Vibration and gear catching sound upon accelerating
Discussion in '2nd Gen. Tacomas (2005-2015)' started by clever421, Mar 20, 2024.
  1. Mar 20, 2024 at 7:09 PM
    clever421
    clever421 [OP] New Member
    Hello,
    I am at a loss as to what could be the issue with my 2012 v6 Tacoma TRD.
    So far I have changed the CV axles, wheel bearings, and needle point bearing on the driver side inside the drive shaft as those have been the most common fix for vibrations I've found browsing these forums. I don't have a lift but I decided to change the needle point bearing regardless hoping to fix the issue.
    My traction control sensor keeps popping as well due to the vibration issue..
    The sound I hear when I press the gas while in motion after letting off the gas sounds like it is coming from the drive shaft and could be described as a sound that gears would make if torqued after being tension being released if that makes sense. This is an automatic transmission as well.
    The milage on the truck is currently 190k.
    I planned on calling a Les Schwab in the morning to make an appointment for a diagnosis but I plan on fixing whatever the issue is and hope someone here could help me figure out where to start..
  2. Mar 20, 2024 at 8:24 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Drop the driveshaft and check the u-joints
  3. Mar 20, 2024 at 8:49 PM
    jdg
    jdg Well-Known Member
    David
    Texas Panhandle
    2015 Tacoma SR5, V6, automatic, 4x4, extended cab
    All the time!!!
    Check the drive shaft, u-joint, and carrier bearing!
    clever421[OP] likes this.
