Vibes at low speed turns (tried searching)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blasphemous, Jul 11, 2011.
  1. Jul 11, 2011 at 7:16 PM
    Blasphemous
    Blasphemous [OP] Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    Hi Guys,
    2008 2wd TRD Sport DC Tacoma. I've noticed that the truck has started pulling to the right more and more rather quickly lately. I am also getting vibrations that seem to come from the floorboard when I am taking mild to sharp turns at low speed.
    Bone stock truck.
    Any ideas?
  2. Jul 11, 2011 at 7:18 PM
    Blasphemous
    That's what I assumed I should start out with. Never had this happen though, where it started happening rather suddenly.
  3. Jul 12, 2011 at 7:09 AM
    Glamis
    Glamis date joined 03-18-2009 this is my new ID
    Anaheim & Glamis, CA
    08 PreRunner DC/LB Sport-2 Debadged
    Debadged, TRD exhaust, Devil Horns, Pop n lock, Stock wheels chromed, K&N, DRL's on/off switch, bed mat, lock & unlock beeper, Disable Seatbelt Warning Chime, 12v Cigarette lighter plug always on, 2009 LED Brake lights, TSP springs, Fire Stone Ride Air springs.
    I also have a 08, been getting the same noise. I have 53K on the truck is on the stock tires that still look good. I have had truck alined and the tires balanced about six months ago.
  4. Jul 12, 2011 at 7:19 AM
    6spdtaco
    6spdtaco Well-Known Member
    VT
    Taco
    I've seen wheel bearings go out and you could feel it through the floor.
  5. Jul 12, 2011 at 12:44 PM
    Blasphemous
    Interesting. What would cause wheel bearings to go out?
  6. Jul 12, 2011 at 5:19 PM
    6spdtaco
    VT
    Taco
    They are a wear item, and can eventually give out on a stock truck, BUT it usually is because of aftermarket wheels, tires, or lift.
  7. Jul 13, 2012 at 10:08 AM
    Blasphemous
    Updating an old thread, but my rear diff fluid needed to be changed.
    With the LSD in the rear diff I was getting chattering that could be described as vibes during low speed turns.
  8. Jul 13, 2012 at 10:49 AM
    Large
    Large Red
    Damn. Thanks for the follow up? A lot of issues would be solved if everyone did this. Props to you.
