Vibration. Another thread
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mrlee, Jun 8, 2024.
  1. Jun 8, 2024 at 10:45 AM
    mrlee
    mrlee [OP] I like crunchy Tacos!!
    2013 TRD Sport (Yeah, it's gotta skewp, Haterz gonna hate)
    Bed rug, ARE bed top, Weathertechs. Little goodies here and there!
    2013 tacoma. 111800 on the clock
    Have a slight vibration coming from the right front. (Swerve going right, its quiet)
    Replaced the right front hub assembly and my cousin thought the old one looked good and the wheel didn't shake. Left front seemed solid too.
    Thanks @05Taco4x4 for his services.
    In 4x4 and no change
    Has newer Michelins on it, rotated right side made no diff.
    Has Billy 5100 set up one notch. Maybe three/four years old. Billy 5100 on back done at the same time.
    Alignment was checked and was within spec but honestly I think it could be better. I'll have to pull the sheet on that.
    Everything seems tight
    Serviced differential fluids at 60k
    I had the truck since it was a baby at 20k miles so have good knowledge of what's been done
    Front core eurothane bushings installed.
    No other suspension mods.
    I think I might try another alignment. Anyone got any other ideas?
  2. Jun 10, 2024 at 2:53 PM
    IA DIY
    IA DIY Well-Known Member
    Iowa
    2008 DCLB 4x4
    Alignment, meh.
    Have the tire balance checked. Check upper ball joint, lower ball joint, tie rod, and sway bar link for slop.
  3. Jun 15, 2024 at 1:32 PM
    mrlee
    All was fine. Turned out to be left front wheel bearing
    IA DIY likes this.
  4. Jun 15, 2024 at 3:14 PM
    Hook78
    Hook78 Well-Known Member
    Eastern NC
    2015 DCSB TRD OR
    Bilstein 6112/5160 Icon RXT
    But vibe was coming from right front I thought you said? Hey if it’s gone it’s gone though.
  5. Jun 16, 2024 at 9:09 AM
    mrlee
    Yeah. When I Swerved right taking the pressure off the right it would go away. So I thought it was right side
    IA DIY likes this.
