Vibration '03 Tac rolling or in-gear
Discussion in '1st Gen. Tacomas (1995-2004)' started by davydog, Aug 26, 2011.
  1. Aug 26, 2011 at 2:20 PM
    davydog
    davydog [OP] New Member
    Tacoma 4WD TRD
    I've got an '03 tac with 100K. Recently I've noticed a vibration when accel., decel or just rolling. The vib is intermittent. Can feel it through entire truck. Wheels tires recently balanced. OK there. I'm thinking carrier bearing?
  2. Aug 26, 2011 at 3:54 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    any lift on your truck? sine you are feeling it thru the whole truck...definitely a driveline vibe. the carrier bearing is a likely culprit, as well as u-joints. check them........if you can shake your drive shaft a good bit, the needle bearings in one of the u joints may be bad.
