Vibe vs. Shutter questions
Discussion in 'Suspension' started by DrRabbitFurHead, Apr 14, 2010.
  1. Apr 14, 2010 at 7:11 PM
    DrRabbitFurHead
    DrRabbitFurHead [OP] Yeah, there's a TSB for that!
    Salem, VA
    X-treme Off Road Edition (4x4)
    Icon Extended Travel Coil Overs, Fox Rear Resi 8-Way Adjustable Shocks, Light Racing UCA's, OME Rear Leafs, M/T Classic Locks 17x9, Nitto T/G (285/70/R17), 5mm Billet Aluminum Spacers, Demello Sliders, All Pro Front Plate Bumper & IFS Skid Plate, PIAA 510's, Doug Thorley Long Tube Headers, O2 sims, Rear Timbren's & U-Bolt Flip Kit , 3* Rear Axel Shims, Extended Rear Brake Lines, 48" Hi-Lift with a ton of accessories, Wet Okoles, TRD bed mat, Borla Air Filter, Garmin Nuvi 765T, Viper 5901 remote start, 50% tint.
    Here's my story.
    step 1 - Had Donohoe front coilovers on, Light Racing UCA's, rear leaf TSB with no vibes or shutter. Donohoes were set to 2.25".
    step 2 - Installed All Pro armor on the front and I raised the Donohoes another 3/8" on top of that to make up for the amount the front end sagged after adding the armor. Again, no vibes or shutter, but the suspension angles didn't change.
    step 3 - Installed OME rear leaf pack (2.75") and new rear shocks and I've developed a very light "shutter" when taking off from 0-5mph. I've only driven ~20 miles with the new leafs but have hit 70mph and I only have this "shutter".
    Now for the questions.
    1. Is this "shutter" what people are calling "vibes"?
    2. Do the vibrations develop over time or are they immediately noticable after the lift is installed?
    3. If I raised my front end another 3/8" (that's where the Donohoes max out at for a 3" lift) is there a chance that I'd change the suspension angles and lose the "shutter"?
    I have the Carrier Bearing sitting in the garage but don't know if I'm going to install it.
    What do you guys recommend? My current plans are to raise the front end the last 3/8" and see what happens.
  2. Apr 14, 2010 at 7:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would try installing a shim in the rear springs first.
  3. Apr 14, 2010 at 7:16 PM
    DrRabbitFurHead
    Salem, VA
    What? :confused:
  4. Apr 14, 2010 at 7:23 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    To help with the shutter you are feeling. Install a 3* shim in the rear, and it should fix it.
  5. Apr 14, 2010 at 11:38 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    What he's referring to " a shim" is a little wedge that sits between the leafspring and the leaf-perch on the axle. What it does is rotate your axle 3* so that the angle of your driveline is about the same as it was before you lifted it. It's a very common problem/fix.
    Shims are pretty easy to install, you usually don't even have to take the u-bolts off, just loosen them enough to fit the shim in place then line it up and retighten the ubolts. They are cheap too. your local 4x shop probably has some or Toytec and and the like have them on their website.
    The other option is a carrier bearing drop, real easy to install but not as much a sure bet as the shims. Some folks use the bearing drop and shims to correct the problem.
  6. Apr 15, 2010 at 4:19 AM
    DrRabbitFurHead
    Salem, VA
    1. So the shims go next to the pin that the shocks sit over?
    2. Would the shim would have the vertical member closese to the front of the truck or the back? Another way of asking the same question is am I trying to raise the front of the leaf (which is what I'd guess) or the back of the leaf?
    3. Finally, is this totally an "angle" problem? Would raising my front up a bit change the angles and help to solve the problem or is that a pipe dream?
    Thanks for the help!
  7. Apr 15, 2010 at 8:09 AM
    nvdeserted
    Reno, NV
    1. You separate the leafsprings from the axle and then stick the shim in between the two. there is a bolt that goes through your leafsrings to hold them together, on one end of the bolt is like round tab or 'locating pin' that fits in a hole on your leafperch (welded to the axle), the shim has a hole in it and that locating pin just slides through the hole and into the leafperch like before. It's easy once you see it.
    2. The shim only rotates the axle a tiny bit, it does not move the axle forward or backward.
    3. You can lift the front 2 feet or drop it 2 feet and it won't change the angle of your rear driveline. The only way to change the driveline angle is to raise the rear of the truck.
