Vibration after adding a leaf to the rear
Discussion in '3rd Gen. Tacomas (2016-2023)' started by larrywa, Apr 10, 2021.
  1. Apr 10, 2021 at 1:27 PM
    larrywa
    larrywa [OP] Well-Known Member
    2020 Tacoma TRD Sport
    2020 Tacoma Sport
    3" ReadyLift in Front, 2" Readylift in the front
    Had a dealer add a ReadyLift add-a-leaf which added about 1.5-2.0 of lift in the back.
    I've noticed now that when I accelerate from a dead stop, a vibration that goes away at 15+ MPG and I never feel it when accelerating while moving at some mph.
    I've also noticed that if I push down on the tailgate like I'm trying to bounce the back of the truck, there is a bumping noise which seems to be coming from under the truck about midway up the vehicle.
    Could the new leaf spring be causing this? (The vibration or bumping)?
    Thanks!
  2. Apr 10, 2021 at 1:29 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Did you do the Carrier Bearing drop kit?
    71tattooguy and Big tall dave like this.
  3. Apr 10, 2021 at 1:31 PM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
  4. Apr 10, 2021 at 1:32 PM
    larrywa
    Looking at the dealers itemized list, I don't see that on there.
  5. Apr 10, 2021 at 1:34 PM
    RatDaddy
    Roy
    None
    I am pretty sure they won't recommend anything, they just do what you want them to
    Mark77 likes this.
  6. Apr 10, 2021 at 1:36 PM
    larrywa
    Since I am not pleased with the overall quality of the ride, I suppose the cheapest thing to do is have them remove the add-a-leaf to take it back to the lift it was. Off the top of my head, I don't believe I felt the vibration with just the 2" block lift...maybe because it was somewhat level with the front (not sure that's the science of it).
    TAC1 likes this.
  7. Apr 10, 2021 at 1:38 PM
    RatDaddy
    Roy
    None
    Typically, lifting changes angles which can induce drivetrain vibration. The items you need to make it right, aren't expensive, but if you don't like the ride in the first place, then spacer lift on stock suspension might be for you.
    71tattooguy likes this.
  8. Apr 10, 2021 at 1:39 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    Is everything tight and correctly installed? Sounds like it's time to inspect and find out what's bumping
  9. Apr 10, 2021 at 1:40 PM
    larrywa
    No see, its going to cost me at least double. 1. The cost of buying the add-a-leaf and having it installed. 2. The cost of having the add-a-leaf removed 3. The amount of money I now have to hand my wife that equals 1 and 2.
    RatDaddy[QUOTED] likes this.
  10. Apr 10, 2021 at 1:40 PM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Check the torque on your ubolts.
  11. Apr 10, 2021 at 1:42 PM
    RatDaddy
    Roy
    None
    lol, you are right about that. I was making the suggestion to fix the problem, might be economical. How about taking it back and asking them to tell you why there is a vibration, they may cut you a break.
    Mark77 likes this.
  12. Apr 11, 2021 at 1:00 AM
    Taco_Kev808
    Taco_Kev808 Instagram: Rillo_kev
    Kevin
    Washington
    2016 MGM DCLB Limited
    I 2nd this. The angle of the driveline has changed. I had to add a spacer on my driveshaft carrier bearing. The part is 30 bucks and is only 2 bolts
    Mark77 likes this.
  13. Apr 11, 2021 at 4:07 AM
    larrywa
    I'll see if they can check this out tomorrow. I'm not sure this is related to the noise I hear when I push the tailgate up and down or not but I know when I hit any bump in the road I can hear a booming sound coming from the rear end area....sort of like what you'd hear if the backend was bouncing and had no suspension. I knew the ride would be stiffer, but this is a bit more than I can tolerate because I don't carry loads in it all the time.
  14. Apr 11, 2021 at 4:30 AM
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Vibration is likely your angles being off. Do like @Unchained 5150 said...$30 for carrier bearing drop. Installs in minutes. As far as bumping, sounds like something was not torqued proper. Check your spare was raised all the way.
    Side note, you now lifted the rear 3-4". What are you running for shocks back there and hope you got longer brake lines. Probably need longer lines and 5125s or something longer than stock back there. Good luck let us know
    Chew and th3118 like this.
  15. Apr 11, 2021 at 4:38 AM
    larrywa
    Running standard OEM shocks. I was wondering if that noise was the shocks hitting the top of their limit. Standard brake lines. Looks like I may just be having them remove the add-a-leaf with all this crap going on, don't need it that bad anyway.
  16. Apr 11, 2021 at 4:42 AM
    aceman4
    aceman4 Well-Known Member
    South FL
    2018 DCSB 4x4 Off Road - Cement
    Take it back and have the dealer solve the noise problem. Maybe they hosed the AAL install. With a 2" block and AAL your driveline angles are hosed and you may need a carrier bearing drop and/or axle shims to solve the vibration.
  17. Apr 11, 2021 at 11:06 AM
    Taco_Kev808
    Kevin
    Washington
  18. Apr 11, 2021 at 11:09 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    Carrier bearing for sure.
    Coming from an Xterra, do you guys also ever use shims with leaf packs? A 3 degree ahim always solved vibration issues in the X when i replaced leaf packs or did an aal.
  19. Apr 11, 2021 at 11:14 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Sounds like a stock suspension might be the best choice for you
  20. Apr 11, 2021 at 11:23 AM
    Taco_Kev808
    Kevin
    Washington
    I used a carrier bearing drop and called it good lol
