Vibration after level kit install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Phab Ej, Feb 24, 2014.
  1. Feb 24, 2014 at 8:56 AM
    Phab Ej
    Phab Ej [OP] Member
    Mudskipper
    South Carolina
    '13 Sprt Debadged
    18 inch Gear wheels, 2.5 inch level kit w/ .750 inch rear block lift
    Hello All,
    I recently installed a 2.5 inch spacer lift in the front and 1 inch blocks in the rear.
    I immediately notice vibrations when driving. It occurs only in the first 10 miles or so of driving then goes away.
    There are no differential drop kit installed.
    Does anyone here know what could be causing the vibrations? Does NOT having the wheels aligned yet have anything to do with this??
    2013 Tacoma 4WD, TRD Sport
  2. Feb 24, 2014 at 9:00 AM
    Yotabilly
    Yotabilly Well-Known Member
    The Bluegrass
    2013 4cyl,5spd.4x4 Reg Cab
    UWS low profile toolbox, tint, rainguards, color matched grill surround 265/75r16 Goodyear Duratracs Ultra-Guage XB fogs, Weathertech Floor Liners, OME 884s, 2"AAL, Bilstein 5100s, FJ Trail Team wheels, Matt123 skid plate, 30" light bar, Rigid Duallys, Bed extender
    At what speed does the sound appear?
  3. Feb 24, 2014 at 9:59 AM
    Phab Ej
    Phab Ej [OP] Member
    Mudskipper
    South Carolina
    '13 Sprt Debadged
    Vibration occurs at low speeds, 15-35 mph
  4. Feb 24, 2014 at 11:07 AM
    Yotabilly
    The Bluegrass
    Does it feel/sound like it's coming from the driver's side?
  5. Feb 24, 2014 at 11:19 AM
    aubi1414
    aubi1414 War Eagle!!
    Justin
    Pensacola, FL
    2014 Tacoma TRD Sport Blue Ribbon Metallic
    LED Dome, LED Map, LED License Plate Bulbs, , Konig SixShooters Matte Black, Toyo Open Country ATII's 285 70 17, Satoshi, Bilstein 5100s (set to 0), 885s, LR UCA's, Icon RR 2.0 +2, All Pro Standard 3" Leaf Pack, All Pro Flip Kit, Sway Bar Relocate, Exhaust Chop, Antenna X 14", Debadged, Tint, Matt123 Black TRD Skid, Black Weathertech Mats
    Axle wrap welcome to lift issues. Yes aligning will help a bit, but mine does the same thing. An AAL or Leaf pack should fix that problem
  6. Feb 24, 2014 at 9:06 PM
    Phab Ej
    Phab Ej [OP] Member
    Mudskipper
    South Carolina
    '13 Sprt Debadged
    Vibration comes from front wheels.
    Just ordered drop kit, will install and update thread if issue is fixed or not. Next, an alignment I guess.
    100% paved, no need for $$-$$$ lift.
  7. Feb 24, 2014 at 9:09 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    Yeah... have fun replacing all sorts of stuff when you donk your diff due to the drop kit.
    The vibes are likely from the rear blocks and not the front.
  8. Feb 24, 2014 at 11:29 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    You must have missed this ^^^
    100% Paved Driving.
  9. Feb 25, 2014 at 5:27 AM
    Phab Ej
    Phab Ej [OP] Member
    Mudskipper
    South Carolina
    '13 Sprt Debadged
    Ill just slap the diff drop kit then test run. If it ain't fix the problem it's coming right off. Thanks guys
  10. Feb 25, 2014 at 9:10 AM
    Skeeter Skeetin
    Skeeter Skeetin Well-Known Member
    Greg
    Daphne, AL
    MGM 4x4 V6 6 speed
    5100's all around w/ 1.75" front. 1.5" Toytec AAL ARE shell with roof rack. Weathertech vent-visors and floormats 20% tint on front. Black and charcol wet okole's VLED V3 Triton DTRL's/turn signals. ECGS bushing
    Sounds like the same problem I have in my 2012. Put it into 4x4 when you feel the vibes. They should go away. If they do it's the drivers side needle bearing that has too much play in it. Search ECGS for a bushing that fixes the problem in pretty much 100% of the cases. If it doesn't go away in 4x4 it's something else.
  11. Feb 27, 2014 at 5:13 AM
    Phab Ej
    Phab Ej [OP] Member
    Mudskipper
    South Carolina
    '13 Sprt Debadged
    Skeeter, I started the truck out this morning in 4WD as you stated, sure enough the vibration did not occur. Several miles later I put it back in 2WD and the vibes came right back – strange.
    I will follow with your suggestion for the remedy, (although I have no clue what it is yet). Thanks, this forum has been very helpful.
  12. May 15, 2014 at 5:13 PM
    05yoter
    05yoter Active Member
    Joshua
    Connecticut
    Tacoma 4x4
    3" Supreme Suspension Lift Kit, Bilstein 5100, K&N, Curtis Tatton driveshaft, Detroit Trutrac, some other doodads...
    hey everyone, been reading up alot on the vibration issues everyone is having after lift or leveling kits. I have a 2005 Tacoma reg cab 4cyl manual. I just installed a Supreme Suspension 3" lift. The kit included diff drop, rear shims with blocks, and I threw on Bilstein 5100's. After the lift, I was getting a bad rattle coming from the 3rd member. Just bought a new one from ECGS and rattle went away, but still getting some vibration. Doesnt seem to be coming from the front, definitly feels like the rear, almost like my driveshaft is a little off balance. With that said, I also have not yet had alignment done, wanted to wait until I pick up new tires (BF 255/85R16's). what advice can anybody give me? should i go ahead and order the front bushing kit from ECGS?
  13. May 16, 2014 at 8:01 AM
    Phab Ej
    Phab Ej [OP] Member
    Mudskipper
    South Carolina
    '13 Sprt Debadged
    strangely after all my bitchin about the vibes, it has gone away since the weather got warm - never did anything to fix it. Strange but great! The last two months have been good. My luck is... the cold weather had a factor on the vibes.
  14. May 16, 2014 at 7:28 PM
    mainewoodsballer
    mainewoodsballer YESSAHBUD...heyut
    Ol' Waltah
    Maine
    2015 DCLB TRD Sport (Pyrite Mica)
    Check out my Build to See!
    weird.. hows it ride with the spacer lift?
  15. May 19, 2014 at 5:08 AM
    Phab Ej
    Phab Ej [OP] Member
    Mudskipper
    South Carolina
    '13 Sprt Debadged
    No difference on road. of course I will admit that I ride 100% on the road, lift is primarily for looks.
    ...yeah yeah, I know what you off roadies gonna say.
