bushing Didn’t Fix It
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ataconamedsylvia, Oct 1, 2020.
  1. Nov 10, 2020 at 8:32 AM
    #81
    Mace27
    Mace27 Well-Known Member
    18 TRD OR
    Just my 2 cents but the lower strut bushing on the drivers side doesn't look right.
  2. Nov 13, 2020 at 9:30 AM
    #82
    Ataconamedsylvia
    Ataconamedsylvia [OP] Active Member
    2019 SR 4x4 V6
    3/2 RC lift. ECGS bushing swap. 1” diff drop. OME carrier drop. Still trying to get rid of the damn 2WD-only pulse vibe.
    How so?
  3. Nov 13, 2020 at 11:55 AM
    #83
    OMGitsme
    OMGitsme Well-Known Member
    Sold
    Maybe they made a defective one? It's happened with a few businesses.
  4. Nov 13, 2020 at 12:08 PM
    #84
    orangeracer
    orangeracer Well-Known Member
    18' DCSB TRD OR 4x4 w/6spd MT
    Sucks to hear your dealing with this. I’m going through it too. I had a Westcott lift and AAL lift installed recently, it’s only a 1.5” lift and the damn steering wheel shake and road vibration is getting really bad. Going into 4wd doesn’t make a difference. Didn’t think lifting it so little would make a difference. I ordered some JBA UCAs to get my castor up, as it’s only at 1.5 with the camber and toe in spec. I read and heard from multiple techs that once lifted you need to have the castor up much higher in the 3+ degree range. Did you try new UCA’s yet? I’m really hoping those plus the ECGS bushing solve my problem too. I’ll let you know how it goes.
  5. Nov 17, 2020 at 10:41 AM
    #85
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    ITS POSSIBLE.. if you hit a harmonic imbalance in the wheel/steering it will cause a death wobble especially if the steering is flat (0* Castor)... would need an alignment done to verify, and a cammera looking from the frame to the suspension/steering helps a lot as well.. a lot of straight axle jeeps experience this with a 3-4" lift on stock control arms.
  6. Nov 17, 2020 at 10:50 AM
    #86
    TacoBuffet
    TacoBuffet Well-Known Member
    AL
    Taco #13, 2022 OR DCSB Cemint
    5100s, TE37s, Toyo RTs, Tint, Bedmat, LEDs
    Definitely not UCAs.
  7. Nov 17, 2020 at 11:48 AM
    #87
    Mace27
    18 TRD OR
    the bolt is not centered in the bushing, if thats worn out(or defective) it could cause the vibs.
  8. Nov 17, 2020 at 4:14 PM
    #88
    Ataconamedsylvia
    2019 SR 4x4 V6
    SOLVED!
    What, you ask, was the solution? Well, let me tell you. It was pulling the 3”/2” RC spacer kit off and replacing it with a 2” RC leveling kit consisting of lifted struts (ie no spacers). Some combination of no spacers, the new struts and 1” less lift finally did it, thank God. I was so damn tired of that vibe.
    My opinion, from this point forward, is this: If you’re going to go 3” or more on a 3rd Gen Taco, spend $5K for a solid axle conversion. Otherwise, stick to 2” or less.
    Thanks to everybody for their input.
    SlumberingBear, gclyne, JPDE and 3 others like this.
