Vibration after heavy leaf spring install
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoSupreme_88, Jan 14, 2023.
  1. Jan 14, 2023 at 11:42 AM
    TacoSupreme_88
    TacoSupreme_88 [OP] New Member
    2021 Cement Tacoma TRD Sport 4x4
    Softopper, datin fab rack, prinsue roof rack, RC 3 in lift, ironman heavy leaf springs
    So I just installed ironman 4x4 heavy rated leaf springs ahead of the arrival of my decked system. Now im getting a vibration between 20-30mph. I understand some angles may be off and that could be the culprit but once I get the decked system installed will the extra weight correct the issue?
  2. Jan 14, 2023 at 11:43 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    there's a good possibility the extra weight will improve the ride. i know my truck rides a lot better with a bunch of weight in the bed.
    TacoSupreme_88[OP] likes this.
  3. Jan 14, 2023 at 11:44 AM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    I had to install a 4 degree shim at rear axle to correct minor vibrations at about same speed. Running medium dobinsons leafs at 2” lift.
  4. Jan 14, 2023 at 12:10 PM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    Rule of thumb is 1 degree per inch of lift for rear lift.
    Rusty66, sbx22 and TacoSupreme_88[OP] like this.
  5. Jan 14, 2023 at 1:30 PM
    mines
    mines Well-Known Member
    I'm running their medium duty pack with 3 degree shims. no vibrations, maybe try adding in some 3-4 degree shims.
