Vibration after lift
Discussion in 'Suspension' started by TRD2006, Feb 27, 2013.
  1. Feb 27, 2013 at 4:19 PM
    TRD2006
    TRD2006 [OP] Well-Known Member
    stock 2006 4x4 TRD Sport
    I am getting courious of what could cause my vibration on my truck after the lift... I put the bilstein 5100 set all the way up and got about around 2.5" of lift. I've read many threads about this issue, it could be the center carrier bearing or it could be the u joints... I tried dropping the center carrier bearing and it didn't do much... I get the vibration from 25-40mph, I'm not sure if I didnt drop it enough or is there any thing else to try?
  2. Feb 27, 2013 at 4:23 PM
    evanmb31
    evanmb31 Well-Known Member
    evan
    connecticut
    09 trd off road
    Satoshi'd grill. blacked out badges. aftermarket sound system. De-chromed and color matched. OME 885s + Dakars with 3rd leaf removed. LR UCAs. Scs stealth 6 with 285 duratracs. BAMF sliders
    did you do AAL in the rear? if you left the rear stock carrier bearing drop is pointless and could cause more vibrations
  3. Feb 27, 2013 at 4:26 PM
    TRD2006
    Yes I did raise the rear with an add a leaf, I'm just wondering how people have a lift that is taller and have no problems. Its a 2" add a leaf.
  4. Feb 27, 2013 at 4:26 PM
    evanmb31
    evan
    connecticut
    09 trd off road
  5. Feb 27, 2013 at 4:32 PM
    TRD2006
    Okay, I honestly kinda forgot I started that thread, oops! Well it feels like its coming from the rear... I use to get it from a dead stop till about 10mph, but it stopped that when I put the washers in.
  6. Feb 27, 2013 at 4:34 PM
    evanmb31
    evan
    connecticut
    09 trd off road
    haha its cool no worries. so it does sound like its being caused by your driveshaft then. you should try axle shims. and your positive it isnt your tires being unbalanced?
  7. Feb 27, 2013 at 4:39 PM
    TRD2006
    Yea I'm positive, it shakes like your driving on wash boards. But with both tires.
  8. Feb 28, 2013 at 7:52 AM
    TRD2006
    I'm just courious if the carrier bearing may not have gotten lowered enough, I dropped it about 3/8"
  9. Mar 1, 2013 at 8:00 PM
    TRD2006
    Okay so I dropped the carrier bearing down to about an inch, it didnt do much all, what is the best way to check if its the front or the rear?
  10. Mar 2, 2013 at 7:03 AM
    evanmb31
    evan
    connecticut
    09 trd off road
    Well you could put it in 4wd then pull the driveshaft making your truck front wheel drive haha. Try reading up on axle shims, i have heard of a few cases that the CB drop didnt work and axle shims did.
  11. Mar 5, 2013 at 11:54 AM
    TRD2006
    I took my truck to inland truck parts today, the deal with drivelines and other mechanical aspects... The told me my driveline needs to be a little longer so I could add some length to it or get a 1 piece driveline... Does this sound like something I may need on a 2.5" lift?
  12. Mar 5, 2013 at 6:47 PM
    coseng
    coseng Well-Known Member
    Grove City, PA
    2011 TRD DC
    OME 885x front, Dakars rear, LR UCAs, ECGS bushing
    Are you sure it isn't the front? Try switching into 4hi and see if the vibes go away.
  13. Mar 6, 2013 at 9:20 AM
    TRD2006
    I'm pretty sure, I put it in 4hi today and drove a little around town and I still got the vibration
  14. Mar 6, 2013 at 9:23 AM
    650H1
    650H1 Well-Known Member
    NH
    2010 Tundra TRD OR C/M 5.7l 4x4
    people dont lift and have no vibes, we live with it because there is nothing wrong. i bought a beefed taco cb drop, and it cured my vibes. put like 2 or 3 washers between your cb and mount and see how it does. also, make sure your leafs are torqued to 90 ft lbs.
    if youre still not happy, you need a 1 piece DS.
  15. Mar 6, 2013 at 10:34 AM
    TRD2006
    I understand that there may be alittle vibe but this is pretty bad, by lowering the cb the 0-10 vibe has Gina away
  16. Mar 6, 2013 at 1:27 PM
    TRD2006
    The leaf pack or the ubolts?
  17. Mar 6, 2013 at 4:02 PM
    650H1
    NH
    U bolts. Toyota only states to set them to like 37ft lbs but we have figured out that that is a typo. And should be 73, but be safe and go with 90.
  18. Mar 6, 2013 at 4:30 PM
    TRD2006
    Okay, I retorqued everything today, my ubolts where loose, but I still have some vibs I just don't understand if it was a little its one thing but this just doesn't seem normal
  19. Mar 11, 2013 at 9:09 AM
    TRD2006
    those of you guy with a beefed cb how much of a drop does it at on the cb?
  20. Mar 11, 2013 at 10:51 AM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    The vibe is from the change in driveshaft angle. The ujoints must rotate faster the higher you lift it.
    3-4 degree shims for the rear axle, and a 1 peice driveshaft should cure it. Start with shims.
