Vibes From Right Front...Help? Took Video
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SManZ, Dec 4, 2010.
  1. Dec 4, 2010 at 10:27 AM
    SManZ
    SManZ [OP] Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    Last night I started getting vibrations from my right front wheel. It happens anytime I'm moving and is most noticeable at 40-60mph. I get a vibration for 1 second, then it stops for a 1.5-2 seconds, and then on again for a second.
    This is on a 2010 4x4. I've got a Toytec lift, wheel spacers, EBC dimpled/slotted rotors. The lift has been on the truck for 15,000mi. The rotors and spacers for 12,000mi. No problems until last night.
    I took the wheel off today and retorqued the spacer nuts and lug nuts. The only thing I noticed is the axle rotates off center. The driver's side does the same thing, but I don't have any vibes from that side. I haven't done anything with the truck that would bend a axle
    Can anyone help figure this out? Its weird that I've had zero problems for 12,000mi and then it just starts up last night.
    Here's a link to a video I shot as I turned the axle by hand.
    http://www.youtube.com/watch?v=f4Usp9JiS6w
  2. Dec 4, 2010 at 10:37 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    the shop I go to has free wheel balancing when you get the tires mounted there, maybe you should try that first before diagnosing something else.
  3. Dec 4, 2010 at 10:39 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    that actually looks fairly normal to me. like above said...maybe that tire is outta balance a bit. when are you getting the vibes?
  4. Dec 4, 2010 at 11:10 AM
    SManZ
    Fauquier County, VA
    Cool...glad theres nothing wrong w/ the axles.
    I get the vibes at all speeds, but most commonly between 40 and 60mph. Doesn't matter if I'm gassing, coasting, or slowing down. Its for a second, then stops for a second or two, then comes back fro a second.
  5. Dec 4, 2010 at 11:37 AM
    ktmrider
    Junk
    how strong is the vibration, I have a pulsing in the floor by the petals but I hardly ever notice it because its so small
  6. Dec 4, 2010 at 7:00 PM
    SManZ
    Fauquier County, VA
    The vibes aren't strong at all. Its a light buzz. I can feel it in the floorboard but the noise is more noticeable than the vibration. Sounds kind of like a mudflap rubbing, but thats not it.
    I went for a drive after I retorqued the nuts and its still there, but not as bad or as frequent. I'll drive again tomorrow and see whats up. I'm coming up on a tire rotation anyway, so I'll see if NTB will rotate and balance for free - they mounted my tires.
  7. Dec 4, 2010 at 7:44 PM
    toku58
    toku58 Well-Known Member
    On a Rock in the middle of the Pacific
    Mall Crawler!
    21' TRD OffRoad 2" 887 OME on Bilstein 5100's. 285/70R17 General Grabbers G3 17x8.5" Icon TRD wheels (Gun metal gray) 4.75" BS
    It looks like something is wrong with the tripod bearing on the inside end of your CV shaft? The wobble appears to be towards the inner portion of the shaft.
  8. Dec 5, 2010 at 6:19 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I agree... A wobble like that shouldn't be anywhere near the bearings.
    To the OP - Jack up the front end of the truck and grab the shaft with your hand and shake it. Can you move it? I'm not talking about rotational movement either. I'm talking about back-n-forth movement.
    If you can move it with your hand....that's bad news and probably a bearing.
  9. Dec 5, 2010 at 7:38 AM
    SManZ
    Fauquier County, VA
    I jacked the front end up. Total in/out movement of the axle is about 1mm. This is on both the driver's and passenger's side. Is this kind of play not normal? What could cause this and what are the next steps?
    -Thanks!
  10. Dec 5, 2010 at 7:47 AM
    Janster
    Jandy
    Lancaster, PA
    It's hard to say....
    What's the passenger side shaft look like? Do the same with the passenger side shaft - how do they compare?
    Also, if you try to shake it closer to the wheel & again closer to the diff.... is it wobble worse at the wheel side or the diff side?
    Another thing to do...while the front end is still jacked up, grab the wheel and shake it also (side to side, front to back), etc. Compare with doing the same on the passenger side.
    Basically, your trying to find where the wobble is coming from.....
  11. Dec 5, 2010 at 7:55 AM
    SManZ
    Fauquier County, VA
    Thanks Janster,
    When I did it this morning, both the passenger and driver's side were the same. I grabbed the axle between the two boots and tried to move it in/out towards the hub and diff. I'll try to shake it front to rear and up/down as well, from the hub side and diff side.
    Does it matter if the truck is jacked up or not when I try to move the axle? The hub stays stationary in either case.
    Yesterday when I jacked the truck up to take the wheel off, I tried shaking the wheel but there was no play. There was also no wobble or resistance when I spun the wheel either.
  12. Dec 5, 2010 at 8:04 AM
    SManZ
    Fauquier County, VA
    :eek::rolleyes::eek:...I think I found my vibe. I cut one of the fenders too short when I installed the All-Pro bumper. It was making a buzzing noise as it fluttered in the wind, so I secured it with tie wire a few months ago. The wire had loosened up and it looks like it was fluttering again. I'm going to secure it again and see if the vibe goes away.
    I hit my head on it when I reached for the axle and just had the aha! moment.
    Still...I can move the axle up/down and back/forth a little more than 1mm at the diff side. The entire assembly has some play in it, from the inner boot to the large metal cylinder that goes into the diff housing. There is no play in the axle at the hub (outer boot). Both driver and passenger sides are the same.
  13. Dec 6, 2010 at 4:07 AM
    Janster
    Jandy
    Lancaster, PA
    Glad you found the vibe problem!! It's always something!
    If everything is the same on both sides, than I'd consider that normal. Although, that video of the axle wobbling is still somewhat odd (to me anyway).
    Does the passenger side axle shaft wobble like that?
