Vibrating side view mirrors
Discussion in '2nd Gen. Tacomas (2005-2015)' started by N919HJ, Mar 12, 2009.
  1. Mar 12, 2009 at 6:55 AM
    N919HJ
    N919HJ [OP] Well-Known Member
    Ohio
    2007 Double Cab TRD OR
    My side view mirrors are vibrating at about 35 mph and above. Anybody else have this or have a fix? My old GTI did this until one day I looked over and the mirror (just the glass) was gone.
  2. Mar 12, 2009 at 7:10 AM
    Bearskill
    Bearskill Well-Known Member
    Sac
    06 Access cab PreRunner Sport
    FlowMaster 40 duals out the back, T-Rex grill, Color matched TRD Nerf bars, Icon coilovers set at 2'', 2.75" OME Dakars spring packs, OME Nitro-Charger extended rear shocks, Carrier bearing drop kit, Wheeler's Extended break Lines, Total Chaos UCAs, Mojave Teflons and 31 1/2" Toyo Open Country A/Ts, Pioneer single din unit, Yakima roof rack, Malone roof basket with X2 KC 130w long range Slimmlights mounted to it, Garmin 255w nav, Fire bottle mod, Air Force standard First Aid kit mod, Hidden Muchette mod (don't ask), and 1 huge OCD about my truck.
    I am friends with this chick and she says her 06 does that. She took it in to the dealer and they put a new mirror on....? She says it still vibes.
  3. Mar 12, 2009 at 10:05 AM
    sonjay
    sonjay Well-Known Member
    Try checking the mirror itself first, the glass part just clips into the mirror housing. If thats all good check the nuts that hold the mirror on inside the truck. To really check them you should take the door panel off, but there is a plastic cap over the top one. There just small bolts use a 1/4" drive and they should be pretty snug!
  4. Mar 12, 2009 at 10:32 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    My 05 with 48k had the drvr side wagglin all around. Yet another 160 pt certification failure on the dealer's part. I just took sail panel off & pulled the top of the door panel loose to get a 1/4 drive/socket on the thing & retightened the 3 nuts holding it to the door. All good now. Actually did both doors but pass side was pretty tight.
  5. Mar 13, 2009 at 6:03 AM
    N919HJ
    Ohio
    Thanks for the help guys. It is just the glass vibrating. Is it safe to assume that the glass is glued to a piece of plastic and the plastic attaches to mirror assembly and that would be where the problem lies. Maybe something with the connection is broke?
  6. Mar 13, 2009 at 8:18 AM
    T@co_Pr3runn3r
    08 RC Prerunner SR5
    Oh, IIRC there were threads about or a tsb for something to do with window registers..........
  7. Mar 13, 2009 at 9:44 AM
    sonjay
    You are correct, the glass is attached to a piece of plastic with a fancy piece of double sided tape. The plastic bit snaps into the motor mechanism, to get it off angle the mirror all the way up and pull straight back on the bottom of the glass. There are some pics on the heated mirror thread!
  8. Mar 16, 2009 at 5:36 PM
    danmckennat
    danmckennat Well-Known Member
    chardon, ohio
    2009 tacoma access cab offroad package
    i noticed on my 09 today that my side mirrors are rattling around too not sure if that is normal or not
  9. Mar 16, 2009 at 6:06 PM
    JimmyCrackCorn
    JimmyCrackCorn Atlanta Falcons
    Cumming, GA (N. Atlanta Area)
    2008 Black PreRunner TRD Sport
    Aero Kit, 3" Lift, 18% All Around Tint, 50% Windshield Tint, MO 957's (Polished), 285/65/18 Terra Grappler's
    Wow, yours came with vibrating mirrors? Was that an upgrade? That option wasn't even available when I bought mine! :p
  10. Mar 19, 2009 at 5:15 AM
    N919HJ
    Ohio
    Oh it was an option all right and I'm such a good haggler i didn't even have to pay for it! Thanks for all the help once it gets warmer I am going to pull them apart and see what's going on.
