Vibration After Wheel & Tire Install
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Nemesis_5.0, Apr 30, 2012.
  1. Apr 30, 2012 at 7:00 PM
    Nemesis_5.0
    Nemesis_5.0 [OP] Well-Known Member
    New Mexico
    '12 REG CAB 4X4
    I recently bought new wheels and tires for my '12 reg cab 4x4. I noticed some road noise, which was expected with the MT's but im also feeling a vibration throughout the whole truck. I can definitely feel it in the seats and steering wheel at times. It seems like its more noticeable between 45-70 mph. I have had the wheels and tires balanced twice and also had them road force balanced, but i still notice the vibration. It's stock with no lift. It almost kinda feels like a driveshaft issue, but i have searched and found no tsb's on the driveshafts on the reg cabs only on the double cabs with the two piece driveshaft. I have been told the MT's will have a little bit of vibration but this seems excessive. I have never had MT's on a truck before so it may just be that im not used to the way they ride. Any body else have this issue or any ideas on what else to check? The tires are Toyo Open Country MT's 265/75R16. Thanks in advance for any feedback.
  2. Apr 30, 2012 at 7:06 PM
    NelsonTacoma
    NelsonTacoma This is my derpawayinator!!!!!
    Tucson, AZ
    06 PreRunner TRD Sport 03 4Runner Limited 4wd
    Bilstein 5100's , 6000k HID Hi/Low Kit, Magnaflow Muffler, 1.5 inch AP Wheel Spacers, Mudflap Delete
    Are the new wheels you got hub centric? If not, that might be the problem.
  3. Apr 30, 2012 at 7:09 PM
    azreb
    azreb Geezer
    AZ mountains
    09 AC 4x4 stock
    camper shell, platform to replace rear seats.
    One or more might be out of round. I have had that problem with several brands of tires.
  4. Apr 30, 2012 at 7:16 PM
    Nemesis_5.0
    New Mexico
    '12 REG CAB 4X4
    I did some looking just now and they are not hubcentric. What does this mean? Is there a fix for that?
  5. Apr 30, 2012 at 7:17 PM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    X2 on the hub centric. What kind of wheels did you buy?
  6. Apr 30, 2012 at 7:20 PM
    NelsonTacoma
    Tucson, AZ
    Some companies sell a ring that fits around the hub to fill in the gap between your wheel and the hub to help them center better. This may or may not fix the problem. The only true way to fix it for sure is to get wheels that are hub centric. :(
  7. Apr 30, 2012 at 7:20 PM
    KenLyns
    KenLyns 8-in. Third Member
    Belly of the Beast
    4x4 TRD Off Road Full-Auto
    All-Pro Bumper, CBI Sliders, Icon Coilovers, BudBuilt Skids, aFe Intake, Icon VS Rear Shocks, Timbren Bumpstops, All-Pro UCAs, JDM Steering Wheel, ViAir Compressor, Klearz LED 3rd Brake Light, Pop-N-Lock Tailgate Handle, Husky Front Flaps
    The stock hub center is 106 mm. What is the wheel center bore diameter? If it's 108 mm or 110 mm, you can get a hubcentric ring that will bridge the gap. Find the PN here and Google for a place to buy them:
  8. Apr 30, 2012 at 7:28 PM
    Nemesis_5.0
    New Mexico
    '12 REG CAB 4X4
    they are the konig countersteers
  9. Apr 30, 2012 at 7:30 PM
    NelsonTacoma
    Tucson, AZ
    +1 good find
  10. Apr 30, 2012 at 7:30 PM
    Nemesis_5.0
    New Mexico
    '12 REG CAB 4X4
    Now that you mention it, each wheel in its own packaged box had a black ring in it, but i thought it was for the center cap for whatever reason and i didn't like the center caps so i didn't put the black rings! but i did keep them thank god! maybe that's all i need to do!
  11. Apr 30, 2012 at 7:33 PM
    Nemesis_5.0
    New Mexico
    '12 REG CAB 4X4
    @KenLyns: Im not sure what the center bore is on the wheels (konig countersteers) but i am looking for that info right now. I did notice some black rings like those in your post in the packages with the wheels but i thought they were for the center caps for whatever reason, i didn't install the center caps so i didn't use the black rings, but now thanks to you i will try them and see if it changes anything!! Thanks a million!
  12. Apr 30, 2012 at 7:35 PM
    NelsonTacoma
    Tucson, AZ
    Sweet!!! Install them and let us know how it turns out. :D:D:D
  13. Apr 30, 2012 at 7:40 PM
    Nemesis_5.0
    New Mexico
    '12 REG CAB 4X4
    I know right! i was getting aggrivated having to go to the tire shop over and over with no progress. I'm at work right now (working the graveyard shift) but i will install them in the morning and post the results, hopefully that's all i need!:D
  14. Apr 30, 2012 at 7:59 PM
    KenLyns
    Belly of the Beast
    The Countersteers have 108 mm bores. You are supposed to use the black rings when running without the center caps. The rings basically take up the thickness of the center caps.
  15. Apr 30, 2012 at 8:07 PM
    Nemesis_5.0
    New Mexico
    '12 REG CAB 4X4
    Oh ok that makes sense now, you just made my night! i was bummed out about all this. Thanks again for the info i really appreciate it.
  16. May 1, 2012 at 11:00 AM
    Nemesis_5.0
    New Mexico
    '12 REG CAB 4X4
    @KenLyns: I installed the supplied rings that came with the wheels and the vibration has been cut down by alot! I think all thats left is just the normal vibration from the MT's! Thanks a bunch! I am wanting to get me some of the Gorilla Hub Rings you posted though, seems like a better brand. Need some more help, Ok you said my stock hubs are 106mm and the konig countersteers are 108mm center bore, so then i would need PN 108-1061, correct?
  17. May 1, 2012 at 5:03 PM
    KenLyns
    Belly of the Beast
    PN is 108-106.1, and it's recognized on Amazon.com, among other places. Beware the rings that came with my Countersteers look identical to the Gorilla rings, so no need to "upgrade". Doesn't hurt to keep a set of rings as backup, though, as they are not reusable: if you ever switch to hubcentric wheels (e.g. OEM wheels with snow tires), the rings will likely be destroyed when you pry them off the hub.
  18. May 1, 2012 at 6:36 PM
    NelsonTacoma
    Tucson, AZ
    Glad to hear we got this resolved for you!! :yay:
  19. May 1, 2012 at 6:40 PM
    Nemesis_5.0
    New Mexico
    '12 REG CAB 4X4
    Awesome! I ordered me some from Amazon:D The ones that came with the wheels didn't have the notches on them like the gorilla ones nor did they say "gorilla" on them like it shows on their website. I might order me another set just to have as a spare. Thanks again I really appreciate all the help from you and the other guys that chimed in.
  20. May 1, 2012 at 6:43 PM
    Nemesis_5.0
    New Mexico
    '12 REG CAB 4X4
    :amen:Yes sir!!! You and me both!! Thanks for all the help!
