Vibes in Steering Wheel between 30-40 MPH???
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaGus, Dec 8, 2010.
  1. Dec 8, 2010 at 6:22 PM
    TacomaGus
    TacomaGus [OP] Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    i have had these tires road forced balanced 4 times now and vibes that i was getting over 65 mph have completely ceased and its nice to drive on the highway but now i get vibes between 30-40 mph. I can feel it slightly in my steering wheel and in the truck itself, and i think it has gotten worse with the cold coming on now because as i drive it more, it is less severe. I my truck to a shop last week to have a 150k mile maintenance done to it and they didn't do anything major, just topped off fluids as needed and fixed e-brake but its done it since then.
    do you think the shop may have done anything, or is it my tires again, or something else all together?
  2. Dec 8, 2010 at 6:58 PM
    McBride513
    McBride513 Well-Known Member
    Luke
    Cincinnati
    04 4x4 TRD
    it might be your rotors. Go for a test drive at around 30-40 mph lightly brake and hold the steering wheel lightly. If it vibrates real bad your rotors are warped and need to get machined or replaced.
  3. Dec 8, 2010 at 7:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    honestly, i think its probably from it being cold.....your tires will flat spot a bit from sitting overnight and after you drive some,they are back to narmal once they heat up.
    do you have a lift on your truck?
  4. Dec 8, 2010 at 7:21 PM
    TacomaGus
    Gus
    Morgantown, WV
    yes i do. I have the billies at the highest setting although they have settled some
  5. Dec 8, 2010 at 7:35 PM
    TacomaGus
    Gus
    Morgantown, WV
    have had alignment done multiple times and i had the last one done about 2 months ago and it has been fine since that was done, drives straight when i can actually find a straight level road haha. Just started doing this about 2 weeks ago aka since its steadily been below 40 degrees
  6. Dec 8, 2010 at 8:18 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    im guessing its your tires flat spotting. mine do it too..here in South Carolina, its been around 14 degrees in the am.
  7. Dec 8, 2010 at 9:18 PM
    TacomaGus
    Gus
    Morgantown, WV
    yea same in WV its around 10 degrees every night and only 25 during the day. But do you just feel it in the steering wheel and it doesn't necessarily shake, but just vibrates like up and down slightly almost? idk hard to explain the vibe
  8. Dec 9, 2010 at 4:01 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Rotate you tires.... and see if the vibration changes.
    When the vibration is occuring - step on the brakes slightly and see if the vibration goes away, or gets worse.
    What size & type of tires & wheels are you running? You mentioned you had them balanced 4x - when did you have all this done? When was the last time you had them balanced? Did you inspect each wheel (inside & out) to make sure you didn't loose any wheel weights?
    Again, as I mentioned above...rotate the tires and see if the vibration changes. You might be able to narrow it down to the fronts/rear or any one wheel.
    What lift do you have in the rear & how long have you had that lift?
  9. Dec 9, 2010 at 4:05 AM
    Gr8WhiteTaco
    Gr8WhiteTaco bishes love my haircut
    Aaron
    Knoxville, TN
    SOLD 02 Double Cab TRD 4x4
    2005 Mazda 3S hatchback
    I think its flat spots. I'm pretty sure I have a spot in one of my fronts, mine shakes ~69-74mph
  10. Dec 9, 2010 at 11:02 AM
    TacomaGus
    Gus
    Morgantown, WV
    i have 32x11.5 R15 tires, they are generic wild country AT tires ans the wheels are pro comps. had them road forced prob about 6 weeks ago was the last time and they have been ok since then. I need to get my tires rotated anyways at my next oil change which will be in a couple of weeks so ya i figured i would see if the vibe went away in the wheel. I know its not the brakes cuz it vibrates whether i'm using the brakes or not and doesn't get any worse with braking
    also i do not have a lift in the back. even with the billies it sits level b/c i had my frame replaced and nothing has really sagged yet
  11. Dec 9, 2010 at 11:05 AM
    snow dude
    snow dude Well-Known Member
    Darius
    Brush prairie
    07 tacoma SR5
    undercover canopy, K&N intake, 1.5in aal, 1in diff drop doug thorley headers, total chaos upper control arms, debadged, fog lights, Nokya Arctic Yellow fogs, 25% tint, isimple aux, kings remote reservoir,
    the same thing was happening to my truck and i got new uca from tc and it went away.
