Vibration ~20mph. If not needle bearing Or carrier bearing... ideas
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Artvandelay, Dec 12, 2017.
  1. Dec 12, 2017 at 11:38 PM
    Artvandelay
    Artvandelay [OP] Well-Known Member
    NY
    17 DCSBOR MGM
    I have a 17 DCSBOR with 5100’s and 888’s with a 3 leaf pack. I have the vibe/ faint rumble strip feeling from 10-20 mph, most noticeable around 15mph. It was most noticeable on deceleration at first but is getting pretty constant now at those speeds.
    1. I of course did the easiest thing first in the process of elimination, the carrier drop. The Emu kit did nothing at all.
    2. Putting it into 4wd doesn’t change it at all, so from what I’ve read that should indicate it’s not the needle bearings...
    With what I’ve done above, can those 2 things be 100% ruled out?
    What is this going to be most likely? Any advice is appreciated. Thanks.
  2. Dec 13, 2017 at 12:09 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Pinion angle.
    More pronounced on deceleration due to springs loading up(a.k.a. axle wrap).
  3. Dec 13, 2017 at 6:58 AM
    Artvandelay
    NY
    17 DCSBOR MGM
    Thanks. How sure are you, need any more details?
  4. Dec 13, 2017 at 7:01 AM
    Bagow
    Bagow Well-Known Member
    Arizona
    2016 DCSB OR 4x4
    I went through the same process as you and ended up fixing it with 3 degree shims.
  5. Dec 13, 2017 at 7:08 AM
    zippsub9
    zippsub9 Well-Known Member
    Halfmoon, NY
    14 DCLB
    Shit bolted onto other shit, and junk.
    +1 shims are definitely the easiest and cheapest next step.
  6. Dec 13, 2017 at 8:06 AM
    Artvandelay
    NY
    17 DCSBOR MGM
    Thanks fellas. Is there’s a diy etc for that? I searched and didn’t see one.
  7. Dec 13, 2017 at 8:08 AM
    Artvandelay
    NY
    17 DCSBOR MGM
    And the truck is going in for the leaf noise tsb. I though I had seen something about an axle wrap issue on the 3rd gens too but don’t see that either...is that a known issue I should have them look at esp since wrap was mentioned above?
  8. Dec 13, 2017 at 8:08 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    Just undo your u bolts holding the springs to the axle then place the shim wedge in between the leafs and the axle. The wedge should be arrayed thinnest portion towards the front and thickest portion closest to the rear to angle up the pinion.
    Artvandelay[OP], FLdub and jholc21 like this.
  9. Dec 13, 2017 at 8:10 AM
    Artvandelay
    NY
    17 DCSBOR MGM
    Thanks. There’s only one size to get?
  10. Dec 13, 2017 at 8:18 AM
    zippsub9
    Halfmoon, NY
    14 DCLB
    2.5 or 3 degree. There are other sizes, but start with one of these. You may accidently go too far, but I have yet to hear of anyone on TW going larger than 3 degree shims.
  11. Dec 13, 2017 at 9:04 AM
    Artvandelay
    NY
    17 DCSBOR MGM
    Thanks. The axle wrap is even an issue with stock height trucks too right?
  12. Dec 13, 2017 at 9:25 AM
    Big Dustin
    Big Dustin Well-Known Member
    Dustin
    Denver, Colorado
    '17 Tacoma DCSB SR 4x4
    5100's all around, OME 887 with 1/4" spacer, icon 3 leaf aal. 255/75/17 BFG KM's on 4runner pro's. Rigid led pods. Debadged and tinted.
    It definitely is. My truck has had the same vibration since day one. I'm going to be installing my lift this week, I'm hoping the new rear shocks will dampen the vibration a bit, maybe with a combination of the new shocks plus aal.
  13. Dec 13, 2017 at 10:06 AM
    FLdub
    FLdub Well-Known Member
    SRQ FL
    2016 Black Tacoma TRD OR 4x4
    Good info here. I recently lifted my truck also and I get a vibration right at 10MPH. I bought the OME carrier bearing drop which didnt do anything at all. Next step is the axle shims, just wasnt sure exactly what size to get. It seems like most people run a 3* shim with good results.
    Now, since my U-bolts and nuts are super new (less than 2 weeks at this point) it should be ok to just loosen them enough to put the shims in and not have to replace them right? Ive heard that once you loosen the nuts from the U-bolts its just best to buy new ones since there is a possibility that they have stretched.
    Artvandelay[OP] likes this.
  14. Dec 13, 2017 at 10:08 AM
    FLdub
    SRQ FL
    How did you determine that 3* would be the best bet? Did you get under the truck and measure angles and figure it out or just guess? This is the situation im in right now too.
  15. Dec 13, 2017 at 11:17 AM
    Bagow
    Arizona
    2016 DCSB OR 4x4
    Just an educated guess based on what I had read here. Got lucky and all vibrations are gone!
  16. Dec 13, 2017 at 1:41 PM
    Artvandelay
    NY
    17 DCSBOR MGM
    What’s your lift set up?
  17. Dec 13, 2017 at 1:41 PM
    Artvandelay
    NY
    17 DCSBOR MGM
    Wondering too.
  18. Dec 13, 2017 at 1:43 PM
    Artvandelay
    NY
    17 DCSBOR MGM
    What’ll be the issue if they stretch?
  19. Dec 13, 2017 at 1:45 PM
    Artvandelay
    NY
    17 DCSBOR MGM
    Thanks. What’s your
    Lift setup?
  20. Dec 13, 2017 at 1:49 PM
    zippsub9
    Halfmoon, NY
    14 DCLB
    I wouldn’t let this worry you. 90ft/lb and call it a day. You are more in danger of boogering up the fine threads from an impact gun or grit on the threads from the nut than anything associated with bolt stretch.
    2nd Gen, so maybe apples and oranges but extended travel up front with aftermarket UCAs, no diff drop, no carrier bearing drop, ECGS solid spacer. 15 leaf AP EXPO in back with 3* shim, shackles flipped with 12” stroke icons.
