Vibes after lift - HELP!
Discussion in 'Suspension' started by headhunter247, Dec 29, 2009.
  1. Dec 29, 2009 at 8:07 AM
    headhunter247
    headhunter247 [OP] Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
    I also read Snoboarders posts/theory regarding the front diff being missalligned.
  2. Dec 29, 2009 at 9:57 AM
    headhunter247
    St. Louis, MO area
    So, with these vibes, if I just get used to them, will it be something that will be determental to the truck?
  3. Dec 29, 2009 at 1:11 PM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    dont get used to them, I think they are able to be fixed...try the shims, ace the diffdrop.
  4. Dec 29, 2009 at 3:08 PM
    09tacoLI
    09tacoLI Well-Known Member
    long island ny
    09 off road
    Shrockworks sliders,Shrockworks Front bumper,Warn 9.5xp winch,Toytec Ult.3in,Total Chaos UCAs,AP expo Rear, Fox remote resi shocks Bud built skids,Piaa 7in,Piaa yellow plasma Off road lights.
    I had bad vibes too after my lift without shims after Dave installed them for me they were gone.
  5. Dec 29, 2009 at 4:36 PM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    take out the diff drop and the cb drop, then go forward. when i did my lift i did not put anything at first. i had vibes then put shims on and it made it worse, then the cb drop and vibes were gone. do the "vibe fixes" one at a time to see what is helping and what is making it worse.
  6. Dec 29, 2009 at 4:47 PM
    pataco
    pataco Well-Known Member
    Down by the lake
    05 4x4 trd dc white
    FOX 2.0 RESIS,LRUCAS,BILLY 5100S ON THE REAR.MAGNAFLOW 11264,COLOR MATCHED GRILL,YELLOW FOG MOD.OVER HEAD DVD,FEDERAL COURAGIA M/T
    that guy is dialed in on that shit.
  7. Dec 29, 2009 at 6:44 PM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    Congrats on getting the lift!
    I'm in no way an expert on this, but I've done a considerable amount of research and have developed my own perspective on how to move forward troubleshooting. A few things come to mind, none of which are necessarily meant to be done at the same time, or necessarily relate to one another:
    1. If the vibes are in the seat, regardless of what the mechanic says, I think the rear of the truck is the source. To me it at least provides a good place to start looking. Makes me second guess this though since the vibe goes away in 4x4, although I can still see this being the case.
    2. As Chris4x4 and others have mentioned, remove the diff drop. Personally, I'd rather add/modify parts to fix a problem rather than add/modify parts to try to prevent a problem from happening to begin with. To me, doing the latter can only inject other variables into the equation.
    3. Experiment with the CB drop. Try the CB drop by itself, try it with some axle shims, try axle shims w/o CB drop. Obviously taking note of different scenarios yield which results. Sometimes axle shims remove the vibes, and adding the CB drop makes things worse. The CB drop is SIMPLE to install, nothing needed other than a wrench, I did it in the parking lot, took 5 minutes.
    4. Check the U Bolts, make sure there is a fairly even amount of threads showing all around (opposed to the front side of the axle bolts showing more thread than the back side, potentially rotating the axle, likewise for more threads rear of the axle).
    5. Make sure the U Bolts are all tight. Should be easy, don't know the torque specs off hand though.
    6. Try lowering the front 5100's to .85 or 1.75. See if the vibe improves. If it does, then the vibes are likely from the front.
    Again, I'm no expert. I've just done a lot (let me reiterate, A LOT) of reading on issues, potential issues, suggested fixes, etc. Not all necessarily pertaining to my own setup or issues that I am even experiencing.
    Good luck!
  8. Dec 30, 2009 at 5:38 AM
    headhunter247
    St. Louis, MO area
    Yea, I feel like by the end of all this, I will be an expert as well. I am going to continue to read and try various things until its right. I am going to take the diff drop off and see where that gets me first.
    I am super happy with the looks and have noticed a few heads turning to look (always a good feeling).
  9. Dec 30, 2009 at 5:54 AM
    rclangelan
    rclangelan Well-Known Member
    Sykesville, MD
    2012 DblCb Baja Ed. (Black)
    TRD Front Skid Plate, Tacoma All-Weather Mats, BFG AT KOs (265/70/16)
    It sucks that your having troubles, but...
    still waiting on pics! :D
  10. Dec 30, 2009 at 10:58 AM
    headhunter247
    St. Louis, MO area
    Its snowing today, maybe when I get home I can snap a few. If not, I will on new years day for sure.
  11. Jan 12, 2010 at 8:20 AM
    wiscdave
    wiscdave Lets Do It!
    Northern Wisconsin
    Tundra Rock Warrior
    Past ride - 3" OME 885s&Shocks/ TSB 1.5AAL/ AX184 Rims 285 Firestone destination ATs/ 2 Shallow mount P310s in Supercrew Box - Punch 601s, Beefed up Hunter Brush guard, Tint, Fog light mod, AFE Drop in, AC and Fog light mods, scangauge
    Any update on your vibes?
