Vibration after 5100s
Discussion in '2nd Gen. Tacomas (2005-2015)' started by HARGROVE93, Aug 2, 2009.
  1. Aug 2, 2009 at 7:05 PM
    HARGROVE93
    HARGROVE93 [OP] Member
    Dylan
    Millen Georgia
    08 Prerunner SR5 Silver Rugged Trail Package
    BF Goodrich KM2 MT 255/85r16" E-range on Black Tacoma Baja Edition Wheels, Bilstein 5100 adjustable lift shocks @2.5", Digital Designs DD-1500 10"sub woofer, custom 1.5ft^3 slot ported enclosure, Alpine MRP M-1000, 20% tint all around.
    Hey i installed the 5100 shocks in the front and set at 2.5. after a week or so i notice a vibration at highway speeds that feels like my truck is bouncing. I have had a 4 wheel alignment done after shocks were installed and was wondering what the problem is and how to fix it?
    thanks,
    Dylan
  2. Aug 2, 2009 at 7:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    what is your tire pressure set at? and just a heads up...........since the shocks are set as high as they can go, you are gonna have a bit of a harsher ride than stock, since the coil is preloaded as much as it is.
  3. Aug 2, 2009 at 7:12 PM
    Taos1
    Taos1 Well-Known Member
    TRD Sport
    Access Roll Up Tonneau cover, Stainless Steel Sidestep bars, Pop&Lock, Grillcraft black Mesh Grill
    Maybe your wheels are out of balance?
  4. Aug 2, 2009 at 7:13 PM
    HARGROVE93
    Dylan
    Millen Georgia
    My tires are set at 28 to 30 psi. I know it should ride stiffer but it feels like the truck is shaking.
  5. Aug 2, 2009 at 7:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    hmmm. i guess first thing is to check all the mounts and such and make sure everything is tight, then go from there.
  6. Aug 2, 2009 at 7:17 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    FL
    SOLD - 2016 TRD Off-Road 4x4 DCSB
    You might have paid for a 4 wheel alignment, but you only got a 2 wheel alignment...
  7. Aug 2, 2009 at 7:19 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    good catch. the dealership tried making me pay for a 4 wheel alignment.......i called bullshits......that wasnt happening. when i asked them how the hell they aligned the wheels on a live axle.....they just looked dumbfounded and drooled.:rolleyes:
  8. Aug 2, 2009 at 7:19 PM
    HARGROVE93
    Dylan
    Millen Georgia
    Could the 2wheel alignment have caused the vibs?
    As for the wheels being balanced it rode pretty smooth before the lift but it is worse now for sure and i dont know what could have threw them out of balance.
  9. Aug 2, 2009 at 7:22 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well.......first,you can only get a 2 wheel alignment on a truck(live axle has no adjustment), and it "MAY" cause some vibes if they didnt align it right, but chances are something isnt tight as it should be. take pics of the shocks mounted on the coils and post them.
  10. Aug 2, 2009 at 7:22 PM
    SC4333
    Grant
    FL
    It is bull shit because they know damn well what they are doing.
    Better yet, it is stealing.
  11. Aug 2, 2009 at 7:23 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yep....cause most folks dont pay attention,or they dont know any better.
  12. Aug 2, 2009 at 7:23 PM
    SpaceMonkey
    SpaceMonkey Well-Known Member
    Houston, Tx
    06 PreRunner
    Did you lift the rear at all?
  13. Aug 2, 2009 at 7:26 PM
    HARGROVE93
    Dylan
    Millen Georgia
    The rear is stock height.
  14. Aug 2, 2009 at 8:30 PM
    Simon2150
    Simon2150 Well-Known Member
    Austin, TX
    06 Tacoma DoubleCab V6 SR5
    So do you have a forward rake higher in front? If u r vibing at hwy speeds I'd get tires rebalanced
  15. Aug 2, 2009 at 8:35 PM
    Tacoyota
    Tacoyota senile member
    North of Cali, South of Canada
    08 4wd
    4.56 gears, rear trutrac,DT header, 235/85r16 Duratracs, 2nd filter pulled, inter.wipers, Cruise control, Factory alum. whls/winter tires(2nd set), Afe pro Dry-S , Dumbo eared flaps cut down.
    I'd Read the lift sticky on uca's, says if you lift over 1-2 or so u need to get new upper control arms.
  16. Aug 3, 2009 at 6:52 AM
    HARGROVE93
    Dylan
    Millen Georgia
    The front is slightly higher maybe .5 to.75 inches higher.
  17. Aug 3, 2009 at 7:32 AM
    OH-MAN
    OH-MAN Well-Known Member
    Sunny Az.
    10 4X4 O.R. White
    TRD skid painted black,
    If the vibration is around 60 it most likely is ballance.
    That seems to be the speed it is most noticeable at.
  18. Aug 3, 2009 at 9:04 AM
    flyingface
    flyingface Well-Known Member
    Zach
    Auburn, AL
    2013 MGM DCLB TRD Sport 4x4
    Soon....
    I would get your tires balanced before you start toying with the idea of UCA's. I needed them at 2.5", but every truck and people's tolerance of handling characteristics are different.
  19. Aug 3, 2009 at 10:41 AM
    HARGROVE93
    Dylan
    Millen Georgia
    Yea i dont notice it except speeds above 50 so they might be off balance. How much are UCAs?
  20. Aug 3, 2009 at 11:20 AM
    Padilla1880
    Padilla1880 "Let's Ride!"
    Daniel
    Temecula, CA
    05 TRD OffRoad V6 SR5 PreRunner
    Does it feel like your whole truck is or is there a shimmy with the steering wheel at that speed? UCA's 400-1000 depending on what you go witih. LR, TC, Camburg, Icon
