Vibration after new wheels?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2ndGenTacomaHI, Mar 23, 2020.
  1. Mar 23, 2020 at 10:45 AM
    2ndGenTacomaHI
    2ndGenTacomaHI [OP] Member
    2015 Tacoma Prerunner
    Hi everyone,
    So here’s the situation I’m in. On Friday I got new wheels. Michelin LTX AT2. 265/65/r17. Not aggressive AT wheels but my first time getting AT. I understand that there could be a bit more vibration but after getting them installed ride actually felt good. Then on Saturday I got the 17” Trd prop wheels installed. After that I felt like I started to feel more vibrations. Whether it be at a stand still or just going 25mph on a smooth road. Any thought of what could be causing this or is this expected? Any personal experience on vibrations or advice will be much appreciated. Thanks everyone!!!
  2. Mar 23, 2020 at 10:46 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
    Check your lug nuts, make sure they are all tight!!! I had one come off after a rotation, not fun.
  3. Mar 23, 2020 at 10:47 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    you have to make sure the balance was done Hub centric or Lug Centric depending on the rims
    super_white likes this.
  4. Mar 23, 2020 at 10:50 AM
    Tacoma Mike
    Southern Maine
    If your getting this vibration at a stand still like you posted it has nothing to do with tires.
  5. Mar 23, 2020 at 10:50 AM
    2ndGenTacomaHI
    Thanks for the reply!
    Just as a added note. I’m using the stock lug nuts that came on my truck.
    But they did do balancing yesterday when I got them installed. Not sure how it was done.
  6. Mar 23, 2020 at 10:52 AM
    2ndGenTacomaHI
    Thanks Mike. I figured that. Just weird with the timing that it didn’t start until I got new wheels on Saturday. Like the vibration ain’t serious at standstill. It’s a very faint one that i think wasn’t there previously.
  7. Mar 23, 2020 at 10:53 AM
    Tacoma Mike
    Southern Maine
    Shut your heater/ac and fan off
  8. Mar 23, 2020 at 10:54 AM
    2ndGenTacomaHI
    I’ll give that a try
  9. Mar 23, 2020 at 10:55 AM
    2ndGenTacomaHI
    Let’s say for conversation sake that we disregard the small vibration at standstill.
    Would the most common thing to check first is the lug nuts for why vibration may be occurring while driving?
  10. Mar 23, 2020 at 11:06 AM
    Tacoma Mike
    Southern Maine
    Keep moving the fence for me....lol
    For sure check lug nut torque.
    At's have more aggressive pattern.
    That slow a speed at 25 mph I would think it would be your thread pattern.
    I have trucks come in with lugs the size of your fist and you have a bad vibration at 5 mph..
  11. Mar 23, 2020 at 11:22 AM
    07tacomatoy
    07tacomatoy Shoots den
    Pacific Ocean
    2007 4x4, 2019 TRD SPORT 4x4
    Just curious how many miles on the truck? everything mostly stock?
    I ask because I had around 165k everything was fine (lol) then I threw on aftermarket rims w/ wildpeaks and it eventually brought out all types of vibes over the course of a year. started very minimal then got wild and lets just say im replacing most my suspension.
    Honestly doubt you have the same problem as me. more guys should chime in with ideas
  12. Mar 23, 2020 at 12:38 PM
    No Shoes Nation
    No Shoes Nation Well-Known Member
    2008 Taco SR5 Access Cab 4.0 4x4
    Hmm . . . none as yet, that's why i'm here . . .
    Are the lug nuts correct for the type of wheel?
  13. Mar 23, 2020 at 12:59 PM
    2ndGenTacomaHI
    Hey. I only got 35k miles on my truck and yes everything is stock.
  14. Mar 23, 2020 at 1:01 PM
    QuicksandTaco
    QuicksandTaco Well-Known Member
    Cody
    Oregon
    2015 Inferno TRD Pro 6spd
    URD short shifter, 285/75/16,
    Take them back and tell them you’re getting a vibration. Tell them to roadforce balance the wheels and that will solve your problems. If it still has a vibration then you may have a bad tire.
  15. Mar 23, 2020 at 1:03 PM
    QuicksandTaco
    Cody
    Oregon
    Did your truck come factory with steel wheels or alloy? Steel lug nuts are different.
    if a shop installed your trd pro wheels without noticing the wrong lug nuts, I would be cautious taking it back to them.
  16. Mar 23, 2020 at 1:19 PM
    2ndGenTacomaHI
    My truck had the stock trd sport wheels 2nd gen which are alloy and I now have the trd pro wheels (4Runner one) which are also alloy. So same lugs nuts should be fine. I’ll take it back for another tire balance and see if that helps.
    QuicksandTaco[QUOTED] likes this.
  17. Mar 23, 2020 at 3:02 PM
    07tacomatoy
    Pacific Ocean
    Ok yea its probably not your suspension with that low miles. probably tire/wheel related as others have sugested
  18. Mar 23, 2020 at 3:34 PM
    2ndGenTacomaHI
    Right on. Thank you!
  19. Mar 24, 2020 at 5:20 AM
    Stormtrooper457
    Stormtrooper457 Well-Known Member
    Indiana
    2013 TRD Sport DCLB
    Nano Ceramic Tint Heated Clazzio Seats TRD Pro Wheels Softopper
    Don't disregard the vibration at a stand still. Check the driveshaft to make sure you don't have any failing U joints. Those will cause vibrations at all speeds.
    If the vibration is only there upon moving you need to check your lug nuts first. Then you need to know if your new wheels are lug centric or hub centric. If they are lug centric wheels, did you get the proper adapters for the wheels and did the shop do road force balancing. If you don't know, call the tire shop and ask. This is critical information.
    Then once you have ruled those out, take the tires back and have them rebalance the wheels. You may have lost a weight already or they just made a simple mistake when balancing.
  20. Mar 24, 2020 at 6:53 AM
    QuicksandTaco
    Cody
    Oregon
    Failed u joints would not cause a vibration when the truck is stopped. Trd pro wheels are hub centric
    Jimmyh likes this.
