Vibes after OME lift - need help resolving the issue
Discussion in 'Suspension' started by ACE_Taco, Mar 9, 2010.
  1. Mar 9, 2010 at 9:41 AM
    ACE_Taco
    ACE_Taco [OP] Long Range Practical Marksman
    NC
    08 DBLCab TRD 4x4
    OME 885x Coils, Dakar Leafs, OME Shocks, TC UCAs, BHLM, Tailgate MOD, WeatherTec Window Deflectors, WeatherTec Floor Mats, Blacked Out chrome bumber, Satoshi Grille, Wet Okole Seat Covers
    Well, I installed the OME 885s w/9000 shocks on the front of my 2008 DC. I have the 182s on the rear, with the TSB Leafs only. Front was lifted approximately 2.5". After the install, vibes in the driver floor board between 25-35 mph were present.
    I then installed the OME CB Drop kit and it made it worse. I removed it. Then, I installed the Diff. Drop and it made no change, so I removed it. All tires and wheels are balanced out GTG. Alignment was ok.
    After a 400+ mile journey, they seemed to have subsided. Over the weekend, I installed new TC UCAs, and the vibes are now WORSE! WTF???? I had it aligned yesterday and it aligned beautifully, but vibes are still there.
    I had the dealership drive it and they said all looked good on the driveline. They said it possibly could be the stiff TSB springs or the shitty BFG Rugged Trail tires. I plan on buying new tires, but none of this was present before the lift.
    Where should I check next??? I am running out of ideas and getting pretty damn annoyed!
    Any help would be greatly appreciated. Thanks
  2. Mar 9, 2010 at 9:47 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Axle shims are the only thing that I think is left. Tires could be the issue....cause after you change the alignment from the stock to lifted the tire wear could be off- but I wouldn't think that would be so bad.....
  3. Mar 9, 2010 at 9:50 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    How do axle shims help?? Doesn't it address the driveline issue like the CB Drop??
  4. Mar 9, 2010 at 9:53 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    It does...but from the other end-
    and if you are sure that all the bolts are tight and everything else is right....I'm pretty out of ideas.
    I can't see why the UCAs would make it worse.....but ::shrug::
    Hopefully Chris12x9 stops by soon
  5. Mar 9, 2010 at 9:55 AM
    Tsenekos
    Tsenekos Well-Known Member
    Greg
    Edmonton, CANADA
    2005 DC 4WD trd offroad
    Toytec 3" lift w coils,1.5 AAL,5100's all around,diff drop kit, axel shims,N-Fab nerf bars,bestop supertop,fog mod, weathertech mats
    I used the axel shims with my rear aal and I only have that 0-10mph little vibe so they may help your problem too good luck with it.
  6. Mar 9, 2010 at 10:29 AM
    twr437
    twr437 Well-Known Member
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    nerf bars, bed cover, husky liners, Icon coilovers, LR UCA, rear 5100s, TSB AAL, diff drop, carrier baring drop, axel shims, AFE pro dry filter, BHLM, mesh grill, Black emblems,
    CB drop and Diff drop combined fixed my vibs.[​IMG]
  7. Mar 9, 2010 at 10:35 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Not sure if the TC UCAs changed anything in the vibe zone. The only thing I did was remove the wheel and install. Maybe it is the wheel/tire. Not only does the vibe happen when accelerating, but also when decelerating. Almost seems like a pulsating vibe/rub.
    BTW, I have had the Diff. Drop Spacer and CB Spacer installed at the same time, and the vibes were still there.
  8. Mar 9, 2010 at 10:49 AM
    headhunter247
    headhunter247 Well-Known Member
    St. Louis, MO area
    18 Taco Double Cab TRD
    5100's all around, OME 888 and Dakars. ProComp Series 05. Cooper SST Maxx 275s.
  9. Mar 9, 2010 at 10:54 AM
    twr437
    Tim
    East Texas
    08 TRD Sport 4x4 LB
    Maybe try the axel shims as well......
  10. Mar 9, 2010 at 1:05 PM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Just drove the truck in and out of 4WD. The vibes are greatly reduced in 4WD. I have read through the TN Thread. I am going to the dealership and see if I can get some help. Shit is frustrating as hell.......
  11. Mar 10, 2010 at 6:18 AM
    headhunter247
    St. Louis, MO area
    Yea, well at least you have a warranty. Im on my own with this. One guy said that hes been driving with it this way for 20000 mi, so it doesnt make me that leary. I think that at worst from a mechanic that I talked to, the U joints will wear out faster.
  12. Mar 11, 2010 at 5:55 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Well, the truck went in yesterday. The CVs, Driveshafts, etc,, looked good. Not loose or bad on the front diff. like some have mentioned. They even took tires and wheels off of another TRD, and still had the vibes. At least that eliminates a tire/wheel issue. Quite possibly could be the angles of the DL. I have a set of 3* axle shims that are going on next. If that doesn't work, the truck will be launched off a cliff....:D
  13. Mar 11, 2010 at 5:57 AM
    headhunter247
    St. Louis, MO area
    Good luck buddy..give us an update once they figure it out.
  14. Mar 11, 2010 at 5:59 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Thanks.. Will do. Hope I find it and no one else has to go through this aggrevating crap......
  15. Mar 13, 2010 at 8:29 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Got the shims on and torqued. I drove the truck and still had vibes. I then put the OME CB Drop Spacer in and had vibes, but they seem to be a little better. Should I try the Front Diff spacer again?? If I can't get them quite gone, will it hurt to leave the CB Drop and axle shims in??
    What next??????
  16. Mar 13, 2010 at 8:33 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Everything on the front is propperly torqued, Right? :confused:
  17. Mar 13, 2010 at 8:43 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Yes. I followed the install sticky and torqued to specs listed in the Toyota Service Leaflets. TC UCA uni-ball bolt torqued as per TC recommendation. (100 ft-lbs)
    I got to thinking about when I removed the stock UCAs last week and installed the TC UCAs. It appeared the vibes were more noticeable. Is there any chance that when I remove the stock UCAs it dissrupted something in the CVs?? As in, when you remove the bolt, the weight makes the spindle lay over to the right or left. May be a long shot, but just grabbing for straws....
  18. Mar 13, 2010 at 8:45 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    That shouldnt have hurt anything....
  19. Mar 13, 2010 at 9:02 AM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Guess I'll pull off the front wheels and torques check everything. OK to leave the shims and CB drop in??
  20. Mar 14, 2010 at 9:46 PM
    ACE_Taco
    NC
    08 DBLCab TRD 4x4
    Well, I took out the axle shims and CB drop, because I still had vibes. Today, I removed the front wheels and loosened everything. I then went through every bolt and torqued to spec. Still have vibes.
    I have tried it all, now what???????
