Vibration after lift
Discussion in '2nd Gen. Tacomas (2005-2015)' started by yellow_bandit, May 27, 2018.
  1. May 27, 2018 at 11:39 AM
    yellow_bandit
    yellow_bandit [OP] Well-Known Member
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I just put on a 2 inch lift with Bilstein, coils, and 3 leaf. I now have what feels like a humming through the floorboard. It oscillates, hums for a second then goes away and repeats. Doesn't change much with speeds. goes away when I go into 4 hi. Also disappears after about 5 minutes of driving. Thought an alignment would fix it but no luck. What could this be?
  2. May 27, 2018 at 11:47 AM
    hyper15125
    hyper15125 Headlight Retrofitting Hobbyist Vendor
    NJ (609)
  3. May 27, 2018 at 11:47 AM
    hyper15125
    NJ (609)
    I just did mine at 32k and the noise went away.
    Freeheelbillie likes this.
  4. May 27, 2018 at 11:56 AM
    Boneretreiver
    Boneretreiver Well-Known Member
    Tom
    Eastern WA.
    2010 AC TRD Sport 4x4
    Get underneath and grab the driver’s side inner cv joint where it goes into the front differential. Check for play. You will be surprised what you find. Hyper15125 is correct I believe. When I did this check on my daughters 2010 AC 4x4 the next thing I did was order a bushing from ECGS and a seal. Have never had a repeat for 3 years.
  5. May 27, 2018 at 11:58 AM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    How hard is it to do the ECGS? Do I need special tools?
  6. May 27, 2018 at 12:02 PM
    Boneretreiver
    Tom
    Eastern WA.
    Not hard if you are a backyard mechanic type. And yes, you will need a bearing puller and something to push the new seal in. There is a great write up and video here in tacoma world that will answer all your questions. Plan on replacing some diff fluid as there will be some drained out why doing this. Did you try the play test yet? I will try and find the write up and get it to you.
  7. May 27, 2018 at 12:06 PM
    replica9000
    replica9000 Das ist no bueno
    Lake Chargoggagoggmanchauggagoggchaubunagungamaugg
    2019 T4R ORP
    You'll need the removal tool to get the old bearing out. I think I had borrowed it from @johnnym
  8. May 27, 2018 at 12:08 PM
    Boneretreiver
    Tom
    Eastern WA.
    Look for “front diff vibes ecgs bushing fix” in 2gen forums. The first post also has a link with a video I believe that will spell the process out for you. Many Taco owners on here have already did this so there is PLENTY of help if needed. There are some that have the tool made by ECGS and are willing to loan or sell to you for less than the cost. Just decide what you want to do and then, do some searching here. You will get all the info you need.
  9. May 27, 2018 at 12:15 PM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    If it's the ECGS, would the vibration go away from driving? That's what confuses me.
  10. May 27, 2018 at 12:19 PM
    Boneretreiver
    Tom
    Eastern WA.
    EGCS stands for East Coast Gear Supply. They developed a bronze bushing to replace the front, drivers side cv needle bearing. If you havent done the slop/play test yet, you really need to. Once 4x4 is selected, the front diff driving the axles takes most of the play out because it is under a load.
  11. May 27, 2018 at 12:24 PM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    Just did the play test and there is very little movement. Just enough to make a knock.
  12. May 27, 2018 at 12:25 PM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I'd say about 1/8" of play
  13. May 27, 2018 at 12:28 PM
    RicanTacoma
    RicanTacoma Well-Known Member
    Andres
    Fountain, Colorado
    2014 DCSB OR
  14. May 27, 2018 at 12:58 PM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    Boneretreiver likes this.
  15. May 27, 2018 at 2:26 PM
    Nomad_Pilot
    Nomad_Pilot I need to pewp
    Clay
    Ft Collins
    Yeah. Mine let loose and I couldn't go over 30 mph, after the ecgs bushing install, it still vibrates till the oil warms up and gets thinned out, then my vibs go away.
  16. May 27, 2018 at 2:28 PM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I think there's a guy in here that doesn't live to far from me that installs it for $50. I PM's him to see what I need to order.
  17. May 27, 2018 at 2:31 PM
    Nomad_Pilot
    Clay
    Ft Collins
    Dude thats a deal. Some guys are paying $300 for that install. Be sure and order a replacment outer seal.
  18. May 27, 2018 at 2:33 PM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I think that's all I need, the CV axle seal. He should have all the tools so $80 for the bushing and seal and $50 to install .that's not bad at all. I'll throw in a case of beer as well.
  19. May 27, 2018 at 3:43 PM
    replica9000
    2019 T4R ORP
    Make sure you don't replace the seal backwards like I did
  20. May 27, 2018 at 4:43 PM
    yellow_bandit
    MA
    2013 TRD Sport DCSB
    HS 2" Lift Kit
    I just ordered the bushing from ECGS. Thanks everyone. TACOMAWORLD saves me again
    Pigpen likes this.
