Vibration after 2" Lift? Help?
Discussion in '1st Gen. Tacomas (1995-2004)' started by agrant2312, Feb 12, 2012.
  1. Feb 12, 2012 at 8:59 PM
    agrant2312
    agrant2312 [OP] Well-Known Member
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    Intake, Flowmaster Exhaust
    Just lifted my truck 2" with a daystar lift. Front spacers rear AAL. My steering is also out of line now since i lifted it? What could be causing the vibration it only vibrates at about 30 mph and under. I can feel it in my steering wheel also.
  2. Feb 12, 2012 at 9:02 PM
    Twistedfreedom
    Twistedfreedom welcome to the incredibuild
    Adam
    Seattle
    in progress
    modded the F*ck out
    what kind of lift did you put on?
  3. Feb 12, 2012 at 9:05 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    You need to drop your carrier bearing about an inch or so & you'll be vibe free...;)
  4. Feb 12, 2012 at 9:05 PM
    VanCity4x
    VanCity4x The shit show
    DJ
    BC
    05 Prerunner SAS
    3link 1tons on 40's and sum stuff
    Got the exact same thing. Got a alignment, going to get it checked when i do my brakes. Daystar 2.5'' strut spacer lift with rear blocks. Vibrations between 18-25 mph. Not something im too conserned about. I can live with it.
  5. Feb 12, 2012 at 9:06 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    OH & get an alignment ASAP for front
  6. Feb 12, 2012 at 9:07 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Same for you, drop the carrier..
  7. Feb 12, 2012 at 9:09 PM
    agrant2312
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    Carrier Drop? Got any how to's or anything on it? Oh yeah it also freaking sucked installing it. The U-Bolts have never been taken off in the back and it too a good 2 hours to get them off.
    Just google'd it just ordered a kit. Will it damage anything the way it is as of now?
  8. Feb 12, 2012 at 9:22 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Theres a couple ways to go about it, you can buy some spacers for it, or you can go a little more advanced & get a carrier drop bracket (more$$)
    Or you can find a couple big nuts,3/4"-1" wide (or tall depending how you look at it) make sure they slide over existing bolts, you want them just slightly over sized so they slide over but not thread on to bolts, this is what I did to cure mine..
    Wow you must have had a fair amount of thread stretch on them, did they re torque ok ? I'd check tightness again also...
  9. Feb 12, 2012 at 9:36 PM
    agrant2312
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    All those sound good ill figure something out with it. Yeah there was which was suprizing. I couldn't really torque them down with how hard it was to get them back on. I didn't cross thread them or anything just rust it would have torqued out at the first push.
  10. Feb 12, 2012 at 10:00 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Oh man , hate to tell you now, but you need new U bolts. You got BAD thread stretch, you'll never get them to torque, it'll strip out before it gets tight, damn hate when that happens & ya don't want to chance having them being loose (which could also cause vibrations)
  11. Feb 12, 2012 at 10:09 PM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I doubt a 2'' lift will cause vibes because driveline angles...most likely just needs an alignment.
    If the alignment does't cure it, then get a carrier drop...and check out the U-joints
  12. Feb 12, 2012 at 10:47 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    Absolutely 2" can cause vibe.. & thats why you drop the carrier, to correct drive angle....
    & OP I wouldn't do shit until I replaced U bolts
  13. Feb 13, 2012 at 9:20 AM
    agrant2312
    Austin
    Nicholasville, KY
    96 Tacoma 3.4l 4X4
    Just dropped the carrier about half an inch and no vibration anymore!!! Got an appointment today at 1 to get it aligned! Thanks guys!
  14. Feb 13, 2012 at 9:33 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    No problem dude, & I'm serious about getting new U bolts, when they thread stretch as bad as yours you are not driving a very safe vehicle, your shit may feel tight but trust me its not...just my $.02
