vibration after lift install
Discussion in '1st Gen. Tacomas (1995-2004)' started by wheeler3129, Feb 4, 2012.
  1. Feb 4, 2012 at 12:10 PM
    wheeler3129
    wheeler3129 [OP] Well-Known Member
    Lexington, NC
    2003 Tacoma SR5 4x4
    I need some help, Just installed spacer lift up front, Procomp AAL with 0-2" skyjacker shocks in the rear. Put on 285/70 17 BFG MT's with eagle alloys and I am experiencing some bad vibration at around 20 mph and I know it is not the tires because this occured after the lift was put on but before the MT's were added. I have also front diff. drop at the time of the lift.
    thanks for any help
  2. Feb 4, 2012 at 3:11 PM
    Phuket
    Phuket Well-Known Member
    Travis
    Los Angeles
    03 4X4 TRD
    Eibach/Toytec coils, bilstein 5100's all around, Kenwood DNX7100 Navigation
  3. Feb 4, 2012 at 3:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Check out my drive line vibe thread in the cheap free more section. Some carrier bearing spacers should help you out.
  4. Feb 4, 2012 at 5:45 PM
    wheeler3129
    Lexington, NC
    2003 Tacoma SR5 4x4
    thanks for the reply, I went to the web site and printed out the drop kits. Are these hard to do? Do you alot of people have to do this because as soon as the lift was put on and I drove it for the first time it did this.
    thanks.
  5. Feb 4, 2012 at 5:46 PM
    wheeler3129
    Lexington, NC
    2003 Tacoma SR5 4x4
    thanks for your help I will definitely check this out!
  6. Feb 4, 2012 at 5:47 PM
    wheeler3129
    Lexington, NC
    2003 Tacoma SR5 4x4
    they just got recently checked and they were fine so I am not sure.
  7. Feb 4, 2012 at 5:47 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    BINGO! Change out the Carrier Bearing while you're there (unless it's ok)
  8. Feb 4, 2012 at 5:51 PM
    wheeler3129
    Lexington, NC
    2003 Tacoma SR5 4x4
    is there a thread posted that refers to this and how to put it on.
    thanks
  9. Feb 4, 2012 at 6:15 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Carrier bearings are pressed on and off. I'll just about guarantee you that adding quarter inch spacers between the carrier bearing bracket and peaked will take care of your problem.
  10. Feb 4, 2012 at 6:51 PM
    wheeler3129
    Lexington, NC
    2003 Tacoma SR5 4x4
    I don't mean to be ignorant but the 1/4' spacer your speaking of would you do this instead of the CB drop kit or both or is it the same thing?
  11. Feb 4, 2012 at 7:19 PM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    If your truck is sounding like that I bet the bearing is dead. Replace the bearing with a new one and install the drop. You'll be cruising happy. 1/4 drop and cb drop kit is the same thing.
  12. Feb 4, 2012 at 7:26 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Yep.....quarter inch slavery is same as cb drop kit......just way cheaper to do.....and has same effect. BTW.....I sell spacers that I make. $15 for a set shipped to you.
  13. Feb 5, 2012 at 11:07 AM
    wheeler3129
    Lexington, NC
    2003 Tacoma SR5 4x4
    let me know more about that spacers that you make
  14. Feb 5, 2012 at 11:52 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
  15. Feb 5, 2012 at 12:45 PM
    Phuket
    Travis
    Los Angeles
    03 4X4 TRD
    the spacers will work just like the carrier bearing drop kit and probably cheaper. i suggested the drop kit because most of the time spacers are the devil around here
  16. Feb 5, 2012 at 1:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    Lol.......the spacers for coilovers are.
  17. Feb 5, 2012 at 1:25 PM
    wheeler3129
    Lexington, NC
    2003 Tacoma SR5 4x4
    thanks it sounds so simple but it sounds like it works great, I really appreciate yalls input.
    thanks
