Vibration after toytec aal and 5100 install
Discussion in 'Suspension' started by wildtrt, Apr 12, 2013.
  1. Apr 12, 2013 at 11:37 AM
    wildtrt
    wildtrt [OP] Active Member
    TXPRO
    Hey Guys
    Any advice on this? Installed AAL and 5100's. Vibration between 70-75 mph. Installed carrier bearing drop kit, no effect still Vibration.
    I have a 12 Dbl Cab TRD.
  2. Apr 12, 2013 at 6:17 PM
    ScudRunner
    ScudRunner Three Tacomas Deep
    Erik
    Twin Cities, MN
    07 TRD 4x4
    IMRYO mirror mount, color keyed front and rear, SCS wheels, 5100 on corners, ALCAN leaf packs, ECGS bushing
    No advice, but definitely watching since I have a box of 5100s and a Toytec AAL sitting in my garage.
    Did you get an alignment check after you put the 5100s in the front?
  3. Apr 12, 2013 at 8:18 PM
    Dirty G
    Dirty G Active Member
    Colorado Springs
    DC TRD Off Road
    TOYTEC coils, Rear TSB
    I have the same issue in a 2011. My fix was to remove the over load spring. I don't like it with out and will be putting the spring back on soon. Thinking about trying shims next.
  4. Apr 13, 2013 at 12:50 PM
    ScudRunner
    Erik
    Twin Cities, MN
    07 TRD 4x4
    Did you do the AAL in addition to TSB or without?
  5. Apr 14, 2013 at 8:31 AM
    wildtrt
    TXPRO
    I put on the aal Wo the tsb. My dealer gave me such a hassle that I just bought the aal. Got my truck aligned right after I installed the shocks and aal. Vibration was there right from the start. Had it back twice to the suspension shop and everything checks out. I'm going to put in the shims get it aligned again. Vibe still there the aal is coming out and I'll deal with it being stock or fight for the tsb.
  6. Apr 14, 2013 at 8:56 AM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    Mini H1 Retrofit 5K, 1st Gen TRD CAI, JBA Catback, Radflo 2.5 extended coilovers w/ resis, Radflo 2.5 rear shocks with resis, toytec superflex rear springs, DSM Uniball UCA's, intake manifold spacer
    Try the carrier bearing drop kit first. Alot easier to install than the shims. If that doesn't work then try shims.
  7. Apr 14, 2013 at 9:10 AM
    CAD41985
    CAD41985 Well-Known Member
    Corey
    Virginia Beach, VA
    12 TRD Sport 4x4 DCLB Super White
    Toytec 3" ULK, LR UCA's, 17" Procomp 7089's with 285/70/17 BFG KM2's, debadged tailgate, plasti-dipped front and side emblems, Weather tech rear liner, ARE camper shell
    Is it a steady vib or a pulsing vibration? Start simple and check your wheels and tires and make sure they are on/balanced correctly. Sounds dumb but you eliminating the smaller things before you go major is more pocket friendly. I have the Toytec ULK on my 12 double cab and noticed a slight pulsing in the front left, turns out my tire is slightly out of shape (apparently that's common with M/T's) once it warms up it rides just fine. If you've tried all the little things, then I would say go with the shims, I have them on mine and no vibs, then try the front diff drop. Those are the only things I have on mine that you don't on yours. Either way good luck.
  8. Apr 14, 2013 at 6:01 PM
    Dirty G
    Colorado Springs
    DC TRD Off Road
    I originally installed with the over load in. At ~40 and ~60 mph I got a steady vib. Added the bearing drop and it lessened. Removed the over load and kept the drop and it lessened but never went away. The back end is to low with out he over load so it's going back in. May try to drop the bearing again or shim. Have not decided. Will by Friday when I have time to work on it.
