Vibration after AAL (tried carrier bearing drop and 3 degree axle shims)
Discussion in 'Suspension' started by nammer, Feb 7, 2013.
  1. Feb 27, 2014 at 10:43 AM
    #41
    TacoRob08
    TacoRob08 Well-Known Member
    Rob
    Fredericton, NB, Canada
    17 Sport DCLB
    gibson exhaust, OVTuned base 91, AFE intake
    OK, now I removed the 3/4 spacer and installed 1/4, vibration at 40 is now gone. Had all my u-joints in rear shaft check and all are free, not loose and not seized. Play in my slip yoke splines, packed grease and vibration is about half of what it used to me at 20kmh. It's annoying but liveable.
  2. Mar 2, 2014 at 11:10 AM
    #42
    rruhl48
    rruhl48 Active Member
    Rick
    union county NJ
    07 access AFE 3 inch volant ram air. sounds.p
    AFE 3 inch sounds amazing.. volant ram air intake
    Ok guys I'm.lifting my 07 sr5 bilstien 5100s and fox 3 inch rear long aal dif drop spacer skid plate spacer drop carrier bearing spacer sway bar drop brackets I know I need new brake lines and haven't heard much about proportioning valve will look into and the e brake extensions?. Going cooper atp lr e 265 75 16 on stocks for now my real question is can I put the 5100s on there stock hight or even like .80 or 1.75 and put.2 inch leveling lift spacers on top to help give them more extension and keep my stock ucas thanks any opinion at this point really helps
  3. Apr 6, 2014 at 5:16 AM
    #43
    Ricks2013
    Ricks2013 Well-Known Member
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    I just installed a 3/4" driveshaft spacer from 4crawler and it took away ALL my vibrations. I really only had a slight shudder at take off before but it rides so much smoother now that I put that spacer in. My yoke is now flush with the transmission housing like it should be. My lift in rear consists of a 2"tapered block with 1.5"aal. If you have any questions about measurement for spacer hit me up. There are many different sizes of flange bolt patterns for same year tacomas(1mm difference!).
  4. May 21, 2014 at 10:16 AM
    #44
    TacomaJay09
    TacomaJay09 Well-Known Member
    Central MA
    09 TRD Sport Dbl Cab
    None Yet
    I'm dealing with a take off shudder after changing to an HD leaf pack. I had seen some of the threads about adding a spacer wondering if would be the missing piece to the puzzle. Do you have any pics that you could share of how things line up now?
  5. May 21, 2014 at 10:54 AM
    #45
    gearcruncher
    Canadain bumper technician
    Once again the proper way to check a universal joint and the only way to properly check universal joints is by removing the driveshaft and manipulating each universal joint by hand . You cant tell if there are tight spots in the universal joint by grabbing the driveshaft and twisting it while the driveshaft is on the truck . All it takes for a vibration is 1 seized cup and there are 4 cups on each u-joint . If the u-joints were properly checked at the start , this would have been a much shorter thread and a lot less thread jacking .:D
  6. May 21, 2014 at 11:21 AM
    #46
    Ricks2013
    Rick
    Orlando, FL
    13' TRD Sport DCSB
    A few things
    PM sent
