Vibration 5-10 MPH after lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dtrujillo63, Oct 8, 2008.
  1. Oct 8, 2008 at 4:28 PM
    dtrujillo63
    dtrujillo63 [OP] Well-Known Member
    Denny
    Los Angeles
    08 Tacoma DC 4x4 Sport
    I installed 5100's all around and an a Toytec AAL in the rear. I also installed some shims as well. After the install, i notice that the truck has a bumpy vibration coming from the rear between 5-10 MPH. I only notice it when starting from a stop. Any ideas what could be causing this? Should I remove the shims?
  2. Oct 8, 2008 at 5:27 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Its the carier bearing. Get a carier bearing drop, whick is just some spacers. I have a small vibe when accelerating, but it doesnt bother me. I didnt use any shims on the back. Did you install the shims? What direction were they installed?
  3. Oct 8, 2008 at 10:44 PM
    dtrujillo63
    Denny
    Los Angeles
    Damn chris, you sound so certain. I did install the Toytec shims. Arrow up pointing towards the front, the thick part is to the rear of the truck. Above the axes, below the overload leaf. So a carrier bearing spacer should fix the problem? Is it easy to isntall? I'll go ahead and place an order for a set from Toytec.
    -Denny
  4. Oct 8, 2008 at 11:01 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    for the carrier bearing spacers, you could probably go cheap and just use some thick washers for each side that bolts to the frame....same amount for each side. just a thought anyway.
  5. Oct 9, 2008 at 6:11 AM
    106Tacoma
    106Tacoma Well-Known Member
    Debadged 06 Black Sand Pearl 4x4 Every option.
    Im going to have to try this also, My truck is doing the same thing.
  6. Oct 23, 2008 at 2:22 PM
    1bad03snake
    1bad03snake Well-Known Member
    Baytown,TX
    4x4 TRD
    none but please give me your info.
    Mine is doing this also. I'm off Mon-thur next week if I get the tranny swapped in my racecar i'll add a few washers and see what happens