  8. Apr 15, 2010 at 8:16 AM
    BirdTRD
    BirdTRD Unsuspectingly striking from above
    Greg
    New Mexico
    TRD Off Road 4x4
    Front (2.75" total): 1.6" Eibach coils, Toytec 0.5" (L) & 0.25" (R) top plate spacers, 5100's @ 0.85", Built Right uniball UCA's, Differential drop, Removed sway bar Rear: TSB springs, Wheeler's 1.5" AAL, 5100's, 2* shims, Carrier bearing drop, F and R Spidertrax, 285/75-16 Goodyear Duratracs, Self-fabbed sliders, rear bumper, and skid plates, Cobra 75 CB, Bed lined slim lo-pro tool box, Bed Extender, Diff breather mod, Two tail gate security mods, Exhaust dumped behind axle, Can't leave shit alone so plenty more coming...
    Why yes, vibes do make my wife shudder.:)
    "Shutters" hang from your windows.
    I would actually recommend the carrier bearing drop first. It takes like 10 minutes to install and you already have it. If it works, great. If it doesn't, buy some shims and take on the more laborious job of installing them.
    You'll get it. Be patient.
  9. Apr 15, 2010 at 6:24 PM
    DrRabbitFurHead
    Salem, VA
    I got under the truck tonight and kind of see what you are talking about. I lifted the front end 3/8" and it made NO difference.
    Tomorrow I'll install the carrier bearing spacer and see if that helps. If not, I'll buy the shims.
    To be more clear, does the shim rotate the rear axel CW or CCW. I'd assume CW is what I want. (That's my way of asking #2 more clearly, hope that's better).
    Oh, sorry on the window covering reference... :D shimmy, shake, elvis the pelvis, whatever...
  10. Apr 15, 2010 at 6:33 PM
    BirdTRD
    Greg
    New Mexico
    TRD Off Road 4x4
    If you're looking from driver's side, shims will twist the axle clockwise. It will take the part of the axle where the drive shaft connects and point it more straight at the carrier bearing joint.
  11. Apr 16, 2010 at 6:50 AM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist
    Rocky Mountains
    Toyota's are awesome
    Install that carrier bearing drop kit, YOU WON'T BE DISAPPOINTED!!!
  12. Apr 16, 2010 at 4:36 PM
    DrRabbitFurHead
    Salem, VA
    I did install it and unfortunately I am disappointed! It didn't do squat! The shudder was never too bad, but if I can get rid of it, I'd rather it be gone. Off to look into the 3 degree shims now... maybe I can get that Toytec discount... hit me up via PM if you would!
  13. Apr 16, 2010 at 7:35 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Wow! I feel sorry for ya man! I had vibes like crazy, and nothing helped! I finally said screw it, and ordered a one piece drive shaft, and never looked back. Hope you get rid of your vibes!
  14. Apr 19, 2010 at 7:33 AM
    Toytec Lifts
    Rocky Mountains
  15. Apr 19, 2010 at 4:18 PM
    DrRabbitFurHead
    Salem, VA
    Parts shipped today. Probably going to install the 3 degree shims before removing the carrier bearing shim kit, even though I've red the shims may do the job by themselves. Hope this works!
  16. May 2, 2010 at 4:56 AM
    DrRabbitFurHead
    Salem, VA
    I installed the 3 degree shims yesterday and the vibe is still there. Almost no noticable changes. I'll remove the carrier bearing shim next to see if that makes a difference.
    If the carrier bearing shim removal doesn't work, is my only other option a new one piece drive shaft? The vibe really isn't "that bad" and it's only from 0 to maybe 15 mph. My big gripe is that my driveway is SO STEEP that whenever I go up it, the damn truck shakes like crazy, otherwise I may just ignore it.
  17. May 2, 2010 at 10:18 AM
    meafordmike
    meafordmike Well-Known Member
    New Brunswick Canada
    08 Tacoma 4X4/ 4Dr 6 speed, Sport/ Towing
    Devil Horns, Wet Okoles, WeatherTechs, Radflo Coilovers, OME Dakar's, FJC Gun metal rims, 265/75/16 BFG All Terrain TA/KO, Rear Diff breather Mod,
    I just finished installing my Dakars and no vibe! But I did remove the 3rd leaf and installed the carrier bearing drop kit. Love it so far, I don't know how to explain it, but it just drives better. Next week coilovers!
  18. May 2, 2010 at 3:34 PM
    DrRabbitFurHead
    Salem, VA
    You have a TRD Sport and longer drive shaft. Your angles are probably better...
  19. May 2, 2010 at 5:10 PM
    meafordmike
    I may be wrong, but I should have the same length truck as you. In Canada the 6 Speed manuals/ Double cabs are all short beds.
  20. May 2, 2010 at 5:42 PM
    DrRabbitFurHead
    Salem, VA
    Learn somethin' new every day. I kept in the 3rd leaf and added the axel shims so I probably am 2 leafs higher than you are. Carrier bearing drop kit comes off tomorrow night after work. I'm keeping my fingers crossed. Anyone know how much a Tom Woods drive shaft costs?
