Vibration after lift
Discussion in '1st Gen. Tacomas (1995-2004)' started by Abes, Mar 21, 2011.
  1. Mar 21, 2011 at 7:49 PM
    Abes
    Abes [OP] Member
    Miami
    '03 4x4 Tacoma
    I recently lifted my '03 DC and noticed that I have a vibration between 20-30 mph. It's very strange as it only happens during that speed wether slowing down or speeding. I dropped the front diff an 1'' during the lift and got an alignment as well. The tires are brand new and it never did it prior to the lift. It almost feels like its coming from the driveshaft.
    Anyone have something similar happen?
  2. Mar 21, 2011 at 10:06 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 Auto Trans With Lots of Mods King Extended Travel COs Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Alcan Custom 8-Leaf Rear Spring Packs Fox 2.0 Resi Rear Shocks FrankenFab Rear Shock Relocate All-Pro U-bolt Flip w/Timbren bumps Toytec 1" Extended Shackle 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Gunmetal 16x8 SCS Ray10s 285/75r16 Cooper STT Pros Limited Edition Relentless Front Bumper Smittybilt X2O 10K Winch 3" LED Pods w/Amber covers in the Bumper 22" Single Row LED Bar on the Bumper Mini D2S Projectors XB35 Ballasts + 4500K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Whynter 65 qt. Fridge/Freezer CVT Mt Bachelor RTT Badland Custom Bed Rack GM 140 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Magnaflow 18" Muffler 13WL Brake Calipers Braided Steel Brake Lines AFE Pro Dry S air filter ScanGauge II OBDII Scanner Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    What kind of lift do you have? Did you also lift the rear?
    Post lift I had a very similar vibe. I dropped the carrier bearing about .5" and it cleared it up.
  3. Mar 22, 2011 at 2:58 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    thats most likely all ya need OP,just to change the pinion angle a degree or so. axle shims or a CB drop will fix you up.
  4. Mar 22, 2011 at 4:38 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    ^^^^not sure if it will damage anything,try lowering the cb about 3/8'' see if that helps man. vibes suck.
  5. Mar 22, 2011 at 4:50 PM
    BlueSteel
    BlueSteel Well-Known Member
    James
    The Woodlands, TX
    09 Magnetic Grey Doublecab TRD Sport Debadged
    Camburg 4" Spindles, Icon CB 2.5 adjustables front and rear, Total Chaos Upper/Lower CAs, Alcan 5" Rear Leafs, Timbren Bumpstops, 5" SS Brakelines, 295/70/18 Nitto Trail Grapplers on 18" KMC Monsters, Grill Craft Black Mesh Upper, Predator Running Boards, All Pro Rear Bumper and Hitch, Wet Okole Covers, Toyota Roof Rack, Limo Tint, TRD CAI, TRD Exhaust, Weathertech Mats, Redline Hood Struts, Red Top Odyssey battery, BDF Light Bar, Foglight anytime Mod, Lo Pro QT Truxedo Tonneau cover, Rocky Mount Bike Pegs.
    Do the Carrier Bearing drop block first because it only takes about 5-10 minutes to do, that should clear it up. I had a little vibration around 15 mph and the that cleared it up on my 2nd Gen. I would do the shims last if it is persistant because they take a little bit longer to do. You will have to seperate the leaf pack and install the shim and maybe a new longer centering bolt.
  6. Mar 22, 2011 at 5:03 PM
    shitroc
    Ant
    2002 Tacoma TRD 4X4
    no write up but heres some pics
    pics from moderator tacomaman06's gallery
  7. Mar 22, 2011 at 5:13 PM
    BlueSteel
    James
    The Woodlands, TX
  8. Mar 22, 2011 at 5:52 PM
    BlueSteel
    James
    The Woodlands, TX
    I actually found the CB bracket to help more and it was easy to install on my 2nd Gen. The shims may or may not solve your problem. Do the CB drop block first.
  9. Mar 22, 2011 at 9:09 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Dropping the carrier bearing is by far the simplest and easiest mod I have done to my truck. :rolleyes:
  10. Jan 8, 2013 at 2:43 PM
    CajunBug73
    CajunBug73 Member
    Paul
    Milwaukee, WI
    2011 Tacoma 4x4 Base Single Cab
    I just got a 1.50" lift done to my 2011 Tacoma and I am getting a very slight humming/vibration at about 50 to 60 mph. Not sure what this is, never had it before. And , where is the Carrier Bearing if it is the problem, not sure where the bearing is. Thanks in advance!
  11. Jan 8, 2013 at 9:03 PM
    AggiePilot12
    AggiePilot12 Well-Known Member
    Texas
    03 4x4 6" Double Cab
    6" Fabtech, All-Pro Leafs, Cold Air, Cat Delete
    Had this after I first installed my original 3" lift. Exact same vibe problems y'all just mentioned.
    Save your time, I have searched this place dry.
    It's not the drive shaft, your CV joints aren't running at stock angles. Your front diff needs to be dropped even more. Fixed my vibes immediately.
  12. Jan 8, 2013 at 9:23 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Have you had a front wheel alignment done since doing the lift? The carrier bearing is the center support bearing on your rear driveshaft.
    I would agree that the higher speed vibe is likely in the front end not the rear driveshaft. And on a 1st gen, a diff drop can be an effective solution. Unfortunately for 2nd gens, it is not nearly as effective because of the design of the 2nd gen diff.
  13. Jan 9, 2013 at 7:15 AM
    Seventh
    Seventh Insert witty title here
    Boston, MA
    2001 Reg Cab 4x4
    Sub'd.