  12. Dec 9, 2010 at 11:28 AM
    Janster
    Jandy
    Lancaster, PA
    So, it was fine after you had the wheels/tires balanced last? You just started getting vibes?
    Check to make sure a wheel weight didn't fall off..... check both the inside & the outside of the wheels. Sometimes they use 'stick-on' weights on the inside of the rim. I've seen them stacked ontop of eachother also....and they can fall off.
    Did Toyota replace the frame under that rust warrantee?
  13. Dec 9, 2010 at 11:48 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Did they rebalance the tires when they rotated them during the 150k maintenance?
  14. Dec 9, 2010 at 5:13 PM
    TacomaGus
    Gus
    Morgantown, WV
    no they did not rebalance the tires when the service was done and they didn't rotate the tires either so i am going to see if rotating them will fix it. and yes the frame was replaced under warranty last fall
    I did a little test drive to see if i could get it to stop, when i braked it didn't get better or worse so i know its not brakes, and it still did it in 4 Hi so glad it has nothing to do with drivetrain anything. So its either major flat spots from cold weather and it does get better over time, but i really only drive extended amounts on weekends aka more than 3-4 miles, everything is close in a college town haha. Or its balancing again, Its just weird that i don't get high speed vibes (60 mph and over) like i used to when i knew the balance was off, its only between 30 and 40 MPH...
    pretty much learned to never get generic name tires and go brand name b/c these tires have been such a pain with all the balance issues and now another balance issue possibly or easily getting flat spots.
  15. Dec 9, 2010 at 8:28 PM
    TacomaGus
    Gus
    Morgantown, WV
  16. Dec 9, 2010 at 9:24 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I think Will's comment was right on. When the truck sits for a while the tires are developing a flat spot at the contact patch. When you drive it, it takes a bit to smooth out that area of the tire.
    Colder temps contribute, on a 100* day this wouldn't happen. Do you own a air pressure gauge. Are all 4 tires aired up fairly equally? The lower the air pressure in the tire, the larger the contact patch. What are your pressures?
  17. Dec 9, 2010 at 9:41 PM
    TacomaGus
    Gus
    Morgantown, WV
    last time i checked was about 10 days ago and i had my fronts set at 34 and my rears at 32. It has been colder since then though consistently. I guess this is my first winter with bigger tires with a higher load rating (Load C on the 32's compared to passenger or standard load on my old 265/70 R16's) so maybe i'm not used to feeling that much of a flat spot? Just seems weird i only feel it between 30 and 40 mph, and that is the only time
  18. Dec 10, 2010 at 4:30 AM
    Janster
    Jandy
    Lancaster, PA
    Rotating the tires isn't gonna FIX it.
    It's a method of troubleshooting. If the vibration changes *FEEL* or location, you could possibly narrow the vibration down to a certain tire or wheel.
    Did you check to see if any wheel weights were missing?
    Vibrations are weird animals. Depending on the severity of the vibration, sometimes you will only FEEL it at certain speeds/rpm's as it build up a rythm. You might feel that rythm (vibration) at 30-40mph and not again until you reach 80mph (example) - due to the rythm (hard to explain).
    Here's a pretty good article about it (kinda mind boggling) but I had to post it.
    http://www.quadratec.com/jeep_knowledgebase/article-36.htm
  19. Dec 10, 2010 at 11:04 AM
    TacomaGus
    Gus
    Morgantown, WV
  20. Dec 10, 2010 at 1:15 PM
    TacomaGus
    Gus
    Morgantown, WV
