vibes from 0 to 15-20mph: help
Discussion in 'Suspension' started by tacosupreme54, Aug 17, 2010.
  1. Aug 17, 2010 at 8:01 PM
    tacosupreme54
    tacosupreme54 [OP] Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    i will just get to the point. i have 2.5" spacers up front and 2" AAL in the rear. the past few days i have noticed slight vibrations when going from a complete stop until i hit about 20mph. i can feel them in the steering wheel and on the gas pedal. once i get past about 15-20mph, there are no more vibes, it just drives like it always has after that. i had my lift purchased/installed at different times because of funds. the thing is that i had the front done first and had no vibes until i had the rear AAL done a few weeks later. i would have thought it would have been more likely to have been the front, since it feels like it's coming from there. but it didn't start, or at least it wasn't noticeable to me until a few days after the rear was done. all i can think is alignment maybe, but i had one done just a few weeks ago when the spacers were installed. i have no idea what it is, so i need any help available. i am on 265/75 duratracs. idk if this has anything to do with it, but i still have stock UCA's, but plan to get some aftermarket ones soon.
    please help if you can
  2. Aug 17, 2010 at 8:10 PM
    sshumphrey1
    sshumphrey1 Greenside Doc
    Naval Weapons Station South Carolina
    08 Tacoma Crew Cab 4x4
    TRD CAI TRD Seat Covers Toyota All Weather Mats Ready Lift SST 2 inch Pro Comp Add a Leaf Double DIN JVC Head Unit Rampage Step Bars
    I have the exact same issue and set up as you have, and have been dealing with it for the past seven months. I even tried spacers on the carrier bearing in efforts to decrease the drive shaft angle with no luck.
  3. Aug 17, 2010 at 8:15 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    it's almost like it can't make it's mind up going from 1st to 2nd gear. i just don't want to drive on this and make it worse.
  4. Aug 17, 2010 at 9:09 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    nobody has any help or advice?
  5. Aug 17, 2010 at 9:24 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Icon's with JBA UCA's, Dakars and 295 BFG KO2, Bora 1" spacers, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    its drive line shutter from your drive shaft/carrier bearing. you might want to try the spacers like staited. but if that doesnt work. you need to try axel shims. they have them at toyteclifts.com
  6. Aug 17, 2010 at 9:27 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    ok, cause i have been looking and was thinking it might be from the lift, but actually on all the threads about half the people were just stock. it's just a toyota problem. thanks man.
  7. Aug 17, 2010 at 11:34 PM
    nvdeserted
    nvdeserted Well-Known Member
    Reno, NV
    2009 Tacoma TRD OR Access Cab
    Electric Dynolock tailgate, TrailGear Slides, , 285/75-16 Yoko Geolanders on Wheelers Type B, SAW 2.0 front and back, Camburg b/j UCA, 1.5" AAL, Ubolt flip, ARB bump.
    ^I'm with this guy. "started after rear AAL"... gotta be driveline vibe, or even if it's not it will be a cheap attempt: first get a carrier bearing drop kit (from Toytec or something) and if that's not enough, get axle shims (from Toytec or something). The carrier bearing drop is super easy to install. The shims are also easy but will take more time/tools.
  8. Aug 18, 2010 at 9:43 AM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    yeah, this will be a cheaper fix than i thought. i also did read on some threads with these symptoms that tires just needed rotating/balancing or alignment.
  9. Aug 18, 2010 at 8:11 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    went to my mechanic today and laid the situation out to him, also mentioned some of the potential problems and solutions to him. he looked and said that the drive shaft looked fine and there was nothing wrong with any of my angles. he said alignment was also fine and that it wouldn't hurt anything to ride on these stock UCA's until i get money for new ones. my tires will just wear uneven. which brought him to a conclusion, or at least the simplest/most logical one. my tires are wearing uneven, which made us realize that i need them rotated and balanced. is that the reason for vibrations? idk, that's what he's saying. i mean i hope that's the problem, cause it's the cheapest and simplest to fix and that's why we agreed to try this first. i haven't had them done in about 10k miles anyway, lol. he didn't really say no to the carrier bearing solution, but if it's still driving like this after rotation and balancing, that might be our next thing to try.
  10. Aug 18, 2010 at 9:49 PM
    FixedTRD
    FixedTRD Well-Known Member
    Will
    Alhambra, CA
    All pro LT, All pro front bumper,All pro rear fox, 1.5 full leaf and u bolt flip kit. KR sliders, bestop, high lift with custom mount, katskin leather, Hankook MT and atx artillery. DMZ SUA w/FOX triple bypass
    I also had the same issue with the vibe after suspension lift. I tired alignment, tire rotation and balance and its still there. I will try the bearing drop soon but I pretty much just lived with it. :D
  11. Aug 18, 2010 at 10:11 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    damn, well i hope when i get my tires rotated and balanced i will be done with it tomorrow. let me know how the bearing drop does when you get it done. you might wanna change your username on here though, haha
